SWH201-NULN-S11-UU-WH 数据手册
Wafers
SWT201 Series Crimp Terminal
SPECIFICATIONS
Material: Phosphor Bronze
Plating: See Part Number Options
Contact Resistance: 20 milli Ohms Max
Current Rating: 1 Amp
Wire Range: AWG #24 - #28
Insulation O.D.: Ø1.20mm ~ Ø1.50mm
Quantity Per Reel = 10,000 Pieces
Used in SWH201 Series Housing
PART NUMBER OPTIONS
SWT201-UPTN-S01-UU-UU
CONTACT FINISH - RoHS Compliant
T = .000015” Min Nickel Underplate, .000040” Min Pure Tin, Bright Overall
P = .000040” Min Nickel Underplate, Gold Flash Overall
DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters.
1.50 [.059]
1.30 [.051]
A
B
SECTION B-B
Wafers
1.50±0.15 [.059±.006]
A
2.60 [.102]
B
5.80 [.228]
2.50 [.098]
0.20±0.03 [.008±.001]
SECTION A-A
0.80 [.031]
1.30 [.051]
1.00±0.10 [.039±.004]
0.45±0.05 [.018±.002]
2.10±0.15 [.083±.006]
0.33±0.08 [.013±.003]
1.30±0.20 [.051±.008]
0.70 [.028]
GOLD PLATING AREA
130
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Wafers
SWH201 Series Housing 2.00 mm [.079”] Contact Centers
SPECIFICATIONS
Insulator Material: Nylon, UL 94V-0 Color: White
Dielectric Withstanding Voltage: 800 VAC
Insulator Resistance: 1000 Megohms Minimum
Operating Temperature: -25°C to +85°C
Voltage Rating: 125 VAC/DC
Suitable for SWT201 Series Terminal
Mates with SWR201 Series Single Row Wafer
PART NUMBER OPTIONS
SWH201-NULN-S16-UU-WH
NUMBER OF POSITIONS
02 thru 16
See Chart Below
A
2.00[.079] TYP.
0.70 ±0.10 [.028 ±.004]
B
3.50 ±0.20 [.138 ±.008]
6.35 [.250]
Wafers
4.50[.177]
PART NUMBER
SWH201-NULN-S02-UU-WH
SWH201-NULN-S03-UU-WH
SWH201-NULN-S04-UU-WH
SWH201-NULN-S05-UU-WH
SWH201-NULN-S06-UU-WH
SWH201-NULN-S07-UU-WH
SWH201-NULN-S08-UU-WH
SWH201-NULN-S09-UU-WH
SWH201-NULN-S10-UU-WH
SWH201-NULN-S12-UU-WH
SWH201-NULN-S13-UU-WH
SWH201-NULN-S14-UU-WH
SWH201-NULN-S15-UU-WH
POSITIONS/
CONTACTS
02/02
03/03
04/04
05/05
06/06
07/07
08/08
09/09
10/10
11/11
12/12
13/13
14/14
15/15
16/16
A
B
mm
in
mm
in
2.00
4.00
6.00
8.00
10.00
12.00
14.00
16.00
18.00
20.00
22.00
24.00
26.00
28.00
30.00
0.079
0.157
0.236
0.315
0.394
0.472
0.551
0.630
0.709
0.787
0.866
0.945
1.024
1.102
1.181
4.40
6.40
8.40
10.40
12.40
14.40
16.40
18.40
20.40
22.40
24.40
26.40
28.40
30.40
32.40
0.173
0.252
0.331
0.409
0.488
0.567
0.646
0.724
0.803
0.882
0.961
1.039
1.118
1.197
1.276
131
SWH201-NULN-S11-UU-WH 价格&库存
很抱歉,暂时无法提供与“SWH201-NULN-S11-UU-WH”相匹配的价格&库存,您可以联系我们找货
