SWH201-NULN-S13-UU-WH
    SULLINS
    CONN RECEPT 2MM 13POS
SWH201-NULN-S13-UU-WH 数据手册
Wafers SWT201 Series Crimp Terminal SPECIFICATIONS • • • • • • • • Material: Phosphor Bronze Plating: See Part Number Options Contact Resistance: 20 milli Ohms Max Current Rating: 1 Amp Wire Range: AWG #24 - #28 Insulation O.D.: Ø1.20mm ~ Ø1.50mm Quantity Per Reel = 10,000 Pieces Used in SWH201 Series Housing PART NUMBER OPTIONS SWT201-UPTN-S01-UU-UU CONTACT FINISH - RoHS Compliant T = .000015” Min Nickel Underplate, .000040” Min Pure Tin, Bright Overall P = .000040” Min Nickel Underplate, Gold Flash Overall DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters. 1.50 [.059] 1.30 [.051] A B SECTION B-B Wafers 1.50±0.15 [.059±.006] A 2.60 [.102] B 5.80 [.228] 2.50 [.098] 0.20±0.03 [.008±.001] SECTION A-A 0.80 [.031] 1.30 [.051] 1.00±0.10 [.039±.004] 0.45±0.05 [.018±.002] 2.10±0.15 [.083±.006] 0.33±0.08 [.013±.003] 1.30±0.20 [.051±.008] 0.70 [.028] GOLD PLATING AREA 130 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Wafers SWH201 Series Housing 2.00 mm [.079”] Contact Centers SPECIFICATIONS • • • • • • • Insulator Material: Nylon, UL 94V-0 Color: White Dielectric Withstanding Voltage: 800 VAC Insulator Resistance: 1000 Megohms Minimum Operating Temperature: -25°C to +85°C Voltage Rating: 125 VAC/DC Suitable for SWT201 Series Terminal Mates with SWR201 Series Single Row Wafer PART NUMBER OPTIONS SWH201-NULN-S16-UU-WH NUMBER OF POSITIONS 02 thru 16 See Chart Below DIMENSIONS Dimensions in [ ] are in inches, all others are in millimeters. A 2.00[.079] TYP. 0.70 ±0.10 [.028 ±.004] 0.70 ±0.10 [.028 ±.004] B 3.50 ±0.20 [.138 ±.008] 6.35 [.250] Wafers 4.50[.177] PART NUMBER SWH201-NULN-S02-UU-WH SWH201-NULN-S03-UU-WH SWH201-NULN-S04-UU-WH SWH201-NULN-S05-UU-WH SWH201-NULN-S06-UU-WH SWH201-NULN-S07-UU-WH SWH201-NULN-S08-UU-WH SWH201-NULN-S09-UU-WH SWH201-NULN-S10-UU-WH SWH201-NULN-S11-UU-WH SWH201-NULN-S12-UU-WH SWH201-NULN-S13-UU-WH SWH201-NULN-S14-UU-WH SWH201-NULN-S15-UU-WH SWH201-NULN-S16-UU-WH POSITIONS/ CONTACTS 02/02 03/03 04/04 05/05 06/06 07/07 08/08 09/09 10/10 11/11 12/12 13/13 14/14 15/15 16/16 A B mm in mm in 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 0.079 0.157 0.236 0.315 0.394 0.472 0.551 0.630 0.709 0.787 0.866 0.945 1.024 1.102 1.181 4.40 6.40 8.40 10.40 12.40 14.40 16.40 18.40 20.40 22.40 24.40 26.40 28.40 30.40 32.40 0.173 0.252 0.331 0.409 0.488 0.567 0.646 0.724 0.803 0.882 0.961 1.039 1.118 1.197 1.276 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 131
SWH201-NULN-S13-UU-WH 价格&库存
很抱歉,暂时无法提供与“SWH201-NULN-S13-UU-WH”相匹配的价格&库存,您可以联系我们找货
