REVISION Q
ISDF-XX-D-X
(No OF POS x .050[1.27])
+ .223[5.66] REF
DO NOT
SCALE FROM
THIS PRINT
OPTIONS
LEAVE BLANK
-M: METAL RETENTION LATCH
(SEE FIG 1)
-S: DUAL SCREW DOWN
ROW SPECIFICATION
(SEE SHT 2, FIG 2)
-D: DOUBLE
-C: CHAMFER
(SEE SHT 3, FIG 3)
(7 POSITION ONLY)
-L: FRICTION LOCK
(SEE SHEET 3, FIG 4)
(AVAILABLE ON POS *-05,
*-07,-10 THRU -50)
(*=NOT AVAILABLE WITH POLARIZATION KEY)
No OF POSITIONS
-02 THRU -50
(PER ROW)
+ .145[3.68] REF
CL
.250 6.35
REF
.050 1.27
REF
CL
.120 3.05
REF
.145 3.68
REF
.180 4.57
REF
ISDF-XX-D-R
.080 2.03 REF
.050 1.27
REF
+ .015[0.38] REF
.080 2.03
REF
C
+.008 [+0.20]
(No OF POS x .050[1.27] + .145[3.68]) - .012 [- 0.30]
CL
+.004
+0.10
.065 - .008 1.65 - 0.20 C
.113 2.86
PACKAGING VIEW
-M OPTION
CL
.050 1.27 REF
C
.010 0.25 REF
.440 11.18
REF
SUB-IM-LTC-07-01-N
(2 PLCS)
.249 6.32
REF
FIG 1
TUBE: PT-1-24-02-44
PLUG: TP-03
ISDF-05-D-M SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. LATCH RETENTION FORCE: .5 LB [2.22N].
3. PARTS TO BE PACKAGED IN TUBES.
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 V-0, COLOR: BLACK
LATCH: NICKEL-PLATED BeCu
BUTTON: NYLON, COLOR: WHITE
F:\DWG\MISC\MKTG\ISDF-XX-D-X-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050[1.27] DISCRETE WIRE INSULATOR & LATCH ASM
DWG. NO.
ISDF-XX-D-X
BY: BRATCHER 11/16/2006
SHEET 1 OF 3
REVISION Q
((No OF POS X .050 [1.27]) + .600 [15.24])REF
C
((No OF POS X .050 [1.27]) + .360 [9.14])
"B"
.125 3.18
REF
CL
"B"
DETAIL 'A'
SCALE 8 : 1
.225 5.72
REF
.218 5.52 REF
CL
((No OF POS X .050 [1.27]) + .015 [0.38]) REF
R.057 1.45 REF
ACCRT-01
CPS-RR-M2-01-X
.079 2.00 REF
ISDF-XX-D-DS
'A'
CL
C
.145 3.68
.070 1.78 REF
SECTION "B"-"B"
SCALE 8 : 1
.340 8.64
REF
PACKAGING VIEW
-S OPTION
FIG 2
-S: DUAL SCREW DOWN OPTION
ISDF-10-D-S SHOWN
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
PROPRIETARY NOTE
TUBE: PT-1-24-08-15
PLUG: TP-03
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
ISDF-XX-D-X
SHEET 2 OF 3
REVISION Q
PACKAGING VIEW
LEAVE BLANK & -C OPTIONS
02 04 06 08 10 12 14
01 03 05 07 09 11 13
FIG 3
ISDF-07-D-C SHOWN
TUBE: PT-1-24-02-44
PLUG: TP-03
PACKAGING VIEW
"C"
"C"
-L OPTION
SECTION "C"-"C"
TUBE: PT-1-24-02-44
PLUG: TP-03
FIG 4
ISDF-25-D-L SHOWN
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
ISDF-XX-D-X
BY: BRATCHER
11/16/2006 SHEET 3 OF 3
很抱歉,暂时无法提供与“ISDF-03-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.89520
- 137+5.15160
- 548+4.97880
- 959+4.89240
