IPM1-02-D
IPM1-02-D
    SAMTEC(申泰)
    IPM1-02-D
IPM1-02-D 数据手册
IPM1-XX-X-XX REVISION F DO NOT SCALE FROM THIS PRINT .100 (4 PLCS) .08 (TYP) "A" (2 PLCS) .080 ROW SPECIFICATION -D: DOUBLE -S: SINGLE (SEE SHT 3, FIG 2 & 3) .1020 (TYP) .0450 FIG 1 .035±.010 .1099 (TYP) IPM1-06-D SHOWN .120 OPTIONS (LEAVE BLANK FOR NO OPTIONS) -GP: GUIDE POST (SEE SHT 4, FIG 5) (ONLY AVAILABLE ON DOUBLE ROW) *-SF: SPLASH FLANGE (COLOR: BLACK; -03, -04, & -05 TOOLED ONLY; NOT AVAILABE WITH -S OR -GP) No OF POSITIONS -02 THRU -25 (PER ROW) .050 (2 PLCS) POSITION 1 INDICATOR TO BE RAISED .005 MAX 'F' SEE NOTE 2 ((NO OF POS -1) X .100)±.002 C2 01 'E' +.000 "B" ((NO OF POS X .100) + .070) - .008 C3 "G" 02 "A" C1 .258 .215 .1000 C4 "A" .045 'H' .021 (TYP) "B" .1000 (TYP) [TOL NON-ACCUM] "G" C5 SEE NOTE 8 SHOW NUMBER OF POSITIONS ON THIS SURFACE (SEE NOTE 8) .05 (2 PLCS) .100±.002 .5° (TYP) CL +.006 'C' .05 SECTION "A"-"A" SCALE 2 : 1 POSITION 1 INDICATOR TO BE RECESSED .0005 MAX +.006 .350 - .003 SEE NOTE 11 1. C REPRESENTS A CRITICAL DIMENSION. 2. SAMTEC LOGO SHALL APPEAR AT TWO EQUALLY SPACED LOCATIONS ON SURFACE SHOWN, APPROXIMATELY .094[2.39] x .055[1.40]. 3. ALL MULTIPLE CAVITY MOLDS SHALL IDENTIFY EACH CAVITY WITH A DOT DESIGNATION LOCATED WHERE SHOWN. 4. ALL IDENTIFICATION MARKS MUST NOT STAND GREATER THAN .002[0.05] OFF THE SURFACE OF THE PART. 5. MOLDED SURFACES SHALL BE CONSISTENT AND SMOOTH. SURFACES TO BE FREE OF SCRATCHES, NICKS, SINK AREAS, VOIDS OR OTHER BLEMISHES. 6. MAXIMUM ALLOWABLE BOW; TOP/BOTTOM: .0025[0.064], SIDE/SIDE: .0020[0.051]. 7. PART TO BE SYMMETRIC ABOUT CENTERLINE WITHIN ±.002 UNLESS INDICATED OTHERWISE. 8. NUMBER OF POSITIONS (PER ROW) TO BE SHOWN IN THIS AREA EXCLUDING 2, 3, & 4 POSITIONS. SIZE SIMILAR TO POSITION 1 INDICATOR. 9. GATE PADS MUST BE RECESSED .005. 10. END CORES ARE POLARIZED. CONFIRM GEOMETRY RELATIVE TO POSITION 1 INDICATOR & GATE PADS. 11. END POSITIONS TO BE SPECIFIED WHERE SHOWN. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS 07 12 01 06 .XX: .01 .XXX: .003 .XXXX: .0015 MATERIAL: SEE NOTE 3 .102 (TYP) SECTION "B"-"B" SCALE 3 : 1 NOTES: .690 - .004 SEE NOTE 9 ANGLES 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING ZYTEL PA66 101F, COLOR: WHITE -SF: BLACK MAX REGRIND: 25% MAX FLASH ALLOWED: .004 MAX GATE VESTIGE: .002 F:\DWG\MISC\MKTG\IPM1-XX-X-XX-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 SHROUDED TERMINAL CABLE END DWG. NO. IPM1-XX-X-XX BY: D. SCHMELZ 12/04/2008 SHEET 1 OF 4 REVISION F .0350 .028 C6 C7 .0820 (TYP) .065 .0899 (TYP) .075 2° (TYP) .0530 30° (TYP) .050 .015 .120 .130 C8 .225 'D' .006 X 75° (TYP) .076 30° DETAIL 'D' SCALE 8 : 1 .0760 (TYP) C13 .335 2° .023 .0349 .079 DETAIL 'C' SCALE 4 : 1 .0350 .035 .0350 C9 DETAIL 'H' SCALE 8 : 1 +.000 .098 - .003 20° .023 * .006 C10 .0360 .040 DETAIL 'F' SCALE 8 : 1 SECTION "G"-"G" SCALE 4 : 1 PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\IPM1-XX-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 SHROUDED TERMINAL CABLE END DWG. NO. IPM1-XX-X-XX BY: D. SCHMELZ 12/04/2008 SHEET 2 OF 4 .040 REVISION F +.006 .300 - .003 .200 .0349 "J" 2° C11 'K' .003 (TYP) "J" CL FIG 2 IPM1-06-S SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "L" .0100 DETAIL 'K' SCALE 12 : 1 SECTION "J"-"J" SCALE 5 : 1 2° (TYP) .040 (TYP) .006 .250 .304 .258 "L" .0360 .0350 (TYP) 'M' C12 DETAIL 'M' SCALE 6 : 1 SECTION "L"-"L" SCALE 3 : 1 F:\DWG\MISC\MKTG\IPM1-XX-X-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 3 APPLIES TO -02 & -03 POSITIONS ONLY IPM1-02-S SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) FIG 4 APPLIES TO -02 & -03 POSITIONS ONLY IPM1-02-D SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 SHROUDED TERMINAL CABLE END DWG. NO. IPM1-XX-X-XX BY: D. SCHMELZ 12/04/2008 SHEET 3 OF 4 REVISION F 01 02 "N" "N" 'P' 07 .065 .005 X 44° 45° DETAIL 'P' SCALE 6 : 1 SECTION "N"-"N" SCALE 3 : 1 .035 (2 PLCS) FIG 5 FIG 6 IPM1-06-D-GP SHOWN (SAME AS FIG 1, UNLESS OTHERWISE STATED) (ONLY AVAILABLE ON DOUBLE ROW) *IPM1-05-D-SF SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (-03, -04, & -05 TOOLED ONLY, *NOT RELEASED FOR PRODUCTION) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .100 SHROUDED TERMINAL CABLE END DWG. NO. F:\DWG\MISC\MKTG\IPM1-XX-X-XX-MKT.SLDDRW IPM1-XX-X-XX BY: D. SCHMELZ 12/04/2008 SHEET 4 OF 4
IPM1-02-D 价格&库存
很抱歉,暂时无法提供与“IPM1-02-D”相匹配的价格&库存,您可以联系我们找货
