DF3-9S-2C
DF3-9S-2C
    HRS(广濑)
    p=2mm
    CONN RECEPT HOUSING 9POS 2MM
DF3-9S-2C 数据手册
Applicable standard Operating temperature range Operating humidity range Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. Storage temperature range Storage humidity range Applicable cable 3 -55C to + 105C(Note 1) △ 40% to + 80%(Note 2) DF3-22SC* DF3-2428SC* Applicable contact Rating Voltage 250V AC AWG 22 to 24 : 3A AWG 26 : 2A AWG 28 : 1A Current UL・CSA Rating -10C to + 60C(Note 3) 40% to + 70%(Note 3) UL1007 AWG24 to 28 UL1061 AWG22 to 28 Voltage 30V AC Current AWG 24 : 3A AWG 26 : 2A AWG 28 : 1A Specifications Item Test method Requirements QT AT X X X X X - X - X - X - X - Construction General examination Visually and by measuring instrument. Marking Confirmed visually. According to drawing. Electric characteristics Insulation resistance 500V DC. Voltage proof 650V AC for 1 min. 1000M MIN. No flashover or breakdown. Mechanical characteristics Mechanical operation 30 times insertions and extractions. ① No damage, crack or looseness of parts. Vibration Frequency 10 to 55 Hz, single amplitude 0.75 mm, at 2 h, for 3 directions. ① No damage, crack or looseness of parts. 2 Shock 490 m/s duration of pulse 11 ms at 3 times for 3 directions. ① No damage, crack or looseness of parts. Environmental characteristics Rapid change of temperature Temperature -55→ 5 to 35→ 85→ 5 to 35 c Time 30→ 5MAX → 30→ 5MAX min Under 5 cycles. ① Insulation resistance: 1000M MIN. ② No damage, crack or looseness of parts. X - Damp heat (Steady state) Exposed at 40 ± 2 c, 90 to 95 , 96 h. ① Insulation resistance: 500M MIN. ② No damage, crack or looseness of parts. X - Remarks Note 1:Including the temperature rise by current Note 2:No condensing. Note 3:Apply to the condition of long term storage for unused products before pcb on board, after pcb board, operating temperature and humidity range is applied for interim storage during transportation. Count Description of revisions Designed Checked Date 1 DIS-H-00003625 TO.KUROMATSU HS.OKAWA 18.03.09 △ Unless otherwise specified , refer to IEC 60512. 3 Note QT:Qualification Test AT:Assurance Test X:Applicable Test FORM HD0011-2-1 Approved KJ.KATAYOSE 05.01.05 Checked KI.AKIYAMA 05.01.05 Designed TH.ARAI 05.01.05 Drawn TH.ARAI 05.01.05 Drawing no. Specification sheet Part no. Hirose electric co., ltd. Code no. ELC-162387-00-01 DF3-*S-2C CL543- 3 △ 1/1
DF3-9S-2C
PDF文档中包含以下信息:
1. 物料型号:型号为“LM324”,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的四运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,其他引脚包括电源和接地。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM324可以进行加法、减法、积分、微分等模拟信号处理。
6. 应用信息:适用于音频放大、传感器信号调理、滤波器设计等。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
DF3-9S-2C 价格&库存
很抱歉,暂时无法提供与“DF3-9S-2C”相匹配的价格&库存,您可以联系我们找货
DF3-9S-2C
    • 1+0.47970
    库存:225
    DF3-9S-2C
      • 1+1.33170
      • 5+1.32282
      • 50+0.96771
      • 192+0.90556
      库存:246
      DF3-9S-2C
        • 50+0.92332
        库存:50
        DF3-9S-2C
          • 100+0.72060100+0.08614
          • 500+0.69181500+0.08270
          • 2000+0.667672000+0.07981
          • 5000+0.652815000+0.07804
          • 12500+0.6231012500+0.07449
          库存:1000
          DF3-9S-2C
            • 200+0.51352200+0.06139
            • 1000+0.494951000+0.05917
            • 3000+0.482883000+0.05772
            • 12500+0.4670912500+0.05584
            • 30000+0.4457330000+0.05328
            库存:5000
