560-002-000-211
560-002-000-211
560-002-000-211 数据手册
560 SERIES WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS Features: • • • • • • • • • • 2.5mm pitch, rated current: 3A max Fully waterproof with double latch solution Available in wire to wire and wire to board options Seals preassembled into housing; no external sealing required Available in 2, 3, or 5 positions True crimp and poke solution Waterproofing cap available to cover unused positions Internal polarization to prevent mismating Available with wire already installed Waterproof Grade: IP67 Certified Specifications: No. of Positions 2, 3, 5 Pitch 2.5 mm Rated Voltage 250 V Rated Current 3 amps maximum Dielectric Withstanding Voltage 1000 V AC (rms) Contact Resistance 15 milliohms maximum Insulation Resistance 1000 megaohms minimum/DC 500 V Operating Temperature -40°C to +105°C PCB Thickness 1.6 mm Ordering Code: Crimp Contact: SERIES: 560, WIRE TO WIRE WIRE TO BOARD NO. OF CONTACTS: 002 - 2 CONTACTS 003 - 3 CONTACTS 005 - 5 CONTACTS CONTACT CODE: 000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS) 420 - BOARD MOUNT CONTACTS STYLE: 101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 110 - WHITE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 310 - BLUE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.3 111 - WHITE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 311 - BLUE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 210 - WHITE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 410 - BLUE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30 211 - WHITE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 411 - BLUE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70 Male Contact (Pin) Female Contact (Socket) Part No AWG# Ins. Dia. Pcs/Reel Part No AWG# Ins. Dia. Pcs/Reel 565-290-731 20-22 Max. Ø1.7 8,000 565-290-741 20-22 Max. Ø1.7 8,000 565-290-711 22-28 Max. Ø1.6 8,000 565-290-721 22-28 Max. Ø1.6 10,000 **Crimp Contacts are also available in strips of 60pcs. Contact EDAC for more information. **Wire seals, housing seals and retainers are already pre-assembled in the connector. Materials: Crimp & Poke PCB Header Housing PBT, UL 94V-0 Contact Phosphor Bronze Housing PBT with Glass, UL 94V-0 Contact Brass Contact Plating Tin Plating Wire & Housing Seals Silicone Rubber Waterproofing Cap PBT, UL 94V-0 Rear Gasket (Wire Seal): Assembly Layout: 28.40 Applicable Contact: Wire O.D.: Color: 565-290-711 565-290-721 Ø1.00 to Ø1.30 Yellow 565-290-731 565-290-741 Ø1.30 to Ø1.70 Orange Waterproofing Cap: 20.85 Part No.: Double Latch 565-200-100 www.edac.net customerservice@edac.net 560 SERIES WIRE TO WIRE / WIRE TO BOARD 2.5MM PITCH Female Housing: PCB Header 560-002-000-XXX 560-002-000-XXX 560-002-420-XXX 560-003-000-XXX 560-003-000-XXX 560-003-420-XXX 560-005-000-XXX 560-005-000-XXX 560-005-420-XXX Male Housing: Male Housing: Female Housing: PCB Header: Ø Wire Insulation: Housing Color: XXX: Ø Wire Insulation: Housing Color: XXX: Housing Color: XXX: Ø1.00 to Ø1.30 White 110 Ø1.00 to Ø1.30 White 210 White 101 Blue 310 Blue 410 Blue 301 White 111 White 211 Blue 311 Blue 411 Ø1.30 to Ø1.70 Ø1.30 to Ø1.70 NOTE: Waterproofing Cap is installed at the wire seal end to cover the unused holes. Waterproofing Cap www.edac.net customerservice@edac.net 560 SERIES WIRE TO WIRE / WIRE TO BOARD 2.5MM PITCH www.edac.net customerservice@edac.net
560-002-000-211 价格&库存
很抱歉,暂时无法提供与“560-002-000-211”相匹配的价格&库存,您可以联系我们找货
