SHDR-30V-S-B
SHDR-30V-S-B
    JST
    P=1mm
    2X15P 1MM
SHDR-30V-S-B 数据手册
SHD CONNECTOR Emboss Emboss Tape Tape 1.0 mm pitch/Disconnectable Crimp style connectors Specifications • Current rating: 1.0 A AC/DC (AWG #28) • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 40 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.4 to 0.8 mm SHD CONNECTOR 11 21 31 39 * In using the products, refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. The SHD connector is compact with a mounting height of 6.3 mm for top entry type and 5.5 mm for side entry type, and a width of 5.0 mm for top entry type and 5.1 mm for side entry type. ● ● ● ● Compact, low profile design Anti-misinsertion feature Receptacles with protrusions Header designed for vacuum pick and place robotics ® Standards  Recognized E60389 Certified LR20812 ® ® ® PC board layout and Assembly layout Top entry type 0.9±0.1 ® Side entry type 0.85±0.1 5.4 Header outline 1±0.1 0.6 Circuit No.1 (7.1) 1.6 0.5 4 7.2 1.8±0.1 Header outline 0.6 0.85±0.1 1.6 0.9±0.1 1.8±0.1 with a boss (6.3) 4.1 1±0.1 5.5 Circuit No.1 0.9 Header outline 1.25±0.1 0.5 0.85±0.1 φ0.55+0.05 0 Circuit No.1 1±0.1 0.6 7.2 1.9±0.1 4 1.8±0.1 1.5 0.7 5 0.7 0.85±0.1 1.5 5.1 0.7 0.7 Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. Contact Model No. 3.9 Applicable wire Insulation O.D. (mm) AWG # 0.032~0.08 32~28 0.4~0.8 23,000 Phosphor bronze, nickel-undercoated, Mating part; gold-plated 0.8 0.8 1.35 RoHS2 compliance Note: Contact JST for tin-plated products. 0.45 Contact Crimping machine Crimp applicator SSH-003GA-P0.2 AP-K2N MKS-L-10-3 Applicator Dies MK/SSH/L-003-02 Note: Contact JST for fully automatic crimping applicator. 1 Q'ty/ reel Material and Finish 1.6 1.55 2 0.5 SSH-003GA-P0.2 mm2 Crimp applicator with dies APLMK SSH/L003-02 SHD CONNECTOR Housing C A 1 No.1 mark 4.9 Model No. 20 30 40 SHDR-40V-S-B 50 SHDR-50V-S-B Dimensions (mm) Q'ty/box A B C SHDR-20V-S-B 9.0 11.2 13.0 4,000 SHDR-30V-S-B 14.0 16.2 18.0 4,000 19.0 21.2 23.0 2,000 24.0 26.2 28.0 2,000 SHD CONNECTOR Material and Finish 5 Circuit No.3 No. of circuits PBT, UL94V-0, natural (white) RoHS2 compliance 4.2 B Shrouded header No. of circuits Top entry type 20 30 40 4.25 50 1 No. of circuits 0.2 1.5 A Circuit No.1 20 30 Circuit No.3 B 40 0.7 5 50 Model No. Side entry type SM20B-SRDS-G-TF SM30B-SRDS-G-TF SM40B-SRDS-G-TF SM50B-SRDS-G-TF Dimensions (mm) A B Q'ty/reel 9.0 12.3 1,500 14.0 17.3 1,500 19.0 22.3 1,500 24.0 27.3 1,500 Q'ty/reel 9.0 13.1 1,250 14.0 18.1 1,250 19.0 23.1 1,250 24.0 28.1 1,250 Header contact: Phosphor bronze, nickel-undercoated, gold-plated Wafer: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) Circuit No.3 Circuit No.1 RoHS2 compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the headers with tin-plated pins. 3. Contact JST for the top entry type headers with suction cap. 5.5 H JST 0.2 A 1.5 B 5.1 0.7 0.6 4.25 Top entry type with a boss 1 Circuit No.1 Dimensions (mm) A B Material and Finish Side entry type 1 Model No. Top entry type BM20B-SRDS-G-TF BM30B-SRDS-G-TF BM40B-SRDS-G-TF BM50B-SRDS-G-TF Circuit No.3 A B Model No. 20 BM20B-SRDS-A-G-TF 19.0 12.3 1,250 30 BM30B-SRDS-A-G-TF 14.0 17.3 1,250 40 BM40B-SRDS-A-G-TF 19.0 22.3 1,250 50 BM50B-SRDS-A-G-TF 24.0 27.3 1,250 Q'ty/reel Material and Finish Header contact: Phosphor bronze, nickel-undercoated, gold-plated Wafer: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 1.9 0.2 Dimensions (mm) A B No. of circuits φ0.5 1.5 0.85 5 0.7 RoHS2 compliance This product displays (LF)(SN) on a label. Note: 1 . The products listed above are supplied on embossed-tape.  2. Contact JST for the headers with tin-plated pins. 2
SHDR-30V-S-B 价格&库存
很抱歉,暂时无法提供与“SHDR-30V-S-B”相匹配的价格&库存,您可以联系我们找货
