Emboss Tape
SHD CONNECTOR
1.0mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
• Current rating: 1.0 A AC, DC (AWG #28)
• Voltage rating: 50 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 20 mΩ max.
After environmental tests/ 40 mΩ max.
• Insulation resistance: 100 MΩ min.
• Withstanding voltage: 500 VAC/minute
• Applicable wire: Conductor size/ AWG #32 to #28
Insulation O.D./ 0.4 to 0.8 mm
11
21
31
39
The SHD connector is compact with a
mounting height of 6.3mm for top entry
type and 5.5mm for side entry type, and a
width of 5.0mm for top entry type and
5.1mm for side entry type.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
• Compact, low profile design
• Anti-misinsertion feature
• Receptacles with protrusions
• Header designed for vacuum pick and place robotics
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
PC board layout and Assembly layout
Top entry type
0.9±0.1
Side entry type
0.85±0.1
5.4
Header outline
0.6
1±0.1
Circuit No.1
7.1
1.6
0.5
4
7.2
1.8±0.1
Header outline
0.6
0.85±0.1
1.6
0.9±0.1
1.8±0.1
with a boss
6.3
4.1
1±0.1
5.5
Circuit No.1
Header outline
0.9
1.5
1.25±0.1
0.7
0.85±0.1
5.1
0.7
0.5
0.85±0.1
0.6
1±0.1
4
0.7
5
0.7
Note: 1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. The dimensions above should serve as a guideline. Contact JST for details.
φ0.55+0.05
Circuit No.1
7.2
1.9±0.1
1.8±0.1
1.5
Contact
Model No.
mm2
SSH-003GA-P0.2
0.032∼0.08
3.9
0.4∼0.8
23,000
Phosphor bronze, nickel-undercoated, Mating part; gold-plated
0.8
1.55
RoHS compliance
Note: Contact JST for tin-plated products.
0.8
1.35
0.5
32∼28
Q'ty/
reel
Material and Finish
1.6
2
Applicable wire
Insulation O.D. (mm)
AWG#
Contact
Crimping
machine Crimp applicator
0.45
SSH-003GA-P0.2 AP-K2N
Applicator
Dies
Crimp applicator with dies
MKS-L-10-3
MK/SSH/L-003-02 APLMK SSH/L003-02
*MKS-SC
SC/SSH/L-003-02 APLSC SSH/L003-02
Note: *Strip-crimp applicator
Contact JST for applicable wires in case that it is not usable due to wire size.
1
SHD CONNECTOR
Housing
C
A
1
No.1 mark
4.9
Model No.
Dimensions (mm)
Q'ty/box
A
B
C
SHDR-20V-S-B
9.0
11.2
13.0
4,000
SHDR-30V-S-B
14.0
16.2
18.0
4,000
40
SHDR-40V-S-B
19.0
21.2
23.0
2,000
50
SHDR-50V-S-B
24.0
26.2
28.0
2,000
Material
5
Circuit No.3
Circuits
PBT, UL94V-0, natural (white)
RoHS compliance
4.2
B
Shrouded header
Top entry type
Circuits
40
4.25
50
Circuits
1
0.2
Circuit No.1
A
30
Circuit No.3
B
40
0.7
5
50
Model No.
Top entry type
BM20B-SRDS-G-TF
BM30B-SRDS-G-TF
BM40B-SRDS-G-TF
BM50B-SRDS-G-TF
Dimensions (mm)
A
B
Model No.
Side entry type
Dimensions (mm)
A
B
SM20B-SRDS-G-TF
SM30B-SRDS-G-TF
SM40B-SRDS-G-TF
SM50B-SRDS-G-TF
Q'ty/reel
9.0
12.3
1,500
14.0
17.3
1,500
19.0
22.3
1,500
24.0
27.3
1,500
Q'ty/reel
9.0
13.1
1,250
14.0
18.1
1,250
19.0
23.1
1,250
24.0
28.1
1,250
Material and Finish
Side entry type
Header contact: Phosphor bronze, nickel-undercoated, gold-plated
Wafer: PA, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
Circuit No.3
Circuit No.1
RoHS compliance This product displays (LF)(SN) on a label.
Note: 1. The products listed above are supplied on embossed-tape.
2. Contact JST for the headers with tin-plated pins.
3. Contact JST for the top entry type headers with suction cap.
5.5
H JST
1
0.2
A
1.5
B
5.1
0.7
0.6
4.25
Top entry type with a boss
1
Circuit No.1
Circuit No.3
A
B
φ0.5
0.85
Model No.
BM20B-SRDS-A-G-TF
19.0
12.3
1,250
30
BM30B-SRDS-A-G-TF
14.0
17.3
1,250
40
BM40B-SRDS-A-G-TF
19.0
22.3
1,250
50
BM50B-SRDS-A-G-TF
24.0
27.3
1,250
Q'ty/reel
Material and Finish
1.9
0.2
Dimensions (mm)
A
B
Circuits
1.5
5
0.7
2
很抱歉,暂时无法提供与“SHDR-40V-S-B”相匹配的价格&库存,您可以联系我们找货
