HILP-06V-2-R
HILP-06V-2-R
    JST
    P=3.3mm
    3.3MM 2X3P
HILP-06V-2-R 数据手册
HIL CONNECTOR 3.3mm pitch/Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– • Current rating: 5A AC, DC (2 circuits AWG #18) • Voltage rating: 300V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: Conductor size/01 type AWG #24 to #20 /21 type AWG #22 to #18 Insulation O.D./01 type 1.3 to 2.5mm /21 type 1.5 to 2.7mm (when using retainer for 21 type 1.5 to 2.5mm) * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. This HIL connector is 3.3mm pitch wire-towire connector that has a mechanism to prevent an incomplete mating when mating connector. • Inertia lock mechanism to prevent an incomplete mating • Box-shaped contact to prevent the influence by external forces • Polarizing key to prevent connector from mating with incorrect circuits Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit: A Circuits Wire size (AWG) #22 #24 2 #18 5 #20 4 3 3 3 4 4 3 2 4 3 3 2 2 6 3 3 2 2 8 3 3 2 2 Assembly layout List of combinations Resin color (Plug/ Receptacle) Natural Red Blue Polarizing key pattern Polarizing key pattern 1 Polarizing key pattern 2 Polarizing key pattern 3 (34.6) Including retainer (9) (31.6) (34.6) Including retainer (13.8) (31.6) 1 Plug Model No. Receptacle Model No. HILP-( )V-1-S HILP-( )V-2-R HILP-( )V-3-E HILR-( )VF-1-S HILR-( )VF-2-R HILR-( )VF-3-E HIL CONNECTOR 1.2 Contact Socket contact 1.8 Pin contact 12.7 15.9 4.3 1.9 0.5 4.3 Model No. Applicable wire Insulation O.D. (mm) Q´ty / reel 24∼20 1.3∼2.5 5,000 22∼18 1.5∼2.7 5,000 mm2 AWG # SHIF-01T-P0.5 0.2∼0.5 SHIF-21T-P0.5 0.3∼0.75 Pin contact Socket contact SHIM-01T-P0.5 SHIM-21T-P0.5 Material and Finish Copper alloy, tin-plated RoHS compliance Note: Insulation O.D. is 1.5mm to 2.5mm when using retainer for 21 type barrel size contact. Applicator Crimping machine Crimp applicator Contact SHIM-01T-P0.5 SHIM-21T-P0.5 AP-K2N MKS-L Dies Crimp applicator with dies Applicator Crimping machine Crimp applicator Contact MK/SHIF/M-01-05 APLMK SHIF/M01-05 SHIF-01T-P0.5 MK/SHIF/M-21-05 APLMK SHIF/M21-05 SHIF-21T-P0.5 AP-K2N MKS-L Dies Crimp applicator with dies MK/SHIF/M-01-05 APLMK SHIF/M01-05 MK/SHIF/M-21-05 APLMK SHIF/M21-05 Contact position location numbers Retainer Contact position numbers are stamped Retainer L JST I A I A L JST Receptacle housing Plug housing Receptacle housing Plug housing L JST 3 A 3 A 2 3 2 1 1 1 L JST A A L JST L JST 4 1 3 1 1 4 A L JST A 4 A 1 5 L JST 7 6 4 8 3 7 2 6 1 5 5 1 5 1 8 4 5 2 2 1 I 6 3 A 2 6 3 6 2 I L JST 3 7 4 7 3 L JST 4 8 8 5 2 2 4 1 3 4 2 2 1 3 5 3 A 1 3 6 6 A 1 2 3 5 2 3 6 L JST 2 4 4 2 2 1 1 1 1 1 2 2 4 L JST 2 3 2 2 HIL CONNECTOR Housing Material: Housing...PA 66, UL94V-0, natural Retainer...Glass-filled PA 66, UL94V-0, natural Voltage Current Circuits rating rating Receptacle housing (for pin contact) HILR-02VF-1-S Q´ty / bag 9 24.4 Q´ty / bag 19.1 2 8.6 8.6 1 1 A A 24.4 L JST HILP-03V-1-S Q´ty / bag 19.1 A A 3 1 1 A A HILP-04V-1-S 4.25 13.8 2 4 1 3 A A L JST 24.4 8.9 8.6 1 1,000 8.6 A 2 3 1,000 A L JST L JST 4 1,000 L JST Q´ty / HILS-03V Q´ty / bag (commonly used for bag 3-circuit housing and 6-circuit housing) HILP-06V-1-S 19.1 4.25 13.8 3A 5 4 3 2 1 11.9 8 6 5 3 2 1 15.2 15.2 I I A A L JST Q´ty / bag 4.25 7 A 2 I 3 6 L JST 4 7 L JST 8 4 13.8 HILS-04V 1 5 L JST 1,000 15.5 11.9 A A 19.1 A 1 L JST Q´ty / bag 500 1,000 I 2 4 24.4 1,000 12.2 A 3 5 L JST 6 A L JST L JST 6 3A 500 Q´ty / HILP-08V-1-S bag RoHS compliance Note: Current rating is for use with AWG #18 wire. 3 HILS-02V Q´ty / (commonly used for bag 2-circuit housing and 4-circuit housing) L JST 19.1 Q´ty / bag 13.8 300V Q´ty / bag 2 11.9 11.9 2 24.4 HILR-08VF-1-S 8 1,000 3A 13.8 300V 1,000 12.2 L JST L JST 3 L JST HILR-06VF-1-S 6 HILS-03V Q´ty / bag (commonly used for 3-circuit housing and 6-circuit housing) 4.25 9 1,000 Q´ty / bag 13.8 300V 1,000 4A HILR-04VF-1-S 4 1,000 8.9 L JST L JST 2 L JST Q´ty / bag 9 300V 4.25 9 1,000 HILR-03VF-1-S 3 HILS-02V Q´ty / bag (commonly used for 2-circuit housing and 4-circuit housing) 5A A 300V HILP-02V-1-S A 2 Retainer Plug housing (for socket contact) 1,000
HILP-06V-2-R 价格&库存
很抱歉,暂时无法提供与“HILP-06V-2-R”相匹配的价格&库存,您可以联系我们找货
HILP-06V-2-R
  • 1000+2.427461000+0.31403
