NVR-02
NVR-02
    JST
    P=5mm
    1X2P 5MM
NVR-02 数据手册
NV CONNECTOR 5.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 10 A AC, DC (AWG #16) • Voltage rating: 250 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #22 to #16 • Applicable PC board thickness: 1.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. • Side stackable • Box contact • Compact connector with a large capacity • Secure contact and mounting Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R9251676 PC board layout and Assembly layout 10.6 5 ±0.05 16.5 5 min 2.5 min φ1.65 +0.1  0 Note: 1. The above figure is the figure viewed from the connector soldering side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG# Insulation O.D. (mm) Q't y/ reel 0.33∼0.83 22∼18 1.7∼3.0 4,500 0.5 ∼1.25 20∼16 1.7∼3.0 3,500 Model No. SVH-21T-P1.1 SVH-41T-P1.1 Material and Finish 10.6 3 4 Phosphor bronze, tin-plated (reflow treatment) 4.2 3.8 RoHS compliance Contact SVH-21T-P1.1 AP-K2N SVH-41T-P1.1 Note: *Strip-crimp applicator 1 Applicator Dies Crimp applicator with dies MKS-L MK/SVH-21-11 APLMK SVH21-11 * MKS-SC SC/SVH-21-11 APLSC SVH21-11 MKS-L MK/SVH-41-11 APLMK SVH41-11 ― ― ― Crimping machine Crimp applicator NV CONNECTOR Housing 9.7 Model No. 2 NVR-02 NVR-03 NVR-04 3 4 Dimensions (mm) A B Q'ty/ bag 5.0 10.0 10.0 15.0 1,000 500 15.0 20.0 1,000 3.8 Circuit No.1 Circuits 6.2 10.6 Material PA 6, UL94V-0, natural (white) RoHS compliance A B As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2.5 13.3 ex. NVR-02-oo(blank)…natural (white) E…blue Header Circuit No.1 Circuits Model No. 2 B02P-NV B03P-NV B04P-NV 4 1.14 10.0 1,000 15.0 700 15.0 20.0 500 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: B02P-NV...PA 66, UL94V-0, natural (white) B03P-NV & B04P-NV...Glass-filled PBT, UL94V-0, natural (white) 3.2 3.7 5.0 10.0 RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 5.0 A B Q'ty/ box Material and Finish 9.4 7.7 3 Dimensions (mm) A B 8.5 ex. B02P-NV-oo(blank)…natural (white) BL…blue 2
NVR-02 价格&库存
很抱歉,暂时无法提供与“NVR-02”相匹配的价格&库存,您可以联系我们找货
NVR-02
  • 5+0.84867
  • 50+0.67608
  • 150+0.58979
  • 1000+0.46797
  • 2000+0.41613
  • 5000+0.39032
库存:67288
NVR-02
    库存:22000
    NVR-02
      • 1+0.879611+0.11380
      • 300+0.71365300+0.09233
      • 500+0.63897500+0.08266
      • 1000+0.589181000+0.07622
      • 4000+0.547694000+0.07086
      • 5000+0.547695000+0.07086
      • 10000+0.5393910000+0.06978
      库存:9
      NVR-02
        • 1000+0.777771000+0.10062
        NVR-02
          库存:10000
          NVR-02
            • 1+0.81840
            • 50+0.62920
            • 1000+0.58080
            NVR-02
              库存:16000
              NVR-02
                • 500+0.33800
                • 1000+0.30180
                库存:18806
