08R-JWPF-VSLE-D
08R-JWPF-VSLE-D
    JST
    P=2mm
    2X4P 2MM
08R-JWPF-VSLE-D 数据手册
JWPF CONNECTOR 2.0mm pitch/Disconnectable Crimp style connectors (Combined use for both wire-to-board and wire-to-wire connections) 4 Specifications –––––––––––––––––– This JWPF connector can be used for the place of which especially waterproof is required. This is the wire-to-board connector that is grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529). • Waterproof performance • Contained seal ring • Solid rubber seal • Double-spring construction • Housing-to-terminal locks • Inner housing lock • Header for use specifically with resin coated ("potted") PC board • Current rating: 3 A AC, DC (AWG #22) • Voltage rating: 100 V AC, DC • Temperature range: -55˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 15 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #26 to #22 0.13 to 0.33 mm2 Insulation O.D./ 1.4 to 1.7 mm • Waterproof grade: Grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529 ) * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards ––––––––––––––––––––– 0 2 Recognized E60389 R50326661 PC board layout and Assembly layout Double-row type Single-row type 7 +0.1 0 3 ±0.05 21 16.6 ±0.05 4 2.45 ±0.05 6 2 ±0.05 3 2.05 ±0.05 2 16.6 21 1.5 φ1±0.05 6 φ1±0.05 φ1.1 1.5 2 +0.1 0 φ1.1 ±0.05 11 2±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 1 JWPF CONNECTOR Contact Applicable wire mm2 AWG# Model No. SWPR-001T-P025 0.13∼0.33 Insulation O.D (mm) Q'ty/reel 1.4∼1.7 8,200 26∼22 Material and Finish Copper alloy, tin-plated (reflow treatment) 11.7 6 RoHS compliance 4.5 Contact Applicator Dies Crimping machine Crimp applicator SWPR-001T-P025 AP-K2N MKS-L Crimp applicator with dies MK/SWPR/T-001-025 APLMK SWPR/T001-025 − − − Housing (2 circuits) 7 16.5 5.5 Circuits Model No. Q'ty/bag 2 02R-JWPF-VSLE-S 03R-JWPF-VSLE-S 04R-JWPF-VSLE-S 06R-JWPF-VSLE-D 08R-JWPF-VSLE-D 1,000 3 2 4 6.7 6 8 Material PBT, UL94V-0, natural (white) (3 circuits) 7 16.5 8.7 2 5.5 (4 circuits) 7 16.5 (6 circuits) 2 10.7 5.5 11 16.5 8.7 2 9.5 4 (8 circuits) 11 2 10.7 9.5 4 Note: Housing comes with seal rubber plate. 2 16.5 RoHS compliance 1,000 1,000 1,000 1,000 JWPF CONNECTOR Shrouded header (2 circuits) (3.3) 16.6 8.1 Circuits Model No. Q'ty/box 2 B02B-JWPF-SK-R B03B-JWPF-SK-R B04B-JWPF-SK-R B06B-JWPF-SK-R B08B-JWPF-SK-R 825 3 4 8 525 330 270 2 7 6 650 Material and Finish 1.2 Press pin: Copper alloy, tin-plated (reflow treatment) Seal ring: Silicon rubber Seal ring holder: PBT, UL94V-0, yellow Wafer: Glass-filled PBT, UL94V-0, natural (white) (3 circuits) 16.6 8.4 16.6 8.4 16.6 12.8 4 16.6 12.5 RoHS compliance This product displays (LF)(SN) on a label. 2 9 (3.3) 1.2 2 (3.3) 11 (4 circuits) 1.2 (6 circuits) 2 9.8 (3.3) 1.2 (8 circuits) (3.3) 11.8 2 4 1.2 3
08R-JWPF-VSLE-D
物料型号: - JWPF连接器,具有2.0mm的间距,可断开的压接式连接器,适用于线对板和线对线的连接。
器件简介: - 这种JWPF连接器特别适用于需要防水的场所。它是一种线对板连接器,具有JIS C 0920标准的7级防护等级(相当于IEC 60529的IPX7)。
引脚分配: - 单排和双排类型,引脚间距为1.5mm,公差为±0.05mm。
参数特性: - 电流额定值:3A AC/DC(AWG #22) - 电压额定值:100V AC/DC - 温度范围:-55°C至+85°C(包括通电时的温度上升) - 接触电阻:初始值/最大10mΩ,环境测试后/最大15mΩ - 绝缘电阻:最小1000MΩ - 耐压:1000V AC/分钟 - 适用线材:AWG #26至#22,0.13至0.33 mm²,绝缘外径1.4至1.7 mm
功能详解: - 防水性能、密封圈、实心橡胶密封、双弹簧结构、外壳至端子锁、内外壳锁、专门用于涂覆树脂("灌封")PC板的插座。
应用信息: - 适用于需要防水保护的场合,例如汽车、工业设备等。
封装信息: - 材料:铜合金,镀锡(回流处理) - 符合RoHS标准 - 外壳材料:PBT,UL94V-0,自然色(白色) - 密封圈材料:硅橡胶 - 密封圈座:PBT,UL94V-0,黄色 - 晶片:玻璃填充PBT,UL94V-0,自然色(白色)
08R-JWPF-VSLE-D 价格&库存
很抱歉,暂时无法提供与“08R-JWPF-VSLE-D”相匹配的价格&库存,您可以联系我们找货
