RA-4011
RA-4011
    JST
    P=2.54mm
    RA-4011
RA-4011 数据手册
Crimp Crimp 2.54 2.54 mm mm RA CONNECTOR Disconnectable Disconnectable Crimp Crimp style style connectors connectors pitch pitch Features ● Secure lock device The locking levers are engaged by inserting the receptacle into the header. This ensures a firm connection that's highly resistant to impact and vibration. RA RA CONNECTOR CONNECTOR ● Housing lances The contact retention lances on the resilient housing allow visual confirmation of contact lock-in for easy and secure insertion. ● Low insertion force contact The low insertion force contacts reduce surface finish wear and reduce the effects of stress relaxation. ● Anti-misinsertion feature Crimp style receptacles that are designed to mate with headers conforming to MIL-C-83503. The low insertion force contacts reduce surface finish wear and resist stress relaxation very well. The guide devices of both housing and header prevent reverse connector insertion. Specifications • Current rating: 1.0 A AC/DC (AWG #22) • Voltage rating: 300 V AC/DC • Temperature range: -55℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 30 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #26 to #22 • Applicable PC board thickness: 1.6 mm ® * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ® ® Standards ® ® 1 Recognized E60389 RA-CON RA CONNECTOR Contact Applicable wire Model No. RA-SC1290 11.5 3.4 4.45 1.8 AWG # Insulation O.D. (mm) Q'ty/ reel 0.13 to 0.33 26 to 22 1.3 to 1.7 8,000 Material and Finish RA CONNECTOR 1 1.5 mm2 Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: Contact JST for gold-plated contacts. 1.55 RA-APP Housing 8 No. of circuits 10 16 5 3 1 20 14.1 26 30 3.65 34 R JST 2.54 40 6.2 A 50 60 Dimensions (mm) A B C Model No. RA-1011 RA-1611 RA-2011 RA-2611 RA-3011 RA-3411 RA-4011 RA-5011 RA-6011 B Q'ty/ box 10.16 17.50 8.75 500 17.78 25.12 12.56 500 22.86 30.20 15.10 500 30.48 37.82 18.91 500 35.56 42.90 21.45 200 40.64 47.98 23.99 500 48.26 55.60 27.80 200 60.96 68.30 34.15 200 73.66 81.00 40.50 200 Material and Finish Glass-filled PBT, UL94V-0, black C 2.54 RoHS2 compliance RA-APP Header The following headers are applicable to the above Housing. RA header No. of circuits Top entry type Side entry type 10 RA-H101TD-1190 RA-H101SD-1190 16 RA-H161TD-1190 RA-H161SD-1190 20 RA-H201TD-1190 RA-H201SD-1190 26 RA-H261TD-1190 RA-H261SD-1190 30 RA-H301TD-1190 - 34 RA-H341TD-1190 RA-H341SD-1190 40 RA-H401TD-1190 RA-H401SD-1190 50 RA-H501TD-1190 RA-H501SD-1190 60 RA-H601TD-1190 RA-H601SD-1190 RoHS2 compliance This product displays (LF)(SN) on a label. Note: Contact JST for gold-plated headers. Crimping machine, Applicator Contact RA-SC1290 Crimping machine AP-K2N Crimp applicator Dies Crimp applicator with dies MKS-L MK/RA-SC12 APLMK RA-SC12 Note: Contact JST for fully automatic crimping applicator. 2
RA-4011 价格&库存
很抱歉,暂时无法提供与“RA-4011”相匹配的价格&库存,您可以联系我们找货
RA-4011
    • 200+2.25420
    库存:600
