572-002-000-100
572-002-000-100
572-002-000-100 数据手册
572 SERIES WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS Features: • • • • • • • • • 5.8mm pitch, rated current: 10A max Fully waterproof with double latch solution Available in wire to wire and wire to board options Available in 1, 2, or 3 positions True crimp and poke solution Internal polarization to prevent mismating Available with wire already installed Wide range of wire sizes available Waterproof Grade: IP67 Certified Specifications: No. of Positions 1, 2, 3 Pitch 5.8 mm Rated Voltage 300 V Rated Current 10 amps maximum Withstanding Voltage 1700 V AC (rms) Contact Resistance 10 milliohms maximum Insulation Resistance 1000 megaohms minimum/DC 500 V Operating Temperature -40°C to +105°C PCB Thickness 1.6 mm Ordering Code: Crimp Contact: 572-002-000-100 Male Contact (Pin) SERIES: 572, WIRE TO WIRE WIRE TO BOARD NO. OF CONTACTS: 001 - 1 CONTACT 002 - 2 CONTACTS 003 - 3 CONTACTS CONTACT CODE: 000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS) 420 - BOARD MOUNT CONTACTS AWG# Ins. Dia. Pcs/Reel Part No (Material) AWG# Ins. Dia. Pcs/Reel 570-290-751 (Brass) 14 Max. Ø3.1 4,000 570-290-761 (Brass) 14 Max. Ø3.1 4,000 570-291-731 (Ph. Brz.) 20-16 Max. Ø3.1 4,000 570-291-741 (Ph. Brz.) 20-16 Max. Ø3.1 4,000 570-290-741 (Brass) 20-16 Max. Ø3.1 4,000 570-290-731 (Brass) 20-16 Max. Ø3.1 4,000 570-291-721 (Ph. Brz.) 22-20 Max. Ø2.7 4,000 570-290-721 (Brass) 22-20 Max. Ø2.7 4,000 Max. Ø2.7 4,000 570-290-711 (Brass) STYLE: 101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 100 - WHITE MALE HOUSING FOR CRIMP CONTACTS 300 - BLUE MALE HOUSING FOR CRIMP CONTACTS 200 - WHITE FEMALE HOUSING FOR CRIMP CONTACTS 400 - BLUE FEMALE HOUSING FOR CRIMP CONTACTS Female Contact (Socket) Part No (Material) 22-20 Materials: Crimp & Poke PCB Header Housing PBT, UL 94V-0 Contact Ph. Brz. or Brass Housing PBT with Glass, UL 94V-0 Contact Brass Assembly Layout: 47.0 Contact Plating Tin Plating Wire & Housing Seals Silicone Rubber Wire Seal: Wire O.D. Color AWG# Ø Dia. Height 570-260-001 Ø1.7~Ø2.1 Black 22 Ø 5.0 6.0 570-260-002 Ø2.1~Ø2.7 Light Blue 22-20 Ø 5.0 6.0 570-260-003 Ø2.1~Ø2.7 Blue 22-20 Ø 5.0 6.7 570-260-004 Ø2.7~Ø3.1 Brown 20-14 Ø 4.9 5.0 www.edac.net 570-260-002 Double Latch 570-260-004 30.5 Part No. 570-260-001 570-260-003 customerservice@edac.net 572 SERIES WIRE TO WIRE / WIRE TO BOARD 5.8MM PITCH Male Housing: Female Housing: PCB Header 572-002-000-XXX 572-002-000-XXX 572-002-420-XXX 572-003-000-XXX 572-003-000-XXX 572-003-420-XXX 572-005-000-XXX 572-005-000-XXX 572-005-420-XXX Male Housing: Female Housing: PCB Header: Housing Color: XXX: Housing Color: YYY: Housing Color: XXX: White 100 White 200 White 101 Blue 300 Blue 400 Blue 301 www.edac.net customerservice@edac.net 572 SERIES WIRE TO WIRE / WIRE TO BOARD 5.8MM PITCH Recommended PCB Layout www.edac.net customerservice@edac.net
572-002-000-100 价格&库存
很抱歉,暂时无法提供与“572-002-000-100”相匹配的价格&库存,您可以联系我们找货
    • 10+9.23812
    库存:1270
