IPBD-02-D-K
IPBD-02-D-K
    SAMTEC(申泰)
    2X2P 4.19MM
IPBD-02-D-K 数据手册
REVISION X IPBD-XX-D-X ((No OF POSITIONS x .1650) + .0400) .012 .002 .060 DO NOT SCALE FROM THIS PRINT No OF POSITIONS -02 THRU -15 (PER ROW) [SEE FIG. 2 FOR -02 POSITION] .095±.010 .075±.010 .485 .15 .100 (NO DRAFT) ROW SPECIFICATION -D: DOUBLE .773±.006 NOTES: 1. REPRESENTS A CRITICAL DIMENSION. 2. SAMTEC LOGO SHALL APPEAR AT ONE LOCATION ON SURFACE SHOWN, APPROXIMATELY .15 x .09 (BOTH SIDES). 3. ALL MULTIPLE CAVITY MOLDS SHALL IDENTIFY EACH CAVITY WITH TOOL DEPENDANT CAVITY ID AT THE DISCRETION OF SAMTEC ENGINEERING. 4. ALL IDENTIFICATION MARKS MUST NOT STAND GREATER THAN .002 OFF THE SURFACE OF THE PART. 5. MOLDED SURFACES SHALL BE CONSISTENT AND SMOOTH. SURFACES TO BE FREE OF SCATCHES, NICKS, SINK AREAS, VOIDS OR OTHER BLEMISHES. 6. MAX ALLOWABLE BOW: SEE TABLE 1. 7. PART TO BE SYMMETRIC ABOUT THE CENTERLINE WITHIN +/-.001, UNLESS OTHERWISE STATED. 8. NUMBER OF POSITIONS (PER ROW) TO BE SHOWN ON THIS SURFACE, SIZE AND DEPTH SIMILAR TO POSITION 1INDICATOR. 9. GATE PAD MUST BE RECESSED .005. GATE LOCATION IS AT THE MOLDERS DISCRETION. 10. END CORES ARE POLARIZED. CONFIRM GEOMETRY RELATIVE TO POSITION 1 INDICATOR & GATE PAD. 11. POSITION 1 INDICATOR TO BE .0005 MAX DEPTH. 12. EACH POSITION TO BE IDENTIFIED WHERE SHOWN. 13. .0005 MAX MISMATCH PERMISSIBLE (ALL FOUR SIDES). 14. LATCH MUST CYCLE 10 TIMES WITHOUT EVIDENCE OF CRACKING OR COMPROMISE OF FUNCTION. 15. CHECK THIS FEATURE WITH GO/NOGO GAUGE. 16. OPTION NOT FOR SALE. FOR RETENTION LATCH FEATURE, SEE IPBD-XX-D-ML PRINT. 17. POSITION INDICATOR NOT PRESENT ON 2 & 3 POSITION -R OPTION BODIES. SEE NOTE 11 ((No OF POSITIONS -1) x .1650) .0050 .0050 .1025±.0020 'G' +.0075 .478 - .0000 01 02 S/S BOW SEE TABLE 1 "A" +.0015 .1650 - .0050 09 "A" .378 'B' 'A' FIG 1 1 MAX DRAFT (TYP) IPBD-08-D SHOWN "B" 1 MAX DRAFT (TYP) 'E SEE NOTE 13 'C' SEE NOTE 8 +.005 .280 T/B BOW SEE TABLE 1 SECTION "B"-"B" SEE NOTE 12 'F' 15 14 08 07 06 11 10 09 03 02 01 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS 04 ANGLES .XX: .01 [.3] 5 .XXX: .003 [.08] .XXXX: .0015 [.038] MATERIAL: 05 DETAIL 'H' SCALE 15 : 1 'H' .070 SECTION "A"-"A" 16 30° (TYP) PARTING LINE .100 'D' SEE NOTE 3 .045 .480 - .002 "B" SEE NOTE 2 OPTION -R: RETENTION LATCH (SEE SHEET 3, FIG 3) (SEE NOTE 16) -K: KEYED POLARIZATION (SEE FIG. 5 & 6, SHEET 4) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: VALOX 457, COLOR NATURAL MAX REGRIND: 0% MAX FLASH ALLOWED: .003 MAX GATE VESTIGE: .004 F:\DWG\MISC\MKTG\IPBD-XX-D-X-MKT.SLDDRW DWG. NO. .165 SHROUDED CONTACT BODY IPBD-XX-D-X BY: DEAN P 10-24-2001 SHEET 1 OF 4 REVISION X .0250 X 45 (3 PLCS, EACH END) .0100 (TYP) .083 REF .100 .0165 (TYP) .115±.002 CL .035 +.004 .049±.003 R.025±.005 .190 .100 - .000 30° (TYP) .1320 SQ (TYP) DETAIL 'D' SCALE 5 : 1 .250 .330±.005 .0860 (4 PLCS) .1520 (4 PLCS) DETAIL 'A' SCALE 3 : 1 DETAIL 'B' SCALE 5 : 1 DETAIL 'C' SCALE 5 : 1 30 (TYP) +.0060 .1400 - .0000 +.004 FIG 2 .035 - .002 .113±.004 -02 POSITION (SAME AS FIG 1, UNLESS OTHERWISE STATED) +.006 .142 - .000 +.003 .098 - .002 34° .055 .0830 SQ (TYP) .076 .1100 .2000 SEE NOTE 8 DETAIL 'F' SCALE 5 : 1 R.025 (TYP) 01 .490 +.005 .006±.002 DETAIL 'G' SCALE 5 : 1 .085 .525 .225±.0100 .05 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING DETAIL 'E SCALE 3 : 1 SHEET SCALE: 1.5:1 F:\DWG\MISC\MKTG\IPBD-XX-D-X-MKT.SLDDRW .110±.002 .040 - .002 .200 .120±.004 (SEE NOTE 15) .030 (SEE NOTE 14) 02 .055 (TYP) .088±.002 SQ 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 SHROUDED CONTACT BODY IPBD-XX-D-X BY: DEAN P 10-24-2001 SHEET 2 OF 4 FIG 3 REVISION X (IPBD-08-D-R SHOWN) (SAME AS FIG 1, UNLESS OTHERWISE STATED) (SEE NOTE 16) FIG 4 (IPBD-02-D-R SHOWN) (SAME AS FIG 3, UNLESS OTHERWISE STATED) (SEE NOTE 16) .017±.001 "M" +.000 .025 - .001 .077 .110±.001 .150 .2000 .0220 R.0550 SEE NOTE 8 "M" .230 02 "N" .490 SECTION "M"-"M" SCALE 4 : 1 .355 "N" 01 'P' .1600±.0010 .1700±.0010 .1800±.0010 .0085 X 45° GATE PAD GROOVES SEE SHEET 1 R.005 (TYP) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. .035 SECTION "N"-"N" SCALE 6 : 1 .040 .065 .070 DETAIL 'P' SCALE 20 : 1 F:\DWG\MISC\MKTG\IPBD-XX-D-X-MKT.SLDDRW DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 SHROUDED CONTACT BODY IPBD-XX-D-X BY: DEAN P 10-24-2001 SHEET 3 OF 4 REVISION X FIG 5 (IPBD-05-D-K SHOWN) (SAME AS FIG 1, UNLESS OTHERWISE STATED) (TYPICAL FOR POSITIONS 3 THRU 15) "Q" 02 01 06 "Q" SECTION "Q"-"Q" SCALE 2.5 : 1 FIG 6 (IPBD-02-D-K SHOWN) (SAME AS FIG 5, UNLESS OTHERWISE STATED) "R" 02 01 03 "R" PROPRIETARY NOTE .040 SECTION "R"-"R" SCALE 2.5 : 1 THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\IPBD-XX-D-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 SHROUDED CONTACT BODY IPBD-XX-D-X BY: DEAN P 10-24-2001 SHEET 4 OF 4
IPBD-02-D-K 价格&库存
很抱歉,暂时无法提供与“IPBD-02-D-K”相匹配的价格&库存,您可以联系我们找货
IPBD-02-D-K
    • 1+3.39120
    • 10+3.31560
    • 30+3.26160
    • 100+3.20760
    库存:109
