PHDR-12VS
PHDR-12VS
    JST
    P=2mm
PHDR-12VS 数据手册
PHD CONNECTOR 2.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10m Ω max. After environmental testing/ 20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.6mm This is a 2.0mm pitch, crimp style, doublerow, wire-to-board connector. It is designed to meet the demand for highdensity and low-profile connection. • Compact • Reliable contacts • Fully shrouded header * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Top entry type Side entry type 5 2 ±0.05 1.95 min φ0.7 +0.1  0 5 7 min Even number circuits (3) Odd number circuits 2 ±0.05 (3) 2 ±0.05 8.8 φ0.7 +0.1  0 1.95 min 11.8 1.5 min 2 ±0.05 Circuit No.1 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ±0.05mm for all centers. 3. Hole dimensions differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire AWG # mm2 Model No. 1.5 SPHD-002T-P0.5 SPHD-001T-P0.5 Insulation O.D. (mm) 0.08∼0.21 28∼24 0.9∼1.5 0.13∼0.33 26∼22 1.0∼1.5 Q'ty / reel 8,000 Material and Finish 6.5 Phosphor bronze, tin-plated (reflow treatment) 2.85 RoHS compliance 1.3 Contact Crimping machine Crimp applicator SPHD-002T-P0.5 AP-K2N Note: *Strip-crimp applicator 1 Applicator Dies Crimp applicator with dies MKS-L-10 MK/SPHD-002-05 APLMK SPHD002-05 *MKS-SC-10 SC/SPHD-002-05 APLSC SPHD002-05 Contact SPHD-001T-P0.5 Crimping machine Crimp applicator AP-K2N Applicator Dies Crimp applicator with dies MKS-L-10 MK/SPHD-001-05 APLMK SPHD001-05 *MKS-SC-10 SC/SPHD-001-05 APLSC SPHD001-05 PHD CONNECTOR Housing Circuits Model No. 8 PHDR-08VS PHDR-10VS PHDR-12VS PHDR-14VS PHDR-16VS PHDR-18VS PHDR-20VS PHDR-22VS PHDR-24VS PHDR-26VS PHDR-28VS PHDR-30VS PHDR-32VS PHDR-34VS 10 12 14 16 Circuit No.1 Circuit No.1 Circuit No.2 18 20 22 H JST 24 7.3 26 28 30 32 2 34 2 1.95 A 4.2 B 5 A Dimensions (mm) B Q'ty / bag 6.0 9.9 1,000 8.0 11.9 1,000 10.0 13.9 1,000 12.0 15.9 1,000 14.0 17.9 1,000 16.0 19.9 1,000 18.0 21.9 1,000 20.0 23.9 1,000 22.0 25.9 1,000 24.0 27.9 1,000 26.0 29.9 1,000 28.0 31.9 1,000 30.0 33.9 1,000 32.0 35.9 1,000 Material PA 66, UL94V-0, natural (white) RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PHDR-10VSS…natural (white) K…black Y…yellow E…blue R…red Shrouded header Top entry type Circuits Circuit No.1 8 10 JST 12 6.5 H 14 (3) 16 1.95 20 Circuit No.1 0.5 2 18 Circuit No.2 A 1.5 2 B 5 22 24 26 28 30 32 34 Model No. Glass-filled nylon Nylon Top entry Side entry Top entry Side entry type type type type B8B-PHDSS S8B-PHDSS B10B-PHDSS S10B-PHDSS B10B-PHDSS-B S10B-PHDSS-B B12B-PHDSS S12B-PHDSS B12B-PHDSS-B S12B-PHDSS-B B14B-PHDSS S14B-PHDSS B14B-PHDSS-B S14B-PHDSS-B B16B-PHDSS S16B-PHDSS B16B-PHDSS-B S16B-PHDSS-B B18B-PHDSS S18B-PHDSS B18B-PHDSS-B S18B-PHDSS-B B20B-PHDSS S20B-PHDSS B20B-PHDSS-B S20B-PHDSS-B B22B-PHDSS S22B-PHDSS B22B-PHDSS-B S22B-PHDSS-B B24B-PHDSS S24B-PHDSS B24B-PHDSS-B S24B-PHDSS-B B26B-PHDSS S26B-PHDSS B26B-PHDSS-B S26B-PHDSS-B B28B-PHDSS S28B-PHDSS B28B-PHDSS-B S28B-PHDSS-B B30B-PHDSS S30B-PHDSS B30B-PHDSS-B S30B-PHDSS-B B32B-PHDSS S32B-PHDSS B32B-PHDSS-B S32B-PHDSS-B B34B-PHDSS S34B-PHDSS B34B-PHDSS-B S34B-PHDSS-B Side entry type 0.5 A B Top entry Side entry type type 6.0 9.9 500 500 8.0 11.9 500 500 10.0 13.9 500 500 12.0 15.9 500 250 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 250 250 20.0 23.9 250 250 22.0 25.9 250 200 24.0 27.9 250 200 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 32.0 35.9 250 200 (3) 7 Circuit No.2 5 RoHS compliance This product displays (LF)(SN) on a label. 2 6.5 9.5 1.95 B Material and Finish JST 2 A Q'ty / box Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) PA 66, UL94V-0, natural (white) Circuit No.1 H Dimensions (mm) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Circuit No.1 ex. B10B-PHDSS- ex. B10B-PHDSS-B- S…natural (ivory) S…natural (white) K…black Y…yellow E…blue R…red 2
PHDR-12VS
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一款高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚(发光二极管正极),2脚(发光二极管负极),3脚(输出晶体管集电极),4脚(输出晶体管发射极),5脚(输出晶体管基极),6脚(内部参考电阻)。
4. 参数特性:主要参数包括隔离电压5000Vrms,响应时间1us,输入电流5mA,输出电流50mA。
5. 功能详解:EL817通过内部发光二极管和光敏晶体管实现电信号隔离,适用于高速数字信号传输。
6. 应用信息:EL817广泛应用于高速数字通信、工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 3.3mm。
PHDR-12VS 价格&库存
很抱歉,暂时无法提供与“PHDR-12VS”相匹配的价格&库存,您可以联系我们找货
PHDR-12VS
  • 1+2.130411+0.25425
  • 10+1.8463610+0.22035
  • 25+1.6853925+0.20114
  • 50+1.5623050+0.18645
  • 100+1.45815100+0.17402
  • 250+1.36346250+0.16272
  • 1000+1.259311000+0.15029
库存:2072
PHDR-12VS
    库存:7407
    PHDR-12VS
      库存:30000
