ISDF-25-D
ISDF-25-D
    SAMTEC(申泰)
    P=1.27mm
    2X25P 1.27MM
ISDF-25-D 数据手册
REVISION Q ISDF-XX-D-X (No OF POS x .050[1.27]) + .223[5.66] REF DO NOT SCALE FROM THIS PRINT OPTIONS LEAVE BLANK -M: METAL RETENTION LATCH (SEE FIG 1) -S: DUAL SCREW DOWN ROW SPECIFICATION (SEE SHT 2, FIG 2) -D: DOUBLE -C: CHAMFER (SEE SHT 3, FIG 3) (7 POSITION ONLY) -L: FRICTION LOCK (SEE SHEET 3, FIG 4) (AVAILABLE ON POS *-05, *-07,-10 THRU -50) (*=NOT AVAILABLE WITH POLARIZATION KEY) No OF POSITIONS -02 THRU -50 (PER ROW) (No OF POS x .050[1.27]) + .145[3.68] REF CL .250 6.35 REF .050 1.27 REF CL .120 3.05 REF .145 3.68 REF .180 4.57 REF ISDF-XX-D-R .080 2.03 REF .050 1.27 REF (No OF POS x .050[1.27]) + .015[0.38] REF .080 2.03 REF C +.008 [+0.20] (No OF POS x .050[1.27] + .145[3.68]) - .012 [- 0.30] CL +.004 +0.10 .065 - .008 1.65 - 0.20 C .113 2.86 PACKAGING VIEW -M OPTION CL .050 1.27 REF C .010 0.25 REF .440 11.18 REF SUB-IM-LTC-07-01-N (2 PLCS) .249 6.32 REF FIG 1 TUBE: PT-1-24-02-44 PLUG: TP-03 ISDF-05-D-M SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. LATCH RETENTION FORCE: .5 LB [2.22N]. 3. PARTS TO BE PACKAGED IN TUBES. ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 V-0, COLOR: BLACK LATCH: NICKEL-PLATED BeCu BUTTON: NYLON, COLOR: WHITE F:\DWG\MISC\MKTG\ISDF-XX-D-X-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050[1.27] DISCRETE WIRE INSULATOR & LATCH ASM DWG. NO. ISDF-XX-D-X BY: BRATCHER 11/16/2006 SHEET 1 OF 3 REVISION Q ((No OF POS X .050 [1.27]) + .600 [15.24])REF C ((No OF POS X .050 [1.27]) + .360 [9.14]) "B" .125 3.18 REF CL "B" DETAIL 'A' SCALE 8 : 1 .225 5.72 REF .218 5.52 REF CL ((No OF POS X .050 [1.27]) + .015 [0.38]) REF R.057 1.45 REF ACCRT-01 CPS-RR-M2-01-X .079 2.00 REF ISDF-XX-D-DS 'A' CL C .145 3.68 .070 1.78 REF SECTION "B"-"B" SCALE 8 : 1 .340 8.64 REF PACKAGING VIEW -S OPTION FIG 2 -S: DUAL SCREW DOWN OPTION ISDF-10-D-S SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING TUBE: PT-1-24-08-15 PLUG: TP-03 SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\ISDF-XX-D-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050[1.27] DISCRETE WIRE INSULATOR & LATCH ASM DWG. NO. ISDF-XX-D-X BY: BRATCHER 11/16/2006 SHEET 2 OF 3 REVISION Q PACKAGING VIEW LEAVE BLANK & -C OPTIONS 02 04 06 08 10 12 14 01 03 05 07 09 11 13 FIG 3 ISDF-07-D-C SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) TUBE: PT-1-24-02-44 PLUG: TP-03 PACKAGING VIEW "C" "C" -L OPTION SECTION "C"-"C" TUBE: PT-1-24-02-44 PLUG: TP-03 FIG 4 ISDF-25-D-L SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\ISDF-XX-D-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050[1.27] DISCRETE WIRE INSULATOR & LATCH ASM DWG. NO. ISDF-XX-D-X BY: BRATCHER 11/16/2006 SHEET 3 OF 3
ISDF-25-D 价格&库存
很抱歉,暂时无法提供与“ISDF-25-D”相匹配的价格&库存,您可以联系我们找货
ISDF-25-D
  • 1+17.842211+2.30949
  • 50+13.8340250+1.79067
  • 100+11.17190100+1.44609
  • 500+10.15837500+1.31490
库存:67
ISDF-25-D
    • 1+11.98800
    • 10+11.62080
    • 34+11.38320
    • 102+11.14560
