XARP-09V
XARP-09V
    JST
    P=2.5mm
    9 Position Rectangular Housing Connector Receptacle Natural 0.098" (2.50mm)
XARP-09V 数据手册
XA CONNECTOR High box type Radial Tape 2.5mm pitch/Disconnectable Crimp style connectors T H JS Specifications ––––––––––––––––––– XA connector high box type, with 19.5mm mounting height and with 6.9mm thickness. • Header for 2.5mm pitch XA connector for use specifically with resin coated ("potted") PC boards • Interchangeability • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,000V AC/minute • Applicable wire: AWG #28 to #22 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R9851220 PC board layout (viewed from component side) and Assembly layout Without a boss With a boss +0.1 φ0.9 0 φ0.9 +0.1  0 2.5 ±0.05 1.6 ±0.05 (19.5) 2.5±0.05 1.6 ±0.05 (6.9) φ1.2+0.1  0 Note:1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 XA CONNECTOR High box type Contact Model No. SXA-001T-P0.6 1.9 Applicable wire Q'ty / reel AWG# Insulation O.D. (mm) mm2 0.08∼0.33 28∼22 0.8∼1.9 8,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 6.5 3.1 1.3 1.6 2.3 RoHS compliance Crimping machine Crimp applicator Contact SXA-001T-P0.6 AP-K2N Applicator Dies Crimp applicator with dies MKS-L MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 Note: *Strip-crimp applicator Housing Standard type Standard type 9.5 6.9 2 XAP-02V-1 3 XAP-03V-1 4 A Circuit No.1 5.8 Retainer mountable type B 2.5 2.4 7.4 0.6 Dimensions (mm) Q'ty / bag Retainer Standard mountable type type A B XARP-02V 2.5 7.3 1,000 1,000 XARP-03V 5.0 9.8 1,000 1,000 XAP-04V-1 XARP-04V 7.5 12.3 1,000 1,000 5 XAP-05V-1 XARP-05V 10.0 14.8 1,000 1,000 6 XAP-06V-1 XARP-06V 12.5 17.3 1,000 1,000 7 XAP-07V-1 XARP-07V 15.0 19.8 1,000 1,000 8 XAP-08V-1 XARP-08V 17.5 22.3 1,000 1,000 9 XAP-09V-1 XARP-09V 20.0 24.8 1,000 1,000 10 XAP-10V-1 XARP-10V 22.5 27.3 1,000 1,000 11 XAP-11V-1 XARP-11V 25.0 29.8 1,000 1,000 12 XAP-12V-1 XARP-12V 27.5 32.3 1,000 1,000 13 XAP-13V-1 XARP-13V 30.0 34.8 1,000 1,000 14 XAP-14V-1 XARP-14V 32.5 37.3 500 1,000 15 XAP-15V-1 XARP-15V 35.0 39.8 500 1,000 B 2.5 2.4 Model No. Retainer mountable type Circuits 10.5 Material PA 66, UL94V-0, natural (white) RoHS compliance A Circuit No.1 5.8 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. XAP-02V-1-oo(blank)…natural (white) K…black R…red E…blue M…green Y…yellow Retainer Model No. A Q'ty / bag 2 XMS-02V 2.5 1,000 3 XMS-03V 5.0 1,000 4 XMS-04V 7.5 1,000 5 XMS-05V 10.0 1,000 6 XMS-06V 12.5 1,000 7 XMS-07V 15.0 1,000 8 XMS-08V 17.5 1,000 9 XMS-09V 20.0 1,000 10 XMS-10V 22.5 1,000 11 XMS-11V 25.0 1,000 12 XMS-12V 27.5 1,000 Material 13 XMS-13V 30.0 1,000 Glass-filled PA 66, UL94V-0, natural (ivory) 14 XMS-14V 32.5 1,000 15 XMS-15V 35.0 1,000 2.5 RoHS compliance 7.8 0.95 2.5 A Circuits 2 XA CONNECTOR High box type Shrouded header Without a boss Circuits 3.3 2.5 0.6 A With a boss A 2 BH02B-XASK-BN BH02B-XASK 2.5 7.5 400 3 BH03B-XASK-BN BH03B-XASK 5.0 10.0 400 4 BH04B-XASK-BN BH04B-XASK 7.5 12.5 300 5 BH05B-XASK-BN BH05B-XASK 10.0 15.0 300 6 BH06B-XASK-BN BH06B-XASK 12.5 17.5 200 7 BH07B-XASK-BN BH07B-XASK 15.0 20.0 200 8 BH08B-XASK-BN BH08B-XASK 17.5 22.5 200 9 BH09B-XASK-BN BH09B-XASK 20.0 25.0 150 10 BH10B-XASK-BN BH10B-XASK 22.5 27.5 150 11 BH11B-XASK-BN BH11B-XASK 25.0 30.0 100 12 BH12B-XASK-BN BH12B-XASK 27.5 32.5 6.4 100 13 BH13B-XASK-BN BH13B-XASK 30.0 35.0 100 14 BH14B-XASK-BN BH14B-XASK 32.5 37.5 100 15 BH15B-XASK-BN BH15B-XASK 35.0 40.0 100 17.0 B Q'ty / box With a boss 6.4 17.0 B Dimensions (mm) Model No. Without a boss B Material and Finish 1.5 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) 3.3 RoHS compliance This product displays (LF)(SN) on a label. φ1.0 0.6 2.5 1.6 1.6 A As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BH02B-XASK-BNS…natural (ivory) K…black R…red M…green Y…yellow Shrouded header on radial-tape Without a boss 6.4 3.3 17.0 2.5 2.5 0.6 (φ0.7) 3.2 Dimensions (mm) Q'ty / box A B Model No. Without a boss With a boss Circuits B A 2 BH02B-XASS-BN-T BH02B-XASS-T 2.5 7.5 1,000 3 BH03B-XASS-BN-T BH03B-XASS-T 5.0 10.0 1,000 4 BH04B-XASS-BN-T BH04B-XASS-T 7.5 12.5 500 5 BH05B-XASS-BN-T BH05B-XASS-T 10.0 15.0 500 6 BH06B-XASS-BN-T BH06B-XASS-T 12.5 17.5 500 7 BH07B-XASS-BN-T BH07B-XASS-T 15.0 20.0 500 8 BH08B-XASS-BN-T BH08B-XASS-T 17.5 22.5 500 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) RoHS compliance This product displays (LF)(SN) on a label. Taping specifications With a boss 6.4 B A 6.4 φ1.0 1.6 3.2 1.6 0 4. φ 18.0 0.6 (φ0.7) 3.2 20.0 3.3 1.5 6.0 1.0max. 17.0 2.5 2.5 12.7 Note: Conforms to JIC C 0806 of "Tape packaging of components with unidirectional leads on continuous tapes". 3 XA CONNECTOR High box type Packaging specifications Package type Distance between folds Box size Distance between the end of the tape and the first connector’s center line (either end) D TERMIN H ALS & CONN Quantity ECTORS 2, 3 circuits 4∼8 circuits Flat pack (zigzag folded) 24 indexing holes per fold (304.8mm) 314(W)×54(D)×314(H)mm 19.05mm 1,000 pcs. / box 500 pcs. / box Note: Products of different packaging specifications are also available. Contact JST for details. R W Distance between the end of the tape and the first connector's center line (either end) Tail tape Leader tape 4
XARP-09V 价格&库存
很抱歉,暂时无法提供与“XARP-09V”相匹配的价格&库存,您可以联系我们找货
XARP-09V
    • 1000+1.064951000+0.13320
    • 3000+1.038323000+0.12987
    • 4000+1.033454000+0.12926
    • 10000+1.0205710000+0.12765
    • 15000+1.0028315000+0.12543
    XARP-09V
      库存:14000
      XARP-09V
        • 5+0.73430
        • 50+0.58670
        • 150+0.51300
        • 1000+0.40280
        • 2000+0.36390
        库存:4950
        XARP-09V
          • 1000+0.60500
          库存:71000
          XARP-09V
            • 1000+0.41217
            库存:4000
