HRP-08-S
HRP-08-S
    JST
    P=2.5mm
    1X8P 2.5MM
HRP-08-S 数据手册
HM CONNECTOR 2.5 2.5 mm mm pitch/Wire-to-wire pitch/Wire-to-wire connectors connectors -- Matable Matable with with HR HR receptacles receptacles Specifications • Current rating: Crimp style HR connectors type 3 A AC/DC Insulation displacement HR connectors type 2 A AC/DC • Voltage rating: 250 V AC/DC (See Note below.) • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #26 to #22 0.13 to 0.33 mm2 • Applicable panel thickness: 0.8 to 1.6 mm Note: Contacts are exposed at the housing lances. Care should be taken so that these parts do not touch the metal section of the chasis. HM connector HM CONNECTOR Insulation displacement HR connector Crimp style HR connector * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. * RoHS2 compliance ● Both crimp style and insulation displacement receptacles can be used ● Housing-to-terminal locks ● Mountable on a variety of panels ● Highly reliable housing construction Standards ® ® ® Recognized E60389 ® Panel layout and Assembly layout 6.8 ® 20.0 5.5 +0.2  0 6.3 +0.2  0 B A Housing 2 HMR-02V 13.3 3.9 3 HMR-03V 15.8 6.4 4 HMR-04V 18.3 8.9 8 HMR-08V 28.3 18.9 12 HMR-12V 38.3 28.9 Note: 1  . Punch holes in the panel according to the sketch and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 Panel hole dimensions (mm) Applicable General tolerance panel thickness +0.2 (mm) A +0.2 B 0 0 No. of circuits 0.8~1.6 Contact Housing 12.85 6.8 4.0 20.0 11.0 1.9 5.85 1.6 1.5 2.1 0.65 1.3 A 2.5 2.85 B 0.64 HM CONNECTOR Applicable wire Model No. mm SMR-001T-0.6 2 0.13~0.33 AWG # Insulation O.D. (mm) Q’ty/ reel 26~22 1.3~1.7 9,000 Material and Finish Brass, tin-plated (reflow treatment) RoHS2 compliance Dimensions (mm) No. of circuits Model No. 2 HMR-02V 2.5 9.3 1,000 3 HMR-03V 5.0 11.8 500 4 HMR-04V 7.5 14.3 500 8 HMR-08V 17.5 24.3 500 12 HMR-12V 27.5 34.3 500 A Q’ty/ bag B Material and Finish Contact SMR-001T-0.6 Applicator Crimping machine Crimp applicator MKS-L AP-K2N Dies Crimp applicator with dies MK/SHR/MR-001-06 APLMK SHR/MR001-06 PA 66, UL94V-0 Applicator Crimping machine Crimp applicator Dies Crimp applicator with dies RoHS2 compliance MKS-L MK/SHR/MR-001-06 APLMK SHR/MR001-06 SHR-001T-P0.6 AP-K2N Contact Note: Contact JST for fully automatic crimping applicator. Receptacle / Crimp style HR connector B 8.2 A 1.9 4.85 2.5 Housing 2.5 Contact 1 R/MR001-06 Plug / HM connector JST ator with dies HM CONNECTOR 2.85 2.1 1.3 10.3 Applicable wire No. of circuits Model No. 2 HRP-02-S 3 Material and Finish HRP-03-S 4 Phosphor bronze, tin-plated (reflow treatment) Model No. mm SHR-001T-P0.6 2 0.13~0.33 AWG # Insulation O.D. (mm) Q’ty/ reel 26~22 1.3~1.7 9,000 RoHS2 compliance 4.1 Dimensions (mm) B Q’ty/ bag 2.5 7.5 2,000 5.0 10.0 2,000 HRP-04-S 7.5 12.5 1,000 8 HRP-08-S 17.5 22.5 500 12 HRP-12-S 27.5 32.5 500 A Material and Finish Contact Crimping machine Crimp applicator SHR-001T-P0.6 AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SHR/MR-001-06 APLMK SHR/MR001-06 PA 66, UL94V-0 RoHS2 compliance Note: Contact JST for fully automatic crimping applicator. 2 HM CONNECTOR Receptacle / Insulation displacement HR connector 10.3 4.1 Model No. Dimensions (mm) Q’ty/ bag A B No. of circuits # 28 # 26 # 24 2 02HR-8M-P-N 02HR-6S-P-N 02HR-4K-P-N 2.5 7.5 1,000 3 03HR-8M-P-N 03HR-6S-P-N 03HR-4K-P-N 5.0 10.0 1,000 4 04HR-8M-P-N 04HR-6S-P-N 04HR-4K-P-N 7.5 12.5 1,000 8 08HR-8M-P-N 08HR-6S-P-N 08HR-4K-P-N 17.5 22.5 500 12 12HR-8M-P-N 12HR-6S-P-N 12HR-4K-P-N 27.5 32.5 500 Material and Finish 3.6 2.5 A B 3 Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0 2.5 RoHS2 compliance
HRP-08-S 价格&库存
很抱歉,暂时无法提供与“HRP-08-S”相匹配的价格&库存,您可以联系我们找货
HRP-08-S
    • 500+0.27020
    库存:5000
