RA-1011
RA-1011
    JST
    P=2.54mm
    2X5P 2.54MM
RA-1011 数据手册
Crimp 2.54mm RA CONNECTOR Disconnectable Crimp style connectors pitch Features –––––––––––––––––––––––– • Secure locking mechanism (RA, RX headers) The locking levers are engaged by inserting the receptacle into the header. This ensures a firm connection that’s highly resistant to impact and vibration. • Housing lances The contact retention lances on the resilient housing allow visual confirmation of contact lock-in for easy and secure insertion. • Low insertion force contact The low insertion force contacts reduce surface finish wear and reduce the effects of stress relaxation. • Anti-misinsertion feature The guide devices of both housing and header prevent reverse connector insertion. Crimp style receptacles that are designed to mate with headers conforming to MIL-C83503. The low insertion force contacts reduce surface finish wear and resist stress relaxation very well. Specifications ––––––––––––––––––– • Current rating: 1.0 A AC, DC (AWG #22) • Voltage rating: 300 V AC, DC • Temperature range: -55˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/15 mΩ max. After environmental tests/ 30 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #26 to #22 • Applicable PC board thickness: 1.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 RA CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Applicable wire Model No. RA-SC1290 mm2 AWG# Insulation O.D. (mm) Q't y/ reel 0.13 to 0.33 26 to 22 1.3 to 1.7 8,000 11.5 3.4 Material and Finish 1 4.45 1.8 Phosphor bronze, tin-plated (reflow treatment) 1.5 1.55 RoHS compliance Note: Contact JST for gold-plated contacts. Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits Model No. 10 RA-1011 RA-1611 RA-2011 RA-2611 RA-3011 RA-3411 RA-4011 RA-5011 RA-6011 Dimensions (mm) A B C 8 16 5 3 1 20 14.1 26 30 34 3.65 R JST 2.54 40 6.2 50 60 A B Q'ty/ box 10.16 17.50 8.75 500 17.78 25.12 12.56 500 22.86 30.20 15.10 500 30.48 37.82 18.91 500 35.56 42.90 21.45 200 40.64 47.98 23.99 500 48.26 55.60 27.80 200 60.96 68.30 34.15 200 73.66 81.00 40.50 200 Material Glass-filled PBT, UL94V-0, black C 2.54 RoHS compliance Header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– The following headers are applicable to the above Housing. RA header Circuits Top entry type Side entry type 10 RA-H101TD-1190 RA-H101SD-1190 16 RA-H161TD-1190 RA-H161SD-1190 20 RA-H201TD-1190 RA-H201SD-1190 26 RA-H261TD-1190 RA-H261SD-1190 30 RA-H301TD-1190 – 34 RA-H341TD-1190 RA-H341SD-1190 40 RA-H401TD-1190 RA-H401SD-1190 50 RA-H501TD-1190 RA-H501SD-1190 RA-H601TD-1190 RA-H601SD-1190 RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for gold-plated headers. 60 Crimping machine, Applicator––––––––––––––––––––––––––––––––––––––––––––––– Contact Crimping machine RA-SC1290 AP-K2N Crimp applicator Dies Crimp applicator with dies MKS-L MK/RA-SC12 APLMK RA-SC12 *MKS-SC *SC/RA-SC12 APLSC RA-SC12 Note: *Strip-crimp applicator 2
RA-1011
1. 物料型号:型号为EL817
2. 器件简介:EL817是一款光电耦合器,用于信号隔离和接口电路,具有高隔离电压和快速响应时间的特点。
3. 引脚分配:EL817有6个引脚,具体分配如下: - 1:发光二极管正极 - 2:发光二极管负极 - 3:输出晶体管集电极 - 4:输出晶体管发射极 - 5:输出晶体管基极 - 6:隔离层
4. 参数特性:主要参数包括工作电压范围3-24V,隔离电压5000Vrms,响应时间1.5us。
5. 功能详解:EL817通过光电效应实现输入和输出之间的隔离,输入端发光二极管发光,光信号被输出端光敏晶体管接收并放大,实现信号传输。
6. 应用信息:常用于数字通信、测量设备、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装。
RA-1011 价格&库存
很抱歉,暂时无法提供与“RA-1011”相匹配的价格&库存,您可以联系我们找货
RA-1011
    • 1+8.80000
    • 250+3.17020
    • 500+2.11310
    库存:2588
    RA-1011
      • 1+2.487581+0.32313
      • 100+2.03304100+0.26409
      • 300+1.69420300+0.22007
      • 500+1.62809500+0.21148
      • 1000+1.578501000+0.20504
      • 4000+1.537184000+0.19968
      • 5000+1.537185000+0.19968
      库存:246
