556 SERIES
Rack And Panel Connectors
Features:
0.156” (3.96mm) contact spacing
Available in plug and receptacle.
Edacon hermaphroditic contact mating design
Contact termination options include crimp, P.C. tail, wire hole, wire wrap and taper tail
Tools available for contact installation, removal and crimping
RoHS Compliant
Specifications:
Insulator Material
Nylon UL 94V-0 , White Color
Contact Material
Copper Alloy
Contact Plating
Gold Plating over Nickel over entire contact
Current Rating
8.5 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
2000 V AC rms at sea level
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-40°C to +105°C
Insertion
2 to 16 oz (0.56 to 4.45N) per contact position
Withdrawal Force
Example Part Number:
556-003-500-102
Series
Total Number of Contacts
Contact Code
Style
Ordering Code Notes:
Crimp contacts are also available for 556 series connectors. Contacts may
be ordered separately for pre-wired or select position assembly.
Series:
556
Total Number of Contacts:
003
Contact Code:
Description:
Tail Size:
Tail Length "G":
000
No Contacts Assembled
500
Wire Hole
.110 x .024 (2.79 x 0.61)
.245 (6.22)
501
Taper Tail
.245 (6.22)
520
P.C. Tail
.025 x .024 (0.64 x 0.61)
.215 (5.46)
540
Wire Wrap
.050 x .024 (1.27 x 0.61)
.600 (15.24)
541
Wire Wrap
.026 x .024 (0.66 x 0.61)
.620 (15.70)
542
Wire Wrap
.790 (20.07)
Style & Material:
Style:
101
Receptacle
102
Receptacle with Panel Retention
201
Plug
www.edac.net
Part Number
Description
516-290-500
Wire Hole
516-290-501
Taper Tail
516-290-520
P.C. Tail
516-290-540
Wire Wrap
516-290-541
Wire Wrap
516-290-542
Wire Wrap
516-290-590
Crimp (Loose)
516-294-571
Crimp - 1800 Contact
Per Reel
Silhouette
For contact installation, removal and crimping tools, Please contact EDAC.
Insulator design prevents improper mating of individual plug and receptacle
customerservice@edac.net
556 SERIES
FEMALE CONNECTOR
(Hermaphroditic contacts)
MALE CONNECTOR
.156 [3.96]
.156 [3.96]
RECOMMENDED
PANEL OPENING
(If Desired)
.625 [15.88]
3 2 1
.240 [6.10]
A
.488 [12.40]
.495 [12.57]
RECOMMENDED
BOARD LAYOUT
.835 [21.21]
.875 [22.23]
.312 [7.92]
.156 [3.96]
? .042 [1.07]
CONNECTOR MATING FACE VIEWS
.240 [6.10]
.312 [7.91]
1.385 [35.18]
(When mated)
SNAP ACTION LOCK
(Holds mated parts
together)
PANEL MOUNTING
PANEL THICKNESS
.029 - .055"
(0.74 - 1.40)
Shown using 516-290-590 or
516-290-591 crimp style contacts
DYNAMIC HINGE
(For panel mounting)
"G"
Shown using 516-290-542 Contacts
www.edac.net
很抱歉,暂时无法提供与“556-003-000-101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.171261+1.45109
