PAD CONNECTOR
2.0 mm pitch/Disconnectable Crimp style connectors
Specifications
• Current rating: 3 A AC/DC (AWG #22)
• Voltage rating: 250 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 800 VAC/minute
• Applicable wire: AWG #28 to #22
• Applicable PC board thickness: 1.6 mm
PAD CONNECTOR
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Dual-row construction allows
high density
PAD
mounting.
Secure locking device
Reliable contacts
Insertion guide mechanism
Polarizing boss
Standards
Recognized E60389
R50053749
PC board layout and Assembly layout
Top entry type
Side entry type
+0.1
φ1 0
2
±0.05
+0.1
Even number circuits
+0.1
φ0.7 0
(10)
Circuit No.1
2 ±0.05
Circuit No.1
2.5 ±0.05
+0.1
±0.05
φ1.1 0
Odd number circuits
φ0.7 0
1.6
1.4±0.05
2 ±0.05
2±0.05
1.6±0.05
A±0.05
1.3±0.05
A±0.05
Odd number circuits
(12.4)
(11)
(15.4)
2
10.7
Note: 1
. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions
should be larger. The dimensions above should serve as a guideline. Contact JST for details.
1
PAD CONNECTOR
Contact
Applicable wire
Model No.
5.7
2.05
SPH-001T-P0.5L
SPH-002T-P0.5L
1
26~22
1.0~1.5
0.08~0.22
28~24
0.8~1.5
0.13~0.33
Q't y/
reel
8,000
PAD CONNECTOR
RoHS2 compliance
Applicable wire
Model No.
7.5
3.9
Insulation O.D.
(mm)
Phosphor bronze, tin-plated (reflow treatment)
1.5
3
AWG #
Material and Finish
2.08
2.85
mm2
SPND-001T-C0.5
SPND-002T-C0.5
1.5
mm2
AWG #
Insulation O.D.
(mm)
26~22
1.0~1.5
0.08~0.22
28~24
0.8~1.5
0.13~0.33
Q't y/
reel
8,000
Material and Finish
2.08
Copper alloy, tin-plated (reflow treatment)
RoHS2 compliance
Note: SPND-( )T-C0.5 is low insertion/withdrawal force type contact, in
order to improve the work of insertion/withdrawal.
Contact
SPH-001T-P0.5L
SPH-002T-P0.5L
Applicator
Crimping
machine Crimp applicator
MKS-L
AP-K2N
Contact
Dies
Crimp applicator with dies
MK/SPH-001-05L
APLMK SPH001-05L
SPND-001T-C0.5
MK/SPH-002-05L
APLMK SPH002-05L
SPND-002T-C0.5
Note: Contact JST for fully automatic crimping applicator.
Applicator
Crimping
AP-K2N
MKS-L
Dies
MK/SPND-001-05
APLMK SPND001-05
MK/SPAD/ND-002-05 APLMK SPAD/ND002-05
Housing
No. of
circuits
B
A
10
Circuit No.1 mark
2
12
10
14
16
6.85
11
24
*40
Model No.
PADP-10V-1-S
PADP-12V-1-S
PADP-14V-1-S
PADP-16V-1-S
PADP-20V-1-S
PADP-22V-1-S
PADP-24V-1-S
PADP-40V-1-S
Dimensions (mm)
A
B
Q'ty/
bag
8.0
12.0
1,000
10.0
14.0
1,000
12.0
16.0
1,000
14.0
18.0
1,000
18.0
22.0
1,000
20.0
24.0
1,000
22.0
26.0
1,000
38.0
42.0
500
Material and Finish
2
PA 66, UL94V-0, natural (white)
RoHS2 compliance
Note: *Marked product is not TÜV approved.
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
Circuit No.1 mark
2
10
ex.
11
6.85
B
A
PADP-16V-1-SS...natural (white)
K...black R...red Y...yellow E...blue M...green P...purple
L...lemon yellow
2
2
PAD CONNECTOR
Shrouded header
Top entry type
2.5 2
3.1
□0.5
7.8
9.5
3.4
7.8
Circuit No.1
1.3
2
1.2
3.4
□0.5
B
A
9.5
10.2
2
10.2
B
A
1.2
Circuit No.1
1.3
2.5 2 3.1
Side entry type
B
B
A
A
10.2
3
(3)
2
10.7
3
10.5
10.7
2
(3)
2
10.5
10.2
2
Circuit No.1
Circuit No.1
No. of
circuits
10
12
14
16
24
*40
Model No.
Top entry type
With a boss Without a boss
B10B-PADSS-1F B10B-PADSS-F
B12B-PADSS-1F B12B-PADSS-F
B14B-PADSS-1F B14B-PADSS-F
B16B-PADSS-1F B16B-PADSS-F
B20B-PADSS-1F B20B-PADSS-F
B22B-PADSS-1F B22B-PADSS-F
B24B-PADSS-1F B24B-PADSS-F
B40B-PADSS-1F
Side entry type
S10B-PADSS-1
S12B-PADSS-1
S14B-PADSS-1
S16B-PADSS-1
S20B-PADSS-1
S24B-PADSS-1
Dimensions Q'ty/box
(mm)
Top
Side
entry type entry type
A
B
8.0
12.0
400
504
10.0
14.0
300
420
12.0
16.0
300
364
14.0
18.0
200
336
18.0
22.0
150
280
20.0
24.0
150
22.0
26.0
150
224
38.0
42.0
100
Material and Finish
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PBT, UL94V-0, (natural) [side entry type]
Glass-filled PA 66, UL94V-0, (natural) [top entry type]
RoHS2 compliance This product displays (LF)(SN) on a label.
Note: * Marked product is not TÜV approved.
ex.
B16B-PADSS(-1F)S...natural (white)
L...lemon yellow
3
很抱歉,暂时无法提供与“PADP-24V-1-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.294391+0.42618
- 50+3.0537450+0.39505
- 100+2.53096100+0.32742
- 300+2.19073300+0.28341
- 500+2.12435500+0.27482
- 1000+2.066261000+0.26731
- 4000+2.033074000+0.26301
- 国内价格 香港价格
- 1+4.384951+0.56726
- 10+3.1533210+0.40793
- 50+2.6204950+0.33900
- 100+2.26236100+0.29267
- 500+2.19248500+0.28363
- 1000+2.140071000+0.27685
- 2000+2.113862000+0.27346
- 国内价格 香港价格
- 1+3.467781+0.44861
- 50+3.2144750+0.41584
- 100+2.66417100+0.34465
- 300+2.30603300+0.29832
- 500+2.23615500+0.28928
- 1000+2.175011000+0.28137
