560 SERIES
WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS
Features:
2.5mm pitch, rated current: 3A max
Fully waterproof with double latch solution
Available in wire to wire and wire to board options
Seals preassembled into housing; no external sealing required
Available in 2, 3, or 5 positions
True crimp and poke solution
Waterproofing cap available to cover unused positions
Internal polarization to prevent mismating
Available with wire already installed
Waterproof Grade: IP67 Certified
Specifications:
No. of Positions
2, 3, 5
Pitch
2.5 mm
Rated Voltage
250 V
Rated Current
3 amps maximum
Dielectric Withstanding Voltage
1000 V AC (rms)
Contact Resistance
15 milliohms maximum
Insulation Resistance
1000 megaohms minimum/DC 500 V
Operating Temperature
-40°C to +105°C
PCB Thickness
1.6 mm
Ordering Code:
Crimp Contact:
SERIES:
560, WIRE TO WIRE
WIRE TO BOARD
NO. OF CONTACTS:
002 - 2 CONTACTS
003 - 3 CONTACTS
005 - 5 CONTACTS
CONTACT CODE:
000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS)
420 - BOARD MOUNT CONTACTS
STYLE:
101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
110 - WHITE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30
310 - BLUE MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.3
111 - WHITE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70
311 - BLUE MALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70
210 - WHITE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30
410 - BLUE FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.30
211 - WHITE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70
411 - BLUE FEMALE HOUSING FOR WIRE INSULATION Ø1.30 TO Ø1.70
Male Contact (Pin)
Female Contact (Socket)
Part No
AWG#
Ins. Dia.
Pcs/Reel
Part No
AWG#
Ins. Dia.
Pcs/Reel
565-290-731
20-22
Max. Ø1.7
8,000
565-290-741
20-22
Max. Ø1.7
8,000
565-290-711
22-28
Max. Ø1.6
8,000
565-290-721
22-28
Max. Ø1.6
10,000
**Crimp Contacts are also available in strips of 60pcs.
Contact EDAC for more information.
**Wire seals, housing seals and retainers are already
pre-assembled in the connector.
Materials:
Crimp & Poke
PCB Header
Housing
PBT, UL 94V-0
Contact
Phosphor Bronze
Housing
PBT with Glass, UL
94V-0
Contact
Brass
Contact Plating
Tin Plating
Wire & Housing Seals
Silicone Rubber
Waterproofing Cap
PBT, UL 94V-0
Rear Gasket (Wire Seal):
Assembly Layout:
28.40
Applicable Contact:
Wire O.D.:
Color:
565-290-711
565-290-721
Ø1.00 to Ø1.30
Yellow
565-290-731
565-290-741
Ø1.30 to Ø1.70
Orange
Waterproofing Cap:
20.85
Part No.:
Double Latch
565-200-100
www.edac.net
customerservice@edac.net
560 SERIES
WIRE TO WIRE / WIRE TO BOARD 2.5MM PITCH
Female Housing:
PCB Header
560-002-000-XXX
560-002-000-XXX
560-002-420-XXX
560-003-000-XXX
560-003-000-XXX
560-003-420-XXX
560-005-000-XXX
560-005-000-XXX
560-005-420-XXX
Male Housing:
Male Housing:
Female Housing:
PCB Header:
Ø Wire Insulation:
Housing Color:
XXX:
Ø Wire Insulation:
Housing Color:
XXX:
Housing Color:
XXX:
Ø1.00 to Ø1.30
White
110
Ø1.00 to Ø1.30
White
210
White
101
Blue
310
Blue
410
Blue
301
White
111
White
211
Blue
311
Blue
411
Ø1.30 to Ø1.70
Ø1.30 to Ø1.70
NOTE: Waterproofing Cap is installed at the wire seal end to
cover the unused holes.
Waterproofing Cap
www.edac.net
560 SERIES
www.edac.net
很抱歉,暂时无法提供与“560-003-000-311”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16.492291+2.13772
- 10+14.0216410+1.81747
- 25+13.1405625+1.70327
- 50+12.5124050+1.62185
- 100+11.91333100+1.54420
- 300+11.02426300+1.42896
- 500+10.63382500+1.37835
- 1000+10.126231000+1.31256
- 2500+9.492552500+1.23042
