GVHRSF-05V-S
GVHRSF-05V-S
    JST
    P=1.25mm
GVHRSF-05V-S 数据手册
Emboss Tape GVH CONNECTOR 1.25mm pitch/Disconnectable Crimp style connectors Side feed type Side entry type Specifications ––––––––––––––––––– • Current rating: 1.0A AC, DC (AWG #26) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30mΩ max. After environmental testing/ 50mΩ max. • Insulation resistance: 100MΩ min. • Withstanding voltage: 500V AC/minute • Applicable wire: Conductor size/ AWG #30 to #26 Insulation O.D./ 0.8 to 1.0mm This connector can be mounted on the same PC board layout as GH connector, and has the sucking area on the top of connector without suction tape. The side feed type for drawing out the wire laterally that considers the workability of mating and normal side entry type has been developed. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. • Secure locking structure • Prevention of contact deformation • Sucking area Standards –––––––––––––––––––––– 0 Recognized E 60389 Side entry type 0.6 ±0.05 1.25 ±0.05 Header outline 1.35 ±0.1 1±0.1 5.4 ±0.1 3.7 ±0.1 0.8 0.25 ±0.1 2.7 ±0.1 7.15 Side feed type 2 to 4 circuits : 8.35 5 to 8 circuits : 8.75 9 to 15 circuits : 9.55 1.25 ±0.05 1.35 ±0.1 1±0.1 5.6 ±0.1 3.9 ±0.1 0.3 ±0.1 2.8 ±0.1 Header outline 8.8 0.6 ±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 1 GVH CONNECTOR Contact 4.8 Normal type 0.6 Applicable wire AWG# mm2 Model No. 2.1 0.85 2.3 1 0.6 SGVH-002T-P0.2 SGVHSF-002T-0.2 Insulation O.D. (mm) Q’ty / reel 0.05∼ 0.13 30∼ 26 0.8 ∼ 1.0 23,000 0.05∼ 0.13 30∼ 26 0.8 ∼ 1.0 13,000 Material and Finish Side entry type: Phosphor bronze, tin-plated (reflow treatment) Side feed type Side feed type: Brass, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for gold-plated products. 2. Contact JST when it is used for the equipment for outdoor use and the part required high reliability, because the side feed type can correspond with phosphor bronze products. Contact SGVH-002T-P0.2 AP-K2N 0.5 4.5 0.5 1 SGVHSF-002T-0.2 AP-K2N 2 Applicator Dies Crimp applicator with dies MKS-L-10-3 MK/SSHL-002-02 APLMK SSHL002-02 – – – Crimping machine Crimp applicator MKS-L-10-3 MK/SGVHSF-002-02 APLMK SGVHSF002-02 – – – Housing Circuits Model No. 3 GVHR-03V-S 5.7 Normal type A Dimensions (mm) B 2.50 7.00 Q’ty / box 5,000 Material PBT, UL94V-0, natural 4.55 1.25 RoHS compliance 5.6 A B Side feed type (2 to 4 circuits) 1 5.7 B Circuits 8.35 2 3 4 5 Circuit No.1 mark 6 7.2 1.25 7 A 8 (5 to 8 circuits) 1 9 5.7 B 10 11 8.75 12 13 14 15 Circuit No.1 mark 1.25 A GVHRSF-02V-S GVHRSF-03V-S GVHRSF-04V-S GVHRSF-05V-S GVHRSF-06V-S GVHRSF-07V-S GVHRSF-08V-S GVHRSF-09V-S GVHRSF-10V-S GVHRSF-11V-S GVHRSF-12V-S GVHRSF-13V-S GVHRSF-14V-S GVHRSF-15V-S 7.2 (9 to 15 circuits) 1 Model No. 9.55 1.25 A 2 7.2 Q’ty / box 1.25 5.75 4,000 2.50 7.00 4,000 3.75 8.25 2,500 5.00 9.50 2,500 6.25 10.75 2,500 7.50 12.00 2,000 8.75 13.25 2,000 10.00 14.50 1,500 11.25 15.75 1,500 12.50 17.00 1,500 13.75 18.25 1,000 15.00 19.50 1,000 16.25 20.75 1,000 17.50 22.00 1,000 PBT, UL94V-0, natural RoHS compliance Circuit No.1 mark Dimensions (mm) B Material 5.7 B A GVH CONNECTOR Shrouded header Circuits Side entry type 2 4.05 0.8 3 4 5 4.25 6 7 8 9 1.25 0.2 A 10 1.75 11 12 B 13 14 15 Side feed type 4.25 0.7 Model No. Side feed type Side entry type BM02B-GVHS-TB – BM03B-GVHS-TB SM03B-GVHS-TB – BM04B-GVHS-TB – BM05B-GVHS-TB – BM06B-GVHS-TB – BM07B-GVHS-TB – BM08B-GVHS-TB – BM09B-GVHS-TB – BM10B-GVHS-TB – BM11B-GVHS-TB – BM12B-GVHS-TB – BM13B-GVHS-TB – BM14B-GVHS-TB – BM15B-GVHS-TB Dimensions (mm) A B Q’ty / reel 1.25 5.75 2,500 2.50 7.00 2,500 3.75 8.25 2,500 5.00 9.50 2,500 6.25 10.75 2,500 7.50 12.00 2,500 8.75 13.25 2,500 10.00 14.50 2,500 11.25 15.75 2,500 12.50 17.00 2,500 13.75 18.25 2,500 15.00 19.50 2,500 16.25 20.75 2,500 17.50 22.00 2,500 Material and Finish Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) 4.05 Housing: PA 6T, UL94V-0, natural Reinforcement: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for gold-plated products. 1.25 0.2 A B 3
GVHRSF-05V-S 价格&库存
很抱歉,暂时无法提供与“GVHRSF-05V-S”相匹配的价格&库存,您可以联系我们找货
GVHRSF-05V-S
    • 2500+0.16330
    库存:5000
    GVHRSF-05V-S
    • 2500+0.411402500+0.05303
