PHDR-26VS
PHDR-26VS
    JST
    P=2mm
    2X13P 2MM
PHDR-26VS 数据手册
PHD CONNECTOR 2.0 mm pitch/Disconnectable Crimp style connectors Specifications PHD CONNECTOR • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃                     (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.6 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. This is a 2.0 mm pitch, crimp style, dual-row, wire-to-board connector. It is designed to meet the demand for high-density and low-profile connection. ● Compact ● Reliable contacts ● Fully shrouded header Standards ® ® ® PC board layout and Assembly layout Top entry type 1.95 min. Side entry type 2±0.05 1.95 min. (11.8) +0.1 φ0.7  0 Even number circuits 5 7 min. (8.8) (3) (3) 2 ±0.05 Odd number circuits Circuit No.1 2 ±0.05 +0.1 φ0.7 0 ® ® 5 1.5 min. 2 ±0.05 Recognized E60389 Note: 1  . The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG # Model No. 1.5 SPHD-002T-P0.5 SPHD-001T-P0.5 Insulation O.D. (mm) 0.08~0.21 28~24 0.9~1.5 0.13~0.33 26~22 1.0~1.5 Q'ty/ reel 8,000 Material and Finish 6.5 Phosphor bronze, tin-plated (reflow treatment) 2.85 1.3 RoHS2 compliance Contact SPHD-002T-P0.5 SPHD-001T-P0.5 Crimping machine Crimp applicator AP-K2N MKS-L-10 Applicator Dies APLMK SPHD002-05 MK/SPHD-001-05 APLMK SPHD001-05 Note: Contact JST for fully automatic crimping applicator. 1 Crimp applicator with dies MK/SPHD-002-05 PHD CONNECTOR Housing No. of circuits 8 10 12 14 16 Circuit No.1 Circuit No.1 Circuit No.2 18 20 22 H JST 24 7.3 26 28 30 32 2 34 2 1.95 A 4.2 B 5 Model No. PHDR-08VS PHDR-10VS PHDR-12VS PHDR-14VS PHDR-16VS PHDR-18VS PHDR-20VS PHDR-22VS PHDR-24VS PHDR-26VS PHDR-28VS PHDR-30VS PHDR-32VS PHDR-34VS A Dimensions (mm) B Q'ty/ bag 6.0 9.9 1,000 8.0 11.9 1,000 10.0 13.9 1,000 12.0 15.9 1,000 14.0 17.9 1,000 16.0 19.9 1,000 18.0 21.9 1,000 20.0 23.9 1,000 22.0 25.9 1,000 24.0 27.9 1,000 26.0 29.9 1,000 28.0 31.9 1,000 30.0 33.9 1,000 32.0 35.9 1,000 PHD CONNECTOR Material and Finish PA 66, UL94V-0, natural (white) RoHS2 compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PHDR-10VSS...natural (white) K...black Y...yellow E...blue R...red Shrouded header Top entry type No. of circuits Circuit No.1 8 10 12 6.5 JST H 14 16 (3) 18 Circuit No.1 □0.5 2 1.95 20 Circuit No.2 A 1.5 2 B 5 22 24 26 28 30 32 34 Side entry type 1.95 □0.5 A B Q'ty/box Top entry Side entry type type A B 6.0 9.9 500 500 8.0 11.9 500 500 10.0 13.9 500 500 12.0 15.9 500 250 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 250 250 20.0 23.9 250 250 22.0 25.9 250 200 24.0 27.9 250 200 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 32.0 35.9 250 200 (3) 7 Circuit No.2 5 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) PA 66, UL94V-0, natural (white) RoHS2 compliance This product displays (LF)(SN) on a label. 2 9.5 6.5 JST 2 Dimensions (mm) Material and Finish Circuit No.1 H Model No. Glass-filled nylon Nylon Top entry Side entry Top entry Side entry type type type type S8B-PHDSS B8B-PHDSS S10B-PHDSS B10B-PHDSS-B S10B-PHDSS-B B10B-PHDSS S12B-PHDSS B12B-PHDSS-B S12B-PHDSS-B B12B-PHDSS S14B-PHDSS B14B-PHDSS-B S14B-PHDSS-B B14B-PHDSS S16B-PHDSS B16B-PHDSS-B S16B-PHDSS-B B16B-PHDSS S18B-PHDSS B18B-PHDSS-B S18B-PHDSS-B B18B-PHDSS S20B-PHDSS B20B-PHDSS-B S20B-PHDSS-B B20B-PHDSS S22B-PHDSS B22B-PHDSS-B S22B-PHDSS-B B22B-PHDSS S24B-PHDSS B24B-PHDSS-B S24B-PHDSS-B B24B-PHDSS S26B-PHDSS B26B-PHDSS-B S26B-PHDSS-B B26B-PHDSS S28B-PHDSS B28B-PHDSS-B S28B-PHDSS-B B28B-PHDSS S30B-PHDSS B30B-PHDSS-B S30B-PHDSS-B B30B-PHDSS S32B-PHDSS B32B-PHDSS-B S32B-PHDSS-B B32B-PHDSS S34B-PHDSS B34B-PHDSS-B S34B-PHDSS-B B34B-PHDSS As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Circuit No.1 ex. B10B-PHDSS- S...natural (ivory) ex. B10B-PHDSS-B- S...natural (white) K...black Y...yellow E...blue R...red 2
PHDR-26VS 价格&库存
很抱歉,暂时无法提供与“PHDR-26VS”相匹配的价格&库存,您可以联系我们找货
PHDR-26VS
    库存:940
    PHDR-26VS
    • 5+1.20161
    • 50+0.95559
    • 150+0.85018
    • 1000+0.71864
    库存:1716
    PHDR-26VS
    • 1+4.928481+0.63963
    PHDR-26VS
      • 5+1.34630
      • 50+1.07060
      • 150+0.95250
      • 1000+0.80510
      库存:1735
