568-001-000-200
568-001-000-200
568-001-000-200 数据手册
568 SERIES WATERPROOF WIRE TO WIRE CONNECTORS Features: • • • • • • Rated current: 12A max Splashproof solution for single position Available in wire to wire option True crimp and poke solution with various sized wire seals available Available with wire already installed Splash Proof Grade: IP52 (JIS C0920) Certified Specifications: Rated Voltage 300 V Rated Current 12 amps maximum Dielectric Withstanding Voltage 1700 V AC (rms) Contact Resistance 10 milliohms maximum Insulation Resistance 1000 megaohms minimum/DC 500 V Operating Temperature -40°C to +105°C Crimp Contact: Materials: Male Contact (Pin) Housing PBT, UL 94V-0 Contact Ph. Brz. or Brass Part No (Material) AWG# Ins. Dia. Pcs/Reel Contact Plating Tin Plating 570-290-751 (Brass) 14 Max. Ø3.1 4,000 Wire & Housing Seals Silicone Rubber 570-291-731 (Ph. Brz.) 20-16 Max. Ø3.1 4,000 570-290-731 (Brass) 20-16 Max. Ø3.1 4,000 570-290-711 (Brass) 22-20 Max. Ø2.7 4,000 **Crimp Contacts are also available in strips of 40pcs. Contact EDAC for more information. Wire Seal: Female Contact (Socket) Part No. Wire O.D. Color AWG# Ø Dia. Height Part No (Material) AWG# Ins. Dia. Pcs/Reel 570-260-001 Ø1.7~Ø2.1 Black 22 Ø 5.0 6.0 570-290-761 (Brass) 14 Max. Ø3.1 4,000 570-260-002 Ø2.1~Ø2.7 Light Blue 22-20 Ø 5.0 6.0 570-291-741 (Ph. Brz.) 20-16 Max. Ø3.1 4,000 6.7 570-290-741 (Brass) 20-16 Max. Ø3.1 4,000 5.0 570-291-721 (Ph. Brz.) 22-20 Max. Ø2.7 4,000 570-290-721 (Brass) 22-20 Max. Ø2.7 4,000 570-260-003 570-260-004 Ø2.1~Ø2.7 Ø2.7~Ø3.1 Blue 22-20 Brown 570-260-002 570-260-001 Ø 5.0 20-14 Ø 4.9 570-260-004 570-260-003 Ordering Guide: Male Housing: 568-001-000-100 www.edac.net Female Housing: Assembly Layout: 568-001-000-200 customerservice@edac.net
568-001-000-200 价格&库存
很抱歉,暂时无法提供与“568-001-000-200”相匹配的价格&库存,您可以联系我们找货
