REVISION X
IPBD-XX-D-X
((No OF POSITIONS x .1650) + .0400)
.012
.002
.060
DO NOT
SCALE FROM
THIS PRINT
No OF POSITIONS
-02 THRU -15
(PER ROW)
[SEE FIG. 2 FOR -02 POSITION]
.095±.010
.075±.010
.485
.15
.100
(NO DRAFT)
ROW SPECIFICATION
-D: DOUBLE
.773±.006
NOTES:
1.
REPRESENTS A CRITICAL DIMENSION.
2. SAMTEC LOGO SHALL APPEAR AT ONE LOCATION ON SURFACE SHOWN,
APPROXIMATELY .15 x .09 (BOTH SIDES).
3. ALL MULTIPLE CAVITY MOLDS SHALL IDENTIFY EACH CAVITY WITH
TOOL DEPENDANT CAVITY ID AT THE DISCRETION OF SAMTEC ENGINEERING.
4. ALL IDENTIFICATION MARKS MUST NOT STAND GREATER THAN .002 OFF THE
SURFACE OF THE PART.
5. MOLDED SURFACES SHALL BE CONSISTENT AND SMOOTH. SURFACES TO BE
FREE OF SCATCHES, NICKS, SINK AREAS, VOIDS OR OTHER BLEMISHES.
6. MAX ALLOWABLE BOW: SEE TABLE 1.
7. PART TO BE SYMMETRIC ABOUT THE CENTERLINE WITHIN +/-.001, UNLESS
OTHERWISE STATED.
8. NUMBER OF POSITIONS (PER ROW) TO BE SHOWN ON THIS SURFACE, SIZE
AND DEPTH SIMILAR TO POSITION 1INDICATOR.
9. GATE PAD MUST BE RECESSED .005. GATE LOCATION IS AT THE MOLDERS DISCRETION.
10. END CORES ARE POLARIZED. CONFIRM GEOMETRY RELATIVE TO POSITION 1
INDICATOR & GATE PAD.
11. POSITION 1 INDICATOR TO BE .0005 MAX DEPTH.
12. EACH POSITION TO BE IDENTIFIED WHERE SHOWN.
13. .0005 MAX MISMATCH PERMISSIBLE (ALL FOUR SIDES).
14. LATCH MUST CYCLE 10 TIMES WITHOUT EVIDENCE OF CRACKING
OR COMPROMISE OF FUNCTION.
15. CHECK THIS FEATURE WITH GO/NOGO GAUGE.
16. OPTION NOT FOR SALE. FOR RETENTION LATCH FEATURE, SEE IPBD-XX-D-ML PRINT.
17. POSITION INDICATOR NOT PRESENT ON 2 & 3 POSITION -R OPTION BODIES.
SEE NOTE 11
((No OF POSITIONS -1) x .1650)
.0050
.0050
.1025±.0020
'G'
+.0075
.478 - .0000
01
02
S/S BOW SEE TABLE 1
"A"
+.0015
.1650 - .0050
09
"A"
.378
'B'
'A'
FIG 1
1 MAX DRAFT (TYP)
IPBD-08-D SHOWN
"B"
1 MAX DRAFT (TYP)
'E
SEE NOTE 13
'C'
SEE NOTE 8
+.005
.280
T/B BOW SEE TABLE 1
SECTION "B"-"B"
SEE NOTE 12
'F'
15
14
08
07
06
11
10
09
03
02
01
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
04
ANGLES
.XX: .01 [.3]
5
.XXX: .003 [.08]
.XXXX: .0015 [.038]
MATERIAL:
05
DETAIL 'H'
SCALE 15 : 1
'H'
.070
SECTION "A"-"A"
16
30°
(TYP)
PARTING LINE
.100
'D'
SEE NOTE 3
.045
.480 - .002
"B"
SEE NOTE 2
OPTION
-R: RETENTION LATCH
(SEE SHEET 3, FIG 3)
(SEE NOTE 16)
-K: KEYED POLARIZATION
(SEE FIG. 5 & 6,
SHEET 4)
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 1.5:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
VALOX 457, COLOR NATURAL
MAX REGRIND: 0%
MAX FLASH ALLOWED: .003
MAX GATE VESTIGE: .004
F:\DWG\MISC\MKTG\IPBD-XX-D-X-MKT.SLDDRW
DWG. NO.
.165 SHROUDED CONTACT BODY
IPBD-XX-D-X
BY: DEAN P
10-24-2001
SHEET 1 OF 4
REVISION X
.0250 X 45
(3 PLCS, EACH END)
.0100 (TYP)
.083 REF
.100
.0165 (TYP)
.115±.002
CL
.035
+.004
.049±.003
R.025±.005
.190
.100 - .000
30°
(TYP)
.1320 SQ
(TYP)
DETAIL 'D'
SCALE 5 : 1
.250
.330±.005
.0860 (4 PLCS)
.1520 (4 PLCS)
DETAIL 'A'
SCALE 3 : 1
DETAIL 'B'
SCALE 5 : 1
DETAIL 'C'
SCALE 5 : 1
30
(TYP)
+.0060
.1400 - .0000
+.004
FIG 2
.035 - .002
.113±.004
-02 POSITION
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
+.006
.142 - .000
+.003
.098 - .002
34°
.055
.0830
SQ (TYP)
.076
.1100
.2000
SEE NOTE 8
DETAIL 'F'
SCALE 5 : 1
R.025
(TYP)
01
.490
+.005
.006±.002
DETAIL 'G'
SCALE 5 : 1
.085
.525
.225±.0100
.05
PROPRIETARY NOTE
DETAIL 'E
SCALE 3 : 1
SHEET SCALE: 1.5:1
.110±.002
.040 - .002
.200
.120±.004
(SEE NOTE 15)
.030
(SEE NOTE 14)
02
.055
(TYP)
.088±.002 SQ
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPBD-XX-D-X
BY: DEAN P
10-24-2001
SHEET 2 OF 4
FIG 3
REVISION X
(IPBD-08-D-R SHOWN)
(SEE NOTE 16)
FIG 4
(IPBD-02-D-R SHOWN)
(SAME AS FIG 3, UNLESS OTHERWISE STATED)
(SEE NOTE 16)
.017±.001
"M"
+.000
.025 - .001
.077
.110±.001
.150
.2000
.0220
R.0550
SEE NOTE 8
"M"
.230
02
"N"
.490
SECTION "M"-"M"
SCALE 4 : 1
.355
"N"
01
'P'
.1600±.0010
.1700±.0010
.1800±.0010
.0085 X 45°
GATE PAD GROOVES
SEE SHEET 1
R.005 (TYP)
PROPRIETARY NOTE
.035
SECTION "N"-"N"
SCALE 6 : 1
.040
.065
.070
DETAIL 'P'
SCALE 20 : 1
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPBD-XX-D-X
BY: DEAN P
10-24-2001
SHEET 3 OF 4
REVISION X
FIG 5
(IPBD-05-D-K SHOWN)
(TYPICAL FOR POSITIONS 3 THRU 15)
"Q"
02
01
06
"Q"
SECTION "Q"-"Q"
SCALE 2.5 : 1
FIG 6
(IPBD-02-D-K SHOWN)
(SAME AS FIG 5, UNLESS OTHERWISE STATED)
"R"
02
01
03
"R"
PROPRIETARY NOTE
.040
SECTION "R"-"R"
SCALE 2.5 : 1
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPBD-XX-D-X
BY: DEAN P
10-24-2001
SHEET 4 OF 4
很抱歉,暂时无法提供与“IPBD-02-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.450521+0.44664
- 国内价格
- 1+2.93760
- 10+2.86200
- 30+2.81880
- 100+2.77560
