566-002-000-811
566-002-000-811
566-002-000-811 数据手册
566 SERIES WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS Features: • • • • • • • • 2.0mm pitch, rated current: 2A max Fully waterproof solution available in 2, 3, 4, or 6 positions (2 and 3 positions only for wire to board) Available in wire to wire and wire to board options Seals preassembled into housing; no external sealing required True crimp and poke solution Waterproofing cap available to cover unused positions Available with wire already installed Waterproof Grade: IP67 Certified Specifications: No. of Positions 2, 3, 4, or 6 Pitch 2.0 mm Rated Voltage 250 V Rated Current 2 amps maximum Dielectric Withstanding Voltage 1000 V AC (rms) Contact Resistance 10 milliohms maximum Insulation Resistance 1000 megaohms minimum/DC 500 V Operating Temperature -40°C to +105°C PCB Thickness 1.6 mm Ordering Code: Crimp Contact: 566-002-000-710 Male Contact (Pin) SERIES: 566, WIRE TO WIRE WIRE TO BOARD NO. OF CONTACTS: 002 - 2 CONTACTS 003 - 3 CONTACTS 004 - 4 CONTACTS 006 - 6 CONTACTS Female Contact (Socket) Part No AWG# Ins. Dia. Pcs/Reel Part No AWG# Ins. Dia. Pcs/Reel 566-290-711 22-28 Ø1.0~Ø1.5 12,000 566-290-721 22-28 Ø1.0~Ø1.5 12,000 **Crimp Contacts are also available in strips of 60pcs. Contact EDAC for more information. **Wire seals and housing seals are already pre-assembled in the connector. CONTACT CODE: 000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS) 421 - BOARD MOUNT CONTACTS (PCB) ONLY FOR 2 & 3 PIN SIZE STYLE: 701 - BLACK MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS) 710 - BLACK MALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.25 711 - BLACK MALE HOUSING FOR WIRE INSULATION Ø1.25 TO Ø1.50 810 - BLACK FEMALE HOUSING FOR WIRE INSULATION Ø1.00 TO Ø1.25 811 - BLACK FEMALE HOUSING FOR WIRE INSULATION Ø1.25 TO Ø1.50 Rear Gasket (Wire Seal): Materials: Crimp & Poke PCB Header Housing PBT, UL 94V-0 Contact Phosphor Bronze Housing PBT with Glass, UL 94V-0 Contact Brass Contact Plating Tin Plating Wire & Housing Seals Silicone Rubber Waterproofing Cap PBT, UL 94V-0 Waterproofing Cap: Part No. Applicable Contact Wire O.D. Color 566-290-711 566-290-721 Ø1.00 to Ø1.25 Light Blue Ø1.25 to Ø1.50 Orange Assembly Layout: PIN SIZE: A (mm) LENGTH: 2P, 3P, 4P 28.85 6P 29.05 Waterproofing Cap 566-200-100 A www.edac.net customerservice@edac.net 566 SERIES WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS Female Housing: Male Housing: Female Housing: Male Housing: 566-002-000-XXX 566-002-000-XXX 566-003-000-XXX 566-003-000-XXX 566-004-000-XXX 566-004-000-XXX PCB Header PCB Header 566-002-421-701 566-003-000-XXX 2.8±0.1 566-006-000-XXX 0.0 .8 ± RECOMMENDED PCB LAYOUT Ø1.0± 0.05 1.6±0.1 566-006-000-XXX Male Housing: Female Housing: Ø Wire Insulation Housing Color XXX Ø Wire Insulation Housing Color XXX "Ø1.00 to Ø1.25" Black 710 "Ø1.00 to Ø1.25" Black 810 "Ø1.25 to Ø1.50" Black 711 "Ø1.25 to Ø1.50" Black 811 www.edac.net Ø0 2.0±0.05 5 ±0.1 2x(N-1) customerservice@edac.net
566-002-000-811 价格&库存
很抱歉,暂时无法提供与“566-002-000-811”相匹配的价格&库存,您可以联系我们找货
