H4P-SHF-AA
H4P-SHF-AA
    JST
    P=2.5mm
H4P-SHF-AA 数据手册
Crimp 2.5mm NH CONNECTOR Disconnectable Crimp style connectors pitch Features –––––––––––––––––––––––– • Superior folded beam construction (1) This sturdy construction withstands repeated stress, resists permanent deformation, and offers a very long service life. (2) High reliability is ensured whether the contact pressure is high or low. (3) This contact design has a large tolerance for variations in mating post thickness and resists deformation when pried. • Double-sided contact (1) The receptacle contact has a protected entry which eliminates contact damage caused by mismating. (2) It provides high contact pressure, is free from abnormal stress, and maintains continuity at all times. (3) It has an extremely long service life due to its folded beam design. • Wide, sturdy post This 2.5mm pitch connector is used to connect wires to printed circuit boards. The header is available in three configurations: top, side, and bottom entry. This allows the wires to be perpendicular or parallel to the printed circuit board in any direction. The post has a large cross-sectional area to resist prying during insertion into printed circuit boards and mating with connector housings. • Molded-in header The posts are molded into the insulator to provide stability when mounted on printed circuit boards. This also prevents flux from entering the connector during soldering. Specifications ––––––––––––––––––– 1 2 3 JS 4 5 T • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15m Ω max. After environmental testing/ 20m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #30 to #22 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 1 2 Recognized E60389 Certified LR20812 J50168090 1 NH CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Applicable wire Model No. 9 3.8 4 2.2 1.7 mm2 AWG # Insulation O.D. (mm) SHF-001T-0.8BS 0.08 to 0.33 28 to 22 1.2 to 1.7 SHF-002T-0.8BS 0.05 to 0.08 30 to 28 0.9 to 1.2 1.2 Q'ty / reel 5,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for gold-plated products. 2. Also contact JST if you require shielded wires, thin wires or other special wires. 3. Contact JST for brass products. 0.7 1.95 4.6 2 1.8 Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– 1.5 A B C 3 Dimensions (mm) C Q'ty / bag 5.7 8.7 1,000 8.2 11.2 1,000 7.5 10.7 13.7 1,000 H 5P-SHF-AA 10.0 13.2 16.2 1,000 6 H 6P-SHF-AA 12.5 15.7 18.7 1,000 7 H 7P-SHF-AA 15.0 18.2 21.2 500 8 H 8P-SHF-AA 17.5 20.7 23.7 500 9 H 9P-SHF-AA 20.0 23.2 26.2 500 10 H10P-SHF-AA 22.5 25.7 28.7 500 11 H11P-SHF-AA 25.0 28.2 31.2 500 12 H12P-SHF-AA 27.5 30.7 33.7 500 13 H13P-SHF-AA 30.0 33.2 36.2 500 14 H14P-SHF-AA 32.5 35.7 38.7 500 15 H15P-SHF-AA 35.0 38.2 41.2 200 16 H16P-SHF-AA 37.5 40.7 43.7 200 18 H18P-SHF-AA 42.5 45.7 48.7 200 20 H20P-SHF-AA 47.5 50.7 53.7 200 21 H21P-SHF-AA 50.0 53.2 56.2 200 22 H22P-SHF-AA 52.5 55.7 58.7 200 24 H24P-SHF-AA 57.5 60.7 63.7 200 25 H25P-SHF-AA 60.0 63.2 66.2 200 Circuits Model No. 2 3 A B H 2P-SHF-AA 2.5 H 3P-SHF-AA 5.0 4 H 4P-SHF-AA 5 11.7 Material PA 6, UL94V-0, natural (white) RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 2 H2P-SHF-AA-oo(blank)…natural (white) K…black R…red TR…tomato red E…blue M…green O…orange N…brown NH CONNECTOR Header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Top entry type Model No. 2.5 1 Circuits 3.4 3.2 6 0.64 3.5 0.64 A 5.6 Side entry type 1 Side Bottom entry entry type type 2 B 2P-SHF-1AA BS 2P-SHF-1AA BE 2P-SHF-1AA 2.5 1,000 1,000 250 3 B 3P-SHF-1AA BS 3P-SHF-1AA BE 3P-SHF-1AA 5.0 1,000 1,000 250 4 B 4P-SHF-1AA BS 4P-SHF-1AA BE 4P-SHF-1AA 7.5 1,000 500 250 5 B 5P-SHF-1AA BS 5P-SHF-1AA BE 5P-SHF-1AA 10.0 1,000 500 250 6 B 6P-SHF-1AA BS 6P-SHF-1AA BE 6P-SHF-1AA 12.5 500 500 150 7 B 7P-SHF-1AA BS 7P-SHF-1AA BE 7P-SHF-1AA 15.0 500 500 150 8 B 8P-SHF-1AA BS 8P-SHF-1AA BE 8P-SHF-1AA 17.5 500 500 150 9 B 9P-SHF-1AA BS 9P-SHF-1AA BE 9P-SHF-1AA 20.0 500 500 150 10 B10P-SHF-1AA BS10P-SHF-1AA BE10P-SHF-1AA 22.5 250 250 100 11 B11P-SHF-1AA BS11P-SHF-1AA BE11P-SHF-1AA 25.0 250 250 100 12 B12P-SHF-1AA BS12P-SHF-1AA BE12P-SHF-1AA 27.5 250 200 100 13 B13P-SHF-1AA BS13P-SHF-1AA BE13P-SHF-1AA 30.0 250 200 100 14 B14P-SHF-1AA BS14P-SHF-1AA BE14P-SHF-1AA 32.5 250 200 50 15 B15P-SHF-1AA BS15P-SHF-1AA BE15P-SHF-1AA 35.0 250 200 50 16 B16P-SHF-1AA BS16P-SHF-1AA – 37.5 250 200 – 17 B17P-SHF-1AA – 40.0 200 – – 18 B18P-SHF-1AA BS18P-SHF-1AA – 42.5 200 200 – 19 B19P-SHF-1AA – 45.0 250 – – 20 B20P-SHF-1AA BS20P-SHF-1AA – 47.5 250 200 – 21 B21P-SHF-1AA BS21P-SHF-1AA – 50.0 250 200 – 22 B22P-SHF-1AA BS22P-SHF-1AA – 52.5 250 200 – 23 B23P-SHF-1AA – 55.0 250 – – 24 B24P-SHF-1AA BS24P-SHF-1AA – 57.5 250 200 – 25 B25P-SHF-1AA BS25P-SHF-1AA – 60.0 250 200 – – 3 3.5 5.6 6 Top entry type Q'ty / box DimenTop Side entry Bottom entry sions A entry (mm) type type type 2.5 0.64 0.64 A 5.5 3 Bottom entry type 11.4 1 – Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) for the top and side entry types PA 6, UL94V-0, natural (white) for the bottom entry type 10 6 7 5.8 – 3.3 RoHS compliance This product displays (LF)(SN) on a label. 2.5 0.64 A 3.4 3 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2P-SHF-1AA-oo(blank)…natural (white) BK…black R…red TR…tomato red E…blue M…green O…orange N…brown 3 NH CONNECTOR PC board layout (viewed from soldering side) and Assembly layout ––––––––––––––––––– Top entry type Side entry type 6.5 2.5 ±0.05 3.1min. 17.7 6.5 14.9 3 to 12 3.1min. 3.5 min. 2.5 ±0.05 +0.1 0 +0.1 0 φ0.9 1.6 1.6 φ0.9 3 14.7 3.5 3 Bottom entry type 2.5 ±0.05 +0.1 0 7.5 min. φ0.9 3.1 14.7 1.6 3 max. 12.2 2.8 9.5 4 min. Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Crimping machine, Applicator––––––––––––––––––––––––––––––––––––––––––––––– Contact SHF-001T-0.8BS SHF-002T-0.8BS Note: *Strip-crimp applicator 4 Crimping machine AP-K2N AP-K2N Crimp applicator Dies Crimp applicator with dies MKS-L MK/SHF-001-08S APLMK SHF001-08S *MKS-SC SC/SHF-001-08S APLSC SHF001-08S MKS-L MK/SHF-002-08S APLMK SHF002-08S *MKS-SC SC/SHF-002-08S APLSC SHF002-08S
H4P-SHF-AA 价格&库存
很抱歉,暂时无法提供与“H4P-SHF-AA”相匹配的价格&库存,您可以联系我们找货
H4P-SHF-AA
    • 1+0.608001+0.07837
    • 300+0.52472300+0.06763
    • 500+0.45809500+0.05905
    • 1000+0.408111000+0.05261
    • 4000+0.374804000+0.04831
    • 5000+0.374805000+0.04831
    • 10000+0.3664710000+0.04724
    库存:179
