WPJR-02V-1-S(NN)
WPJR-02V-1-S(NN)
    JST
    P=5mm
    5MM
WPJR-02V-1-S(NN) 数据手册
WPJ CONNECTOR 5.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– Compact, Water Resist and Durable. This connector for electrical connection can be used on both waterproof and nonwaterproof conditions, depending on the usage. Just by placing a rubber part will change it into a water resistant connector. Both conditions are using the same header. • Waterproof performance [Grade 7 ingress protection of JIS C 0920 ( IPX7 of IEC 60529 ) ] • Control key system • Contacting part of contact is hardly deformed • Inner locking system • Compact design • Current rating: 7 A AC, DC (AWG #18) • Voltage rating: 300 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: Conductor size/ AWG #22 to #18 Insulation O.D./ 2.32 to 2.83 mm 1.52 to 2.03 mm • Waterproof grade: Grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529 ) * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R50073100 PC board layout and Assembly layout 11.2 φ1.5 +0.1 0 φ1.1 +0.05 0 5 ±0.05 Connector outline 10 ±0.05 3.075 ±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 1 25.3 (2.6) 1.8 ±0.05 (4.6) WPJ CONNECTOR (Non-waterproof type) Contact Applicable wire mm2 AWG# Model No. Insulation O.D. (mm) Q'ty/reel SWPJR-21T-M0.5 0.33∼0.83 22∼18 2.32∼2.83 4,500 SWPJR-21T-M0.5A 0.33∼0.83 22∼18 1.52∼2.03 4,500 2.4 Material and Finish Copper alloy, tin-plated (reflow treatment) RoHS compliance 14.5 5.6 Contact Crimping machine Crimp applicator MKS-L SWPJR-21T-M0.5 Applicator Dies ― AP-K2N MKS-L SWPJR-21T-M0.5A Crimp applicator with dies MK/SWPJR/T-21-05 APLMK SWPJR/T21-05 ― ― MK/SWPJR/T-21-05A APLMK SWPJR/T21-05A ― ― ― Housing Receptacle housing 14.2 Circuits Model No. WPJR-02V-1-S WPJR-03V-1-S 2 22.8 3 A B Q'ty/bag ー 12.1 1,000 10.0 17.1 1,000 Material Glass-filled PBT, UL94V-0, natural (white) RoHS compliance 0.7 Polarizing key pattern Key pattern 1 (Color: Natural): 11.2 B WPJR-02V-1-S Key pattern 2 (Color: Red): WPJR-02V-2-R Key pattern 3 (Color: Blue): WPJR-02V-3-E For availability, delivery and minimum order quantity, contact JST. 5 A Header Circuits Model No. B02B-WPJSS-1 B03B-WPJSS-1 2 3 A B Q'ty/box ー 14.2 600 10.0 19.2 390 Material and Finish B 10.2 Wafer: Glass-filled PBT, UL94V-0 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Polarizing key pattern Key pattern 1 (Color: Natural): B02B-WPJSS-1 13.3 21.4 Key pattern 2 (Color: Red): B02B-WPJRS-2 Key pattern 3 (Color: Blue): B02B-WPJES-3 For availability, delivery and minimum order quantity, contact JST. 5 (4.6) 7.1 A 3.075 2 WPJ CONNECTOR (Waterproof type) Contact Applicable wire mm2 AWG# Model No. 0.33∼0.83 2.4 SWPJR-21T-M0.5 Insulation O.D. (mm) Q'ty/reel 2.32∼2.83 4,500 22∼18 Material and Finish Copper alloy, tin-plated (reflow treatment) 14.5 RoHS compliance 5.6 Contact SWPJR-21T-M0.5 Crimping machine Crimp applicator MKS-L AP-K2N Applicator Dies Crimp applicator with dies MK/SWPJR/T-21-05 APLMK SWPJR/T21-05 ― ― ― Housing Receptacle housing assembly 14.2 Circuits Model No. 02R-WPJV-1-SMM 03R-WPJV-1-SMM 2 3 A B Q'ty/box ー 12.1 720 10.0 17.1 576 22.8 Material Receptacle housing: Glass-filled PBT, UL94V-0, natural (white) Seal ring: Silicon, green Seal rubber plate: Silicon, green RoHS compliance B 0.7 Polarizing key pattern 11.2 Key pattern 1 (Color: Natural): 02R-WPJV-1-SMM Key pattern 2 (Color: Red): 02R-WPJV-2-RMM Key pattern 3 (Color: Blue): 02R-WPJV-3-EMM For availability, delivery and minimum order quantity, contact JST. 5 A Header Circuits Model No. B02B-WPJSS-1 B03B-WPJSS-1 2 3 A B Q'ty/box ー 14.2 600 10.0 19.2 390 Material and Finish B 10.2 Wafer: Glass-filled PBT, UL94V-0 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Polarizing key pattern 13.3 21.4 Key pattern No.1(Color: Natural): B02B-WPJSS-1 Key pattern No.2(Color: Red): B02B-WPJRS-2 Key pattern No.3(Color: Blue): B02B-WPJES-3 For availability, delivery and minimum order quantity, contact JST. 5 (4.6) 3 7.1 A 3.075
WPJR-02V-1-S(NN)
物料型号: - SWPJR-21T-M0.5: 适用于0.33~0.83 mm²的电线,AWG #22至#18,绝缘外径2.32~2.83 mm - SWPJR-21T-M0.5A: 适用于0.33~0.83 mm²的电线,AWG #22至#18,绝缘外径1.52~2.03 mm
器件简介: - WPJ CONNECTOR是一款5.0mm间距、可断开的压接式连接器,具有7A的电流额定值和300V的电压额定值。适用于防水和非防水条件,通过添加橡胶部件可转换为防水连接器。
引脚分配: - 引脚分配信息未在文档中明确列出,但提供了PC板布局和组装布局的图示。
参数特性: - 工作温度范围:-25°C至+85°C - 初始接触电阻:最大10 mΩ - 环境测试后接触电阻:最大20 mΩ - 绝缘电阻:最小1,000 MΩ - 耐电压:1,500 VAC/分钟 - 适用电线:导体尺寸AWG #22至#18,绝缘外径2.32至2.83 mm或1.52至2.03 mm
功能详解: - 连接器具有内锁系统和紧凑设计,确保接触部分不易变形。 - 符合RoHS标准。
应用信息: - 可用于控制键系统等应用。
封装信息: - 母头材料:铜合金,镀锡(回流处理) - 插座材料:玻璃填充PBT,UL94V-0,自然色(白色) - 密封圈和密封橡胶板:硅橡胶,绿色
WPJR-02V-1-S(NN) 价格&库存
很抱歉,暂时无法提供与“WPJR-02V-1-S(NN)”相匹配的价格&库存,您可以联系我们找货
