IPM1-XX-X-XX
REVISION F
DO NOT
SCALE FROM
THIS PRINT
.100 (4 PLCS)
.08 (TYP)
"A"
(2 PLCS)
.080
ROW SPECIFICATION
-D: DOUBLE
-S: SINGLE (SEE SHT 3, FIG 2 & 3)
.1020
(TYP)
.0450
FIG 1
.035±.010
.1099 (TYP)
IPM1-06-D SHOWN
.120
OPTIONS
(LEAVE BLANK FOR NO OPTIONS)
-GP: GUIDE POST (SEE SHT 4, FIG 5)
(ONLY AVAILABLE ON DOUBLE ROW)
*-SF: SPLASH FLANGE
(COLOR: BLACK;
-03, -04, & -05 TOOLED ONLY;
NOT AVAILABE WITH -S OR -GP)
No OF POSITIONS
-02 THRU -25
(PER ROW)
.050 (2 PLCS)
POSITION 1
INDICATOR TO BE
RAISED .005 MAX
'F'
SEE NOTE 2
((NO OF POS -1) X .100)±.002 C2
01
'E'
+.000
"B"
((NO OF POS X .100) + .070) - .008 C3
"G"
02
"A"
C1
.258
.215
.1000 C4
"A"
.045
'H'
.021
(TYP)
"B"
.1000 (TYP)
[TOL NON-ACCUM]
"G"
C5
SEE NOTE 8
SHOW NUMBER OF POSITIONS
ON THIS SURFACE (SEE NOTE 8)
.05 (2 PLCS)
.100±.002
.5°
(TYP)
CL
+.006
'C'
.05
SECTION "A"-"A"
SCALE 2 : 1
POSITION 1
INDICATOR TO BE
RECESSED .0005 MAX
+.006
.350 - .003
SEE NOTE 11
1. C REPRESENTS A CRITICAL DIMENSION.
2. SAMTEC LOGO SHALL APPEAR AT TWO EQUALLY SPACED LOCATIONS ON
SURFACE SHOWN, APPROXIMATELY .094[2.39] x .055[1.40].
3. ALL MULTIPLE CAVITY MOLDS SHALL IDENTIFY EACH CAVITY WITH A DOT
DESIGNATION LOCATED WHERE SHOWN.
4. ALL IDENTIFICATION MARKS MUST NOT STAND GREATER THAN .002[0.05] OFF THE
SURFACE OF THE PART.
5. MOLDED SURFACES SHALL BE CONSISTENT AND SMOOTH. SURFACES TO BE
FREE OF SCRATCHES, NICKS, SINK AREAS, VOIDS OR OTHER BLEMISHES.
6. MAXIMUM ALLOWABLE BOW; TOP/BOTTOM: .0025[0.064], SIDE/SIDE: .0020[0.051].
7. PART TO BE SYMMETRIC ABOUT CENTERLINE WITHIN ±.002 UNLESS INDICATED OTHERWISE.
8. NUMBER OF POSITIONS (PER ROW) TO BE SHOWN IN THIS AREA EXCLUDING 2, 3, & 4 POSITIONS.
SIZE SIMILAR TO POSITION 1 INDICATOR.
9. GATE PADS MUST BE RECESSED .005.
10. END CORES ARE POLARIZED. CONFIRM GEOMETRY RELATIVE TO POSITION 1 INDICATOR & GATE PADS.
11. END POSITIONS TO BE SPECIFIED WHERE SHOWN.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
07
12
01
06
.XX: .01
.XXX: .003
.XXXX: .0015
MATERIAL:
SEE NOTE 3
.102 (TYP)
SECTION "B"-"B"
SCALE 3 : 1
NOTES:
.690 - .004
SEE NOTE 9
ANGLES
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
ZYTEL PA66 101F, COLOR: WHITE
-SF: BLACK
MAX REGRIND: 25%
MAX FLASH ALLOWED: .004
MAX GATE VESTIGE: .002
F:\DWG\MISC\MKTG\IPM1-XX-X-XX-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.100 SHROUDED TERMINAL CABLE END
DWG. NO.
IPM1-XX-X-XX
BY: D. SCHMELZ
12/04/2008 SHEET 1 OF 4
REVISION F
.0350
.028
C6
C7 .0820 (TYP)
.065
.0899 (TYP)
.075
2° (TYP)
.0530
30° (TYP)
.050
.015
.120
.130
C8 .225
'D'
.006 X 75°
(TYP)
.076
30°
DETAIL 'D'
SCALE 8 : 1
.0760
(TYP)
C13
.335
2°
.023
.0349
.079
DETAIL 'C'
SCALE 4 : 1
.0350
.035
.0350
C9
DETAIL 'H'
SCALE 8 : 1
+.000
.098 - .003
20°
.023
.006
C10 .0360
.040
DETAIL 'F'
SCALE 8 : 1
SECTION "G"-"G"
SCALE 4 : 1
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPM1-XX-X-XX
BY: D. SCHMELZ
12/04/2008 SHEET 2 OF 4
.040
REVISION F
+.006
.300 - .003 .200
.0349
"J"
2°
C11
'K'
.003
(TYP)
"J"
CL
FIG 2
IPM1-06-S SHOWN
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
"L"
.0100
DETAIL 'K'
SCALE 12 : 1
SECTION "J"-"J"
SCALE 5 : 1
2° (TYP)
.040 (TYP)
.006
.250
.304
.258
"L"
.0360
.0350
(TYP)
'M'
C12
DETAIL 'M'
SCALE 6 : 1
SECTION "L"-"L"
SCALE 3 : 1
PROPRIETARY NOTE
FIG 3
APPLIES TO -02 & -03 POSITIONS ONLY
IPM1-02-S SHOWN
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2)
FIG 4
IPM1-02-D SHOWN
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPM1-XX-X-XX
BY: D. SCHMELZ 12/04/2008
SHEET 3 OF 4
REVISION F
01
02
"N"
"N"
'P'
07
.065
.005 X 44°
45°
DETAIL 'P'
SCALE 6 : 1
SECTION "N"-"N"
SCALE 3 : 1
.035 (2 PLCS)
FIG 5
FIG 6
IPM1-06-D-GP SHOWN
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
*IPM1-05-D-SF SHOWN
(-03, -04, & -05 TOOLED ONLY, *NOT RELEASED FOR PRODUCTION)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPM1-XX-X-XX
BY: D. SCHMELZ 12/04/2008 SHEET 4 OF 4
