ZER-09V-S
ZER-09V-S
    JST
    P=1.5mm
ZER-09V-S 数据手册
ZE CONNECTOR Emboss Emboss Tape Tape 1.5 mm pitch/Disconnectable Crimp style connectors 1.5 mm pitch secure lock type connector. Fork-shaped header contact provides the good mating feeling and secure mating operation. ● Secure locking structure ● Contact locking structure ZE CONNECTOR Specifications • Current rating: 2 A AC/DC (AWG #24) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 40 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #30 to #24 Insulation O.D./ 0.8 to 1.2 mm * In using the products, refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ® ® ® Standards ® Recognized E60389 ® PC board layout and Assembly layout Top entry type Side entry type +0.1 φ0.8 0 Connector outline 1.65 ±0.05 (3.65) (6.3) 3.7 1.85 ±0.05 +0.1 φ1.1 0 +0.1 1.5 ±0.05 φ0.7 0 (0.6) (9.7) ±0.05 (10.4) 3.8 2 ±0.05 ±0.05 1.5 ±0.05 (0.7) Circuit No.1 (0.65) A ±0.05 1.55 ±0.05 Connector outline (5.75) +0.1 φ0.7 0 Circuit No.1 A ±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Side entry type 1.7 ±0.1 1.8 ±0.1 1.5 ±0.05 0.8 min. 6.6 ±0.1 3.8 ±0.1 Circuit No.1 Connector outline 1.7 ±0.1 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances for the centers of pattern on PCB is ± 0.05,and shall be not cumulative more than ± 0.1. The dimensions above should serve as a guideline. Contact JST for details. 1.8 ±0.1 (9.4) 1.2 5.8 A±0.1 1.2 1.45 ±0.1 ±0.1 3.3 0.4 ±0.1 1 Connector outline (5.8) (9.4) 1.5 ±0.05 Circuit No.1 5.5 ±0.1 0.8 min. ±0.1 2.4 min. A 2.9 min. Top entry type ZE CONNECTOR Contact Applicable wire AWG # mm2 Model No. SZE-002T-P0.3 SZE-003T-P0.3 6.2 28~24 0.8~1.2 16,000 0.05~0.13 30~26 0.8~1.0 16,000 ZE CONNECTOR Material and Finish 2.7 Copper alloy, tin-plated (reflow treatment) 1 RoHS2 compliance 0.54 0.75 1.3 Q’ty/ reel 0.08~0.21 2.9 0.8 Insulation O.D. (mm) Contact SZE-002T-P0.3 SZE-003T-P0.3 Crimping machine Crimp applicator AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SZE-002-03 APLMK SZE002-03 MK/SZE-003-03 APLMK SZE003-03 Note: Contact JST for fully automatic crimping applicator. Housing Circuit No.1 mark 5.7 7.5 5.7 1.5 A A B B Circuit No.1 mark 5.7 7.5 5.7 1.5 1.5 A A B B 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Circuit No.1 mark 7.5 No. of circuits Circuit No.1 mark 7.5 Model No. ZER-02V-S ZER-03V-S ZER-04V-S ZER-05V-S ZER-06V-S ZER-07V-S ZER-08V-S ZER-09V-S ZER-10V-S ZER-11V-S ZER-12V-S ZER-13V-S ZER-14V-S ZER-15V-S ZER-16V-S Dimensions (mm) A B Q’ty/ bag 1.5 5.0 6,000 3.0 6.3 6,000 4.5 7.8 5,000 6.0 9.3 3,000 7.5 10.8 3,000 9.0 12.3 2,000 10.5 13.8 2,000 12.0 15.3 2,000 13.5 16.8 2,000 15.0 18.3 2,000 16.5 19.8 2,000 18.0 21.3 2,000 19.5 22.8 2,000 21.0 24.3 1,500 22.5 25.8 1,500 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. ZER-02V-S S...natural Z...ivory E...blue TR...tomato red MG...moss green DH...dark gray DPK...dark pink L...lemon yellow LE...light blue DO...dark orange DP...dark purple K...black R...red M...green Y...yellow N...brown P...purple FY...vivid yellow PK...pink O...orange Material and Finish PBT, UL94V-0, natural RoHS2 compliance 2 ZE CONNECTOR Header (DIP type) Top entry type Circuit No.1 mark B Side entry type 5.75 A (0.65) 3.8 Circuit No.1 mark 6.3 (3.4) 1.5 1.85 (3.4) 3.7 7.8 3.65 8.5 1.5 B A 2 1.65 Circuit No.1 mark B 5.75 A B (0.65) Circuit No.1 mark A 6.3 1.5 (3.4) 1.5 1.65 2 Circuit No.1 mark B 1.85 (3.4) 3.7 7.8 8.5 3.65 3.8 5.75 A (0.65) 3.8 Circuit No.1 mark B 6.3 1.5 (3.4) 1.5 2 1.65 Top entry type No. of circuits 1.85 (3.4) 3.7 7.8 3.65 8.5 A Side entry type Model No. Without boss With boss Dimensions (mm) A B Q’ty / box No. of circuits Model No. Dimensions (mm) A B Q’ty/ box 2 - B02B-ZESK-1D 1.5 6.0 2,496 2 S02B-ZESK-2D 1.5 6.0 1,872 3 B03B-ZESK-D B03B-ZESK-1D 3.0 7.5 1,984 3 S03B-ZESK-2D 3.0 7.5 1,488 4 B04B-ZESK-D B04B-ZESK-1D 4.5 9.0 1,664 4 S04B-ZESK-2D 4.5 9.0 1,248 5 B05B-ZESK-D B05B-ZESK-1D 6.0 10.5 1,408 5 S05B-ZESK-2D 6.0 10.5 1,056 6 B06B-ZESK-D B06B-ZESK-1D 7.5 12.0 1,216 6 S06B-ZESK-2D 7.5 12.0 912 7 B07B-ZESK-D B07B-ZESK-1D 9.0 13.5 1,088 7 S07B-ZESK-2D 9.0 13.5 816 8 B08B-ZESK-D B08B-ZESK-1D 10.5 15.0 960 8 S08B-ZESK-2D 10.5 15.0 720 9 B09B-ZESK-D B09B-ZESK-1D 12.0 16.5 896 9 S09B-ZESK-2D 12.0 16.5 672 10 B10B-ZESK-D B10B-ZESK-1D 13.5 18.0 832 10 S10B-ZESK-2D 13.5 18.0 624 11 B11B-ZESK-D B11B-ZESK-1D 15.0 19.5 768 11 S11B-ZESK-2D 15.0 19.5 576 12 B12B-ZESK-D B12B-ZESK-1D 16.5 21.0 704 12 S12B-ZESK-2D 16.5 21.0 528 13 B13B-ZESK-D B13B-ZESK-1D 18.0 22.5 640 13 S13B-ZESK-2D 18.0 22.5 480 14 B14B-ZESK-D B14B-ZESK-1D 19.5 24.0 576 14 S14B-ZESK-2D 19.5 24.0 432 15 B15B-ZESK-D B16B-ZESK-D B15B-ZESK-1D B16B-ZESK-1D 21.0 25.5 576 15 21.0 25.5 432 22.5 27.0 512 16 S15B-ZESK-2D S16B-ZESK-2D 22.5 27.0 384 16 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural RoHS2 compliance This product displays (LF)(SN) on a label. Note: Top entry type 2 circuits is only header with boss. Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural RoHS2 compliance This product displays (LF)(SN) on a label. ex. 3  s the color identification, the following alphabet shall be put in the underlined part. A For availability, delivery and minimum order quantity, contact JST. B02B-ZESK-1D, S02B-ZESK-2D  S...natural Z...ivory E...blue TR...tomato red MG...moss green DH...dark gray DPK...dark pink L...lemon yellow LE...light blue DO...dark orange K...black R...red M...green Y...yellow N...brown P...purple FY...vivid yellow PK...pink O...orange ZE CONNECTOR Header (SMT type) Top entry type B 1.2 B Circuit No.1 mark A 5.8 7.5 5.8 1.2 7.5 Side entry type Circuit No.1 mark A 5.8 B A 5.8 1.2 Circuit No.1 mark 1.5 1.2 7.5 1.5 Circuit No.1 mark B A 7.5 B A Circuit No.1 mark 1.5 5.8 Circuit No.1 mark 5.8 1.2 1.2 7.5 7.5 1.5 B A B A Circuit No.1 mark 5.8 1.2 B A Circuit No.1 mark 5.8 1.2 7.5 7.5 1.5 1.5 Top entry type Dimensions (mm) A B Side entry type Dimensions (mm) A B Q’ty/ reel Q’ty/ reel No. of circuits 7.5 800 2 SM02B-ZESS-TB 1.5 7.5 1,000 9.0 800 3 SM03B-ZESS-TB 3.0 9.0 1,000 4.5 10.5 800 4 SM04B-ZESS-TB 4.5 10.5 1,000 BM05B-ZESS-TBT 6.0 12.0 800 5 SM05B-ZESS-TB 6.0 12.0 1,000 6 BM06B-ZESS-TBT 7.5 13.5 800 6 SM06B-ZESS-TB 7.5 13.5 1,000 7 BM07B-ZESS-TBT 9.0 15.0 800 7 SM07B-ZESS-TB 9.0 15.0 1,000 8 BM08B-ZESS-TBT 10.5 16.5 800 8 SM08B-ZESS-TB 10.5 16.5 1,000 9 BM09B-ZESS-TBT 12.0 18.0 800 9 SM09B-ZESS-TB 12.0 18.0 1,000 10 BM10B-ZESS-TBT 13.5 19.5 800 10 SM10B-ZESS-TB 13.5 19.5 1,000 11 BM11B-ZESS-TBT 15.0 21.0 800 11 SM11B-ZESS-TB 15.0 21.0 1,000 12 BM12B-ZESS-TBT 16.5 22.5 800 12 SM12B-ZESS-TB 16.5 22.5 1,000 13 BM13B-ZESS-TBT 18.0 24.0 800 13 SM13B-ZESS-TB 18.0 24.0 1,000 SM14B-ZESS-TB 19.5 25.5 1,000 SM15B-ZESS-TB SM16B-ZESS-TB 21.0 27.0 1,000 22.5 28.5 1,000 No. of circuits Model No. 2 BM02B-ZESS-TBT 1.5 3 BM03B-ZESS-TBT 3.0 4 BM04B-ZESS-TBT 5 14 BM14B-ZESS-TBT 19.5 25.5 800 14 15 BM15B-ZESS-TBT BM16B-ZESS-TBT 21.0 27.0 800 15 22.5 28.5 800 16 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural Reinforcement: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape/with suction tape. 16 Model No. Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural Reinforcement: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape/without suction tape. ex.  s the color identification, the following alphabet shall be put in the underlined part. A For availability, delivery and minimum order quantity, contact JST. BM02B-ZESS-TBT, SM02B-ZESS-TB  S...natural Z...ivory E...blue TR...tomato red MG...moss green DH...dark gray DPK...dark pink L...lemon yellow LE...light blue DO...dark orange DP...dark purple 4
ZER-09V-S 价格&库存
很抱歉,暂时无法提供与“ZER-09V-S”相匹配的价格&库存,您可以联系我们找货
ZER-09V-S
    • 1+1.356241+0.17402
    • 10+1.1977210+0.15368
    • 50+0.8278350+0.10622
    • 100+0.75738100+0.09718
    • 500+0.70454500+0.09040
    • 1000+0.678121000+0.08701
    • 2000+0.660512000+0.08475
    库存:1920
    ZER-09V-S
      库存:32000
      ZER-09V-S
      • 1+1.497941+0.19221
      ZER-09V-S
        • 1+2.451351+0.31454
        • 100+1.83224100+0.23510
        • 300+1.27169300+0.16318
        • 500+1.15456500+0.14815
        • 1000+1.070901000+0.13741
        • 4000+1.003974000+0.12882
        • 5000+1.003975000+0.12882
        库存:908
        ZER-09V-S
          库存:3
          ZER-09V-S
            库存:882
