567-001-000-310
567-001-000-310
567-001-000-310 数据手册
567 SERIES WATERPROOF WIRE TO WIRE & CONNECTORS Features: • • • • • • 5.0mm x 5.9mm pitch, rated current: 8A max Splashproof solution available in 1, 2, 3, 4, 6, or 9 positions Available in wire to wire options True crimp and poke solution with various sized wire seals available Available with wire already installed Splash Proof Grade: IP52 (JIS C0920) Certified Specifications: No. of Positions 1, 2, 3, 4, 6, or 9 Pitch 5.0 mm x 5.9 mm Rated Voltage 300 V Rated Current 8 amps maximum Dielectric Withstanding Voltage 1700 V AC (rms) Contact Resistance 10 millihoms maximum Insulation Resistance 1000 megaohms minimum/DC 500 V Operating Temperature -40°C to +105°C Ordering Code: Crimp Contact: 567-002-000-100 Male Contact (Pin) SERIES: 567, WIRE TO WIRE NO. OF CONTACTS: 001 - 1 CONTACT 002 - 2 CONTACTS 003 - 3 CONTACTS 004 - 4 CONTACTS 006 - 6 CONTACTS 009 - 9 CONTACTS Part No (Material) AWG# Ins. Dia. Pcs/Reel Part No (Material) AWG# Ins. Dia. Pcs/Reel 570-290-751 (Brass) 14 Max. Ø3.1 4,000 570-290-761 (Brass) 14 Max. Ø3.1 4,000 570-291-731 (Ph. Brz.) 20-16 Max. Ø3.1 4,000 570-291-741 (Ph. Brz.) 20-16 Max. Ø3.1 4,000 570-290-731 (Brass) 20-16 Max. Ø3.1 4,000 570-290-741 (Brass) 20-16 Max. Ø3.1 4,000 4,000 570-291-721 (Ph. Brz.) 22-20 Max. Ø2.7 4,000 570-290-721 (Brass) 22-20 Max. Ø2.7 4,000 570-290-711 (Brass) CONTACT CODE: 000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS) Female Contact (Socket) 22-20 Max. Ø2.7 STYLE: 310 - WHITE MALE HOUSING FOR CRIMP CONTACTS 410 - WHITE FEMALE HOUSING FOR CRIMP CONTACTS Materials: Housing PBT, UL 94V-0 Contact Ph. Brz. or Brass Contact Plating Tin Plating Wire & Housing Seals Silicone Rubber Wire Seal: Assembly Layout: Part No. Wire O.D. Color AWG# Ø Dia. Height 570-260-001 Ø1.7~Ø2.1 Black 22 Ø 5.0 6.0 570-260-002 Ø2.1~Ø2.7 Light Blue 22-20 Ø 5.0 6.0 570-260-003 Ø2.1~Ø2.7 Blue 22-20 Ø 5.0 6.7 570-260-004 Ø2.7~Ø3.1 Brown 20-14 Ø 4.9 5.0 570-260-002 570-260-001 www.edac.net 570-260-004 570-260-003 customerservice@edac.net 567 SERIES WATERPROOF WIRE TO WIRE & CONNECTORS Male Housing: 567-001-000-310 567-002-000-310 567-003-000-310 567-004-000-310 567-006-000-310 567-009-000-310 567-001-000-410 567-002-000-410 567-003-000-410 567-004-000-410 567-006-000-410 567-009-000-410 Female Housing: www.edac.net customerservice@edac.net
567-001-000-310 价格&库存
很抱歉,暂时无法提供与“567-001-000-310”相匹配的价格&库存,您可以联系我们找货
  • 250+10.87128250+1.40523
