SAG.H51.LLZBG
SAG.H51.LLZBG
    LEMO(雷莫)
    CONN INLINE PLUG 51POS SKT HSG
SAG.H51.LLZBG 数据手册
HIGH VOLTAGE CONNECTORS FOR SPECIAL APPLICATIONS ® ® 05 Series 5G Series ® REDEL Kft ® K and S Series No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO reserve the right at all times to modify and improve specifications without any notification. ® ® 05 Series Connectors High voltage connectors of the new 05 miniature series have been specifically developed to meet the requirements of experimental nuclear research programme. The 05 series contains a miniature HV 12kV d.c. (test voltage) contacts. This crimp contact is removable from the shell and is inserted in a PEEK insulator. The actual mating is provided by the LEMO Push-Pull system, renowned for its reliability worldwide and a red safety nut to secure the connection. The compact design of these connectors makes them ideal for applications where minimal mass and space saving are critical factors. Interconnections Straight plug FFR Fixed socket PES LEMO’s Push-Pull Self-Latching Connecting System This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. For added security a safety nut (shown in red) can prevent disengagement by blocking the motion of the outer release sleeve. 1 ® ® Part Section Showing Internal Components Connector Straight plug Fixed socket 7 1 2 3 4 5 6 7 1 2 3 6 5 4 8 6 3 1 5 4 2 7 1 shell crimp back end hexagonal nut conical nut insulator HV female contact crimp ferrule 2 3 4 5 6 7 8 outer shell latch sleeve safety nut crimp back end insulator HV male contact crimp ferrule earthing crown HV Contact 2 Male contact 3 1 1 4 3 2 Female contact 1 male contact 1 female contact 2 insulator 2 insulator 3 clips 3 clips 4 sealing gland Technical characteristics Mechanical and climatical Characteristic Electrical characteristics Value Contact retention force Working temperature Mechanical life Climatic class Radiation resistance Standard 40 N IEC 60512-8 test 15a -20 °C to +125°C > 200 cycles IEC 60512-5 test 9a 20/125/21 IEC 60068-1 > 10 6 Gy Characteristic Test voltage d.c.1) Rated current Contact resistance Screen resistance Insulation resistance Value Standard 12 kV (1 min.) 4A ≤ 8 mΩ ≤150 mΩ ≥ 1012 Ω IEC 60512-2 test 4a IEC 60512-3 test 5a IEC 60512-2 test 2a IEC 60512-2 test 2f IEC 60512-2 test 3a Note: 1) specific assembly instructions shall be respected. (see page 6 and 7) Materials and Treatment – Connector Component Material (standard) Contact Surface treatment (µm) Component Material (standard) Ni Outershell + crimpend Safety nut Earthing crown Latch sleeve Hex and conical nut Insulator Crimp ferrule 2 Aluminium (AA 6012) Aluminium (AA 6012) Aluminium special Aluminium special Aluminium (AA 6012) PEEK Aluminium (AA 6012) 5 Anodized red 5 5 Anodized natural – 5 Male contact Female contact Contact clips Insulator Sealing gland Surface treatment (µm) Cu Ni Au Brass (UNS C38500) 0.5 3 1.0 Bronze (UNS C54400) Cu-Be (QQ-C-530) PEEK Silicone PVMQ 0.5 3 – – – 1.5 ® ® Models FFR Straight plug for cable crimping, with safety nut 42 Cable group FFR.05.403.LLAE141 FFR.05.403.LLAE142 1 2 ø6 29.8 Part Number PES Fixed socket, with two nuts, for cable crimping Part Number Cable group PES.05.403.LLLE141 PES.05.403.LLLE142 1 2 42 8.5 max. ø 9.2 2.5 ø 8.5 S8 M6.5x0.6 S 5.7 S7 Recommanded high voltage cables Construction and dimensions Dielectric Screen Mat. ø Mat. Cable group Manufacturer Part Number CERN Type Conductor Constr. Mat. ø 1 ABBNK - 45/94 HTC 50-1-1 7x0.17 CuSn 0.51 PE solid 1.5 2 HABIA 31789-004-001 HFI 150 mini coax Mono 0.16 HFI 150 0.5 Cu CuSn 16x4x0.1 Sheath Mat. ø Polyolefine Corona screen 3.3 yes Drain 2x0.1 HFI 150 1.15 + Alu polyester no 3 ® ® Accessories FFA-ERA High Voltage Contacts Contact Part Number Male contact Female contact FFA.05.403.ZLA1 FFA.05.403.ZLA2 male L Cable group L (mm) 1 2 4 6 ERA.05.403.ZLL1 ERA.05.403.ZLL2 female GMA Heatshrink tube ø D min. Shall be ordered separately L Part number Cable group GMA.30.010.ST GMA.15.010.ST 1+2 2 Name Supplier Product reference RAYCHEM® RNF 3000 3/1 RAYCHEM® RNF 3000 1.5/0.5 øD L (mm) (mm) 3.0 1.5 Note: for cable group 2, the two heatshrink tubes are necessary ● Material: Polyolefin transparent FFS Crimp ferrule 10 ø 4.1 Model 1 Part number FFS.05.160.PM FFS.05.161.PM 10 Cable group Model 1 2 1 2 ø 1.4 Model 2 ● Material: Aluminium alloy (AA6012) nickel plated GEC Conical nut 7 M 6.5 x 0.6 2.5 ø 8.5 Part number GEC.05.241.PT ● Material: Aluminium alloy (AA 6012) natural anodized. GEA Hexagonal nuts 8 M 6.5 x 0.6 2 9.2 Part number GEA.05.241.PT ● Material: Aluminium alloy (AA 6012) natural anodized. 4 13 9 ® ® Tooling DCH Spanner for conical nut 39.7 37 Part Number DCH.91.113.9TN ø 11 ● Material: Blackened steel. DCF Extraction tools for HV contacts Part Number DCF.91.133.5LT Automatic model DPH Crimping tool with die and positioner Part Number DPH.99.005.2K DPH.99.060.11K DPH.99.065.11K Applications Cable group Marking on die 1-2 1 2 DPH.91.005.2K DPH.91.001.16K DPK.91.001.16K Cable group Marking on die 1-2 1 2 DPH.91.005.2K DPH.91.001.16K DPK.91.001.16K shield centre contact centre contact DPN Dies and positioner Part Number DPN.99.005.2K DPN.99.060.11K DPN.99.065.11K Applications shield centre contact centre contact ● Dies material: Blackened steel Panel cut-out ø 6.6 + 0.1 0 10 min. 5.8 + 0.1 0 Recommended mounting nut torque: 0.8 Nm. 5 ® ® Termination Instructions Cable Group 1 5 3 4 FFR 1 5 3 4 PES 1. Strip the cable according to the given dimensions, remove carefully the cable corona screen, making sure that the cable dielectric is not damaged. Remove also the aluminium foil and the textile tape. Clean the dielectric with isopropylic alcool. ±0.2 9 3 ±0.2 3.5 ±0.2 Dimensions in mm. 3 Apply laquer 4 1 Crimp 4 3 1 A Apply laquer 4 3 2. Place the crimp ferrule ➀ on the cable. Widen completely the shield braid and fold it back over the jacket. Introduce the cable center conductor into the HV contact ➃ until the contact end rests against the dielectric and the conductor is visible through the contact inspection hole. Crimp with the LEMO crimping tool DPH.99.060.11K. Cover the crimp section of the contact and the Peek end of the HV contact with a layer of insulating laquer. Let the laquer dry, approx.15 min. Note: We recommand the laquer Urethan ref: Cellpack n° 912110 3. Slide the heatshrink tube ➂ over the HV contact until it rests against the contact insulator. One end of the heatshrink tube shall be located at the position A of the HV contact insulator. Shrink the tube. Shrink A 4 3 Shrink 5 1 5 1 5. Slide the crimp ferrule over the cable shield until it rests against the connector shell. Crimp with the LEMO crimping tool DPH.99.005.2K. 5 Crimp 5 Crimp 6 4. Fully introduce the HV contact into the connector shell ➄. Check that the contact is correctly located and remains in position when given a gentle pull. Place the cable shield braid strand over the shell crimp back end, cut the length of braid in excess. ® ® Termination Instructions Cable Group 2 5 3 4 2 FFR 1 5 3 4 2 PES 14 ±0.2 1. Strip the cable according to the given dimensions, cut the aluminium foil making sure that the dielectric is not damaged. Do not damage the 2 drain wires. Fold the drain wires back over the outer jacket and slide over the small heatshrink tube ➁. Clean the dielectric with isopropylic alcool. 10 ±0.2 3 ±0.2 2 Dimensions in mm. 3 Apply laquer 4 2 1 Crimp B A 3 2 4 Apply laquer 4 3 1 Shrink Shrink 3. Slide the heatshrink tube ➂ over the HV contact until it rests against the contact insulator. One end of the heatshrink tube shall be located at the position A of the HV contact insulator. Shrink the tube. 1 A 4 3 2. Place the crimp ferrule ➀ introducing first the small diameter on the cable. Introduce the cable center conductor and a part of the dielectric into the HV contact ➃ until the conductor is fully visible through the contact inspection hole. Crimp with the LEMO crimping tool DPH.99.065.11K. Cover the crimp section of the contact and a short length of the dielectric with a layer of insulating laquer. Let the laquer dry, approx. 15 min. Note: We recommand the laquer Urethan ref: Cellpack n° 912110 Slide the heatskrink tube ➁ over the HV contact until it rests against the contact insulator at the position B. Shrink the tube. Cover the Peek end of the HV contact and the first heatshrink tube with a layer of the insulating laquer. Let the laquer dry, approx. 15 min. 1 Shrink 5 4 3 1 4. Fully introduce the HV contact into the connector shell ➄. Check that the contact is correctly located and remains in position when given a gentle pull. Place the 2 drain wire around the shell crimp back end. A 5 4 3 5. Slide the crimp ferrule over the cable shield until it rests against the connector shell. Crimp with the LEMO crimping tool DPH.99.005.2K. 5 5 1 Crimp Crimp 7 ® ® 5G Series Connectors High voltage cylindrical connectors of the new 5G series have been specifically developed to meet the requirements of the “ATLAS” experimental nuclear research programme at the CERN. The 5G series contains 50 miniature HV 12kV d.c. (test voltage) contacts. These crimp contacts are removable from the shell and are inserted in a PEEK insulator. The same HV contacts are used in the 05 series. The actual mating is provided by the LEMO Push-Pull system, renowned for its reliability worldwide and a red safety nut to secure the connection. Two keying alternative (code R or W) are available. The compact design of these connectors makes them ideal for applications where minimal mass and space saving are critical factors. Interconnections Straight plug Fixed socket DANGER DANGER FG PH LEMO’s Push-Pull Self-Latching Connecting System DANGER DANGER This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. For added security a safety nut (shown in red) can prevent disengagement by blocking the motion of the outer release sleeve. 8 ® ® Part Section Showing Internal Components Connector 8 7 2 1 4 5 3 6 10 9 8 2 7 4 3 1 2 3 4 5 5 DANGER DANGER Fixed socket 1 6 Straight plug outer shell earthing crown retaining ring clamp collet nut round nut conical nut 7 adapter w. cable collet 8 keyed mid-piece 9 insulator 10 HV male contact 6 1 2 3 4 5 outer shell latch sleeve safety nut clamp collet nut 6 7 8 adapter w. cable collet keyed mid-piece insulator HV female contact HV Contact 2 Male contact 3 1 1 4 3 2 Female contact 1 male contact 1 female contact 2 insulator 3 clips 4 sealing gland 2 insulator 3 clips Technical characteristics Mechanical and climatical Characteristic Electrical characteristics Value Contact retention force Working temperature Mechanical life Climatic class Radiation resistance Standard 40 N IEC 60512-8 test 15a -20 °C to +125°C > 100 cycles IEC 60512-5 test 9a 20/125/21 IEC 60068-1 >106 Gy Characteristic Test voltage d.c.1) Rated current Contact resistance Screen resistance Insulation resistance Value Standard 12 kV (1 min.) 4A ≤ 8 mΩ ≤150 mΩ ≥ 1012 Ω IEC 60512-2 test 4a IEC 60512-3 test 5a IEC 60512-2 test 2a IEC 60512-2 test 2f IEC 60512-2 test 3a Note: 1) specific assembly instructions shall be respected. Materials and Treatment – Connector Component Material (standard) Contact Surface treatment (µm) Component Material (standard) Ni Outershell + collet nut Safety nut Earthing crown Latch sleeve Round and conical nut Insulator Other metallic pieces Aluminium (AA 6012) Aluminium (AA 6012) Aluminium special Aluminium special Aluminium (AA 6012) PEEK Aluminium Anodized natural Anodized red 5 5 Anodized natural – Anodized natural Male contact Female contact Contact clips Insulator Sealing gland Surface treatment (µm) Cu Ni Au Brass (UNS C38500) 0.5 3 1.0 Bronze (UNS C54400) Cu-Be (QQ-C-530) PEEK Silicone PVMQ 0.5 3 – – – 1.5 9 ® ® Alignment key and polarized keying system β α Ref. HV contact type α β γ δ Plug Socket R yellow 110° 105° 25° 35° male female W red 95° 115° 20° 30° female male ●● δ Angle Dot Colour γ ●● Front view of a socket Models FG● Straight plug with keys (code R or W), cable clamp-collet and safety nut Part Number Cable Group 67 FGR.5G.450.LLAY5T1 FGR.5G.450.LLAY5T2 FGW.5G.450.LLLY5T1 FGW.5G.450.LLLY5T2 ø 35 DANGER Cable ø 14.0 min. 16.5 max. 52 1 2 1 2 S 30 S 31 PH● Fixed socket with keys (code R or W), cable clamp-collet, 2 nuts fixing (back panel mounting) S 37 ~64.7 S 30 S 31 Part Number Cable Group PHR.5G.450.LLLY5T1 PHR.5G.450.LLLY5T2 PHW.5G.450.LLAY5T1 PHW.5G.450.LLAY5T2 1 2 1 2 5 ø 41 Cable ø 14.0 min. 16.5 max. DANGER ø 35 5 max. S 33.5 Recommanded high voltage cables Cable group Manufacturer Part Number 1 SILISOL CEPMB 56x0.12 mm2 1 ABBNK - 45/94 2 HABIA 31789-004-001 10 CERN Type Type/Nb. of conductor Conductor Constr. Mat. ø Construction and dimensions Dielectric Screen Mat. ø Mat. Sheath Mat. ø Corona screen Multi/56 7x0.15 CuSn 0.45 PE 1.5 CuSn + Alu Silic 14.5 no HTC 50-1-1 Mono/1 7x0.17 CuSn 0.51 PE solid 1.5 CuSn 16x4x0.1 Polyolefine 3.3 yes HFI 150 mini coax Mono/1 Mono 0.16 HFI 150 0.5 Cu Drain 2x0.1 HFI 150 1.15 + Alu polyester no ® ® Accessories FFA-ERA HV Contacts Contact Part Number Male contact Female contact FFA.05.403.ZLA1 FFA.05.403.ZLA2 male L ERA.05.403.ZLL1 ERA.05.403.ZLL2 Cable group L (mm) 1 2 4 6 female GMA Heatshrink tube ø D min. Shall be ordered separately L Part number Cable group GMA.30.010.ST GMA.15.010.ST 1+2 2 Name Supplier Product reference RAYCHEM® RNF 3000 3/1 RAYCHEM® RNF 3000 1.5/0.5 øD L (mm) (mm) 3.0 1.5 13 9 Note: for cable group 2, the two heatshrink tubes are necessary ● Material: Polyolefin transparent GEC Conical nut 37 5 M 35 x 1 ø 41 Part number GEC.5G.240.PT ● Material: Aluminium alloy (AA6012) natural anodized GEB Round nut ø 40 8 M 35 x 1 Part number GEB.5G.240.PT ● Material: Aluminium alloy (AA6012) natural anodized FGG Extension piece 36 ø 29 ø 27.9 Part Number FGG.5G.815.PN Note: allows an extension of the plug or the socket to make cable stripping and mounting easier when weight and size are not critical ● Material: Aluminium alloy (AA6012) natural anodized 11 ® ® Tooling DCH Spanner for conical nut 81.5 90 Part Number DCH.91.418.0TN ø 45 ● Material: Blackened steel. DCP Set of flat spanners for collet nuts and round nuts 54 31.1 30.1 3.5 Part Number 160 DCP.91.005.TN ● Material: Blackened steel. DCF Extraction tools for HV contacts Part Number DCF.91.133.5LT Automatic model DPH Crimping tool with die and positioner Part Number DPH.99.005.2K DPH.99.060.11K DPH.99.065.11K Applications shield centre contact centre contact Cable group Marking on die 1-2 1 2 DPH.91.005.2K DPH.91.001.16K DPK.91.001.16K Note: DPN Dies and positioner: See 05 series data sheet. Panel cut-out 0 ø 35.2 + 0.1 42 min. 33.5 12 + 0.1 0 Recommended mounting nut torque: 7 Nm. ® ® Termination Instructions Cable Group 1 (multi HT cable) 5 7 3 4 6 FG• 7 5 PH• 4 2 1. Strip the cable according to the given dimensions. A 500 mm length is necessary to give enough flexibility to the cable. Remove first the outer jacket and the screen then the dielectric of each individual high-voltage conductor, making sure that the cable dielectric is not damaged. 500 24 3.5 3 1 ±0.2 Dimensions in mm. 1 55 55 2. Slide 2 pieces of 55mm heat-shrink tubing, (not supplied) of the correct size, the clamp collet nut ➀ and the adapter with cable collet ➁ on the cable. 2 Apply laquer 3 4 Crimp A 3 3. For each individual high-voltage conductor install a HV contact as follow: 4 Crimp 3.1 Introduce the cable center conductor into the HV contact ➃ until the conductor end rests against the dielectric and the conductor is visible through the contact inspection hole. Crimp with the LEMO crimping tool DPH.99.060.11K. Cover the crimp section of the contact and the Peek end of the HV contact with a layer of insulating laquer. Let the laquer dry, approx. 15 min. Note: We recommand the laquer Urethan ref: Cellpack n° 912110 Apply laquer 4 3 Shrink 3 Shrink 3.2 Slide the heatshrink tube ➂ over the HV contact until it rests against the contact insulator. One end of the heatshrink tube shall be located at the position A of the HV contact insulator. Shrink the tube. A 4 13 ® ® 4. Fully introduce the HV contacts into the insulator ➄. – The short insulator shall be fitted with the female HV contacts. – The long insulator shall be fitted with the male HV contacts. Check that the contacts are correctly located and remains in position when given a gentle pull. 5 5 solder 5. Install a ground wire (not supplied) as follow: ground wire L = 130 mm 5.1 Wrap a tin copper wire 0.5 mm2 over a 6 mm length of the cable screen and hold the ground wire as shown. Then solder. Solder an earthing washer with a 3.5 mm hole on the other side. 6 solder ground wire L = 130 mm 6 Shrink Shrink 25 55 5.2 Cover the end of the cable screen with the first heatshrink tube and the end of the cable jacket with the second heat-shrink tube, then shrink. 55 Shrink Shrink 25 55 55 6 2 6. Push the adapter with cable collet ➁ forward over the cable until the insulator locate into the groove on the adapter. Then fit the keyed mid-piece ➅ onto the insulator, make sure that the key of the insulator is correctly located into the key of the mid-piece. 6 2 14 7 1 7 1 7. Next slide the connector shell ➆ over the insulator assembly making sure that the key on the keyed mid piece goes into the key-way (under the color point/inside the shell). – Note that the HV contact type shall be respected depending upon the keying code as indicated on page 10. Screw the collet nut ➀ and tighten to the maximum torque value of 4 Nm. Tight the two screws of the adapter and in between on an appropriate manner the washer of the ground wire. REDEL Elektronika Kft K and S Series Connectors High voltage rectangular connectors of the new K and S series have been specially developed to meet the requirements of the “ATLAS” experimental nuclear research programme at the CERN. The K series contains 22 miniature HV contacts (12kV d.c. test voltage). The S series contains 51 miniature HV contacts (12kV d.c. test voltage). These crimp contacts are removable from the shell and are inserted in a PEEK insulator. The mating is assured by guide pins and sleeves. Two red sliding tabs secure the connection by locking a pair of levers to a bracket mounted on the housing. The rectangular design of these connectors makes them ideal for applications where space saving is critical; for example on narrow panels. INTERCONNECTION KR/SR REDEL KL/SL KA/SA REDEL KAG.H22 REDEL 3 KLG.H22 REDEL 3 KAG.H22 KLG.H22 REDEL SELF-LATCHING CONNECTING SYSTEM 1 1 Straight plug KAG.H22 REDEL KRG.H22 REDEL Fixed socket KLG.H22 Straight socket 1 The REDEL Self-Latching connecting system allows the connectors to be mated by simply pushing the plug axially into the socket The connectors are disengaged by pressing down on the latch levers and then withdrawing the plug from the socket Once latched, connection cannot be broken by pulling on the cable or 2 any other component part REDEL KAG.H22 REDEL 4 KLG.H22 REDEL KAG.H22 REDEL 2 KLG.H22 1 For added security two red tabs can be slid forward, locking the latch levers 4 in place. 2 ALIGNMENT KEY Code G Code A KRA/SRA KLA/SLA REDEL KAA.H22 REDEL KLA.H22 REDEL KLG.H22 KAG.H22 KAG/SAG REDEL Modification 08.05 KLG/SLG KRA.H22 REDEL KRG.H22 KRG/SRG REDEL 2 KAA/SAA 15 REDEL Kft PART SECTION SHOWING INTERNAL COMPONENTS Connector Rectangular plug 7 6 1 8 5 2 3 4 7 6 5 3 2 4 8 9 1 11 10 Rectangular socket 1 2 5 6 7 8 3 4 .H22 3 4 outer shell insulator HV male contact male guide pin threaded insert cable clamp earthing insert earthing tag 5 KAG 1 2 6 7 8 9 10 11 outer shell latch lever locking clip security tab insulator HV female contact female guide pin threaded insert cable clamp earthing insert earthing tag HV Contact 2 Male contact 3 1 1 4 3 2 Female contact 1 male contact 1 female contact 2 insulator 3 clips 4 sealing gland 2 insulator 3 clips TECHNICAL CHARACTERISTICS Mechanical and climatical Characteristic Value Contact retention force Working temperature Mechanical life Climatic class Radiation resistance Electrical characteristics Standard 40 N IEC 60512-8 test 15a -20 °C to +125°C > 100 cycles IEC 60512-5 test 9a 20/125/21 IEC 60068-1 > 106 Gy Characteristic Test voltage d.c.1) Rated current Contact resistance Screen resistance Insulation resistance Value 9/12 kV (1 min.) 4A ≤ 8 mΩ ≤150 mΩ ≥ 1012 Ω Standard IEC 60512-2 test 4a IEC 60512-3 test 5a IEC 60512-2 test 2a IEC 60512-2 test 2f IEC 60512-2 test 3a Note: 1) specific assembly instructions shall be respected. 9 kV dc apply to the pair KA●/KL● and SA●/SL●. 12 kV dc apply to the pair KA●/KR● and SA●/SR●. Contact Materials and Treatment – Connector Component Material (standard) Surface treatment (µm) Component Material (standard) Cu Ni Au Brass (UNS C38500) 0.5 3 1.0 Bronze (UNS C54400) Cu-Be (QQ-C-530) PEEK Silicone PVMQ 0.5 3 – – – 1.5 Ni Outershell Latching mechanism Insulator cable clamp Other met. pieces Other plastic pieces 16 Aluminium Bronze PEEK PSU Stainless Steel PSU 5 5 – – – – Male contact Female contact Contact clips Insulator Sealing gland Surface treatment (µm) Modification 08.05 REDEL MODELS Kft K series (22 contacts) Straight plug with key (code G or A) and cable collet 16 KA● Part Number Cable Group 43.4 REDEL KAG.H22 Cable ø 6 mm min. 9.5 mm max. 68.5 KAG.H22.LLZBG KAA.H22.LLZBG KAG.H22.LLLB1G KAA.H22.LLAB1G KAG.H22.LLLB2G KAA.H22.LLAB2G no contact 1 2 Contact Type Marking female male female male female male black red black red black red 6 22 16 11 17 12 7 1 46.6 Fixed socket with key (code G or A), two screw fixing 16 KL● Part Number KLG.H22.LLZG KLA.H22.LLZG KLG.H22.LLA1G KLA.H22.LLL1G KLG.H22.LLA2G KLA.H22.LLL2G 37.4 17 7 12 33.4 REDEL 1 KLG.H22 23 Cable Group no contact 1 2 Contact Type Marking male female male female male female black red black red black red 11 16 6 22 36 Straight socket with key (code G or A) and cable collet 16 KR● 7 12 REDEL Modification 08.05 22 KRG.H22 11 16 6 37.4 17 Part Number 33.4 1 Cable ø 6 mm min. 9.5 mm max. 69.6 KRG.H22.LLZBG KRA.H22.LLZBG KRG.H22.LLAB1G KRA.H22.LLLB1G KRG.H22.LLAB2G KRA.H22.LLLB2G Cable Group no contact 1 2 Contact Type Marking male female male female male female black red black red black red 17 REDEL Kft MODELS S series (51 contacts) Straight plug with key (code G or A) and cable collet 19.6 SA● Part Number Cable Group 75.5 53 Cable ø 7.5 mm min. 12.5 mm max. 51 REDEL SAG.H51 SAG.H51.LLZBG SAA.H51.LLZBG SAG.H51.LLLB1G SAA.H51.LLAB1G SAG.H51.LLLB2G SAA.H51.LLAB2G no contact 1 2 Contact Type Marking female male female male female male black red black red black red 41 40 31 30 22 21 12 11 1 53.6 Fixed socket with key (code G or A), two screw fixing 19.6 SL● Part Number Cable Group Contact Type Marking male female male female male female black red black red black red 23 1 SLG.H51.LLZG SLA.H51.LLZG SLG.H51.LLA1G SLA.H51.LLL1G SLG.H51.LLA2G SLA.H51.LLL2G 41 21 30 47 43 31 REDEL 22 SLG.H51 12 no contact 1 2 40 11 51 36 Straight socket with key (code G or A) and cable collet 19.6 SR● Part Number 76.6 1 47 Cable ø 7.5 mm min. 12.5 mm max. REDEL 18 30 31 SRG.H51 21 11 22 43 41 12 SRG.H51.LLZBG SRA.H51.LLZBG SRG.H51.LLAB1G SRA.H51.LLLB1G SRG.H51.LLAB2G SRA.H51.LLLB2G Cable Group no contact 1 2 Contact Type Marking male female male female male female black red black red black red 40 51 Modification 08.05 REDEL Kft ACCESSORIES FFA-ERA High Voltage Contacts Contact Part Number Male contact Female contact male L FFA.05.403.ZLA1 FFA.05.403.ZLA2 Cable group L (mm) 1 2 4 6 ERA.05.403.ZLL1 ERA.05.403.ZLL2 female GMA Heatshrink tube ø D min. Shall be ordered separately L Part number Cable group GMA.30.010.ST GMA.15.010.ST 1 2 Name Supplier øD Product reference L 3.0 1.5 13 9 RAYCHEM® RNF 3000 3/1 RAYCHEM® RNF 3000 1.5/0.5 Note: for cable group 2, the two heatshrink tubes are necessary ● Material: Polyolefine transparent DCT Assembly tool for guide pins ø 5.5 ø 5.5 ø 16 TOOLING Part Number 120 DCT.91.551.0LA DCF Extraction tools for HV contacts Part Number Automatic model DCF.91.133.5LT DPH Crimping tool with die and positioner Part Number DPH.99.005.2K DPH.99.060.11K DPH.99.065.11K Applications Cable group Marking on die shield centre contact centre contact 1-2 1 2 DPH.91.005.2K DPH.91.001.16K DPK.91.001.16K Applications Cable group Marking on die shield centre contact centre contact 1-2 1 2 DPH.91.005.2K DPH.91.001.16K DPK.91.001.16K DPN Dies and positionner Part Number DPN.99.005.2K DPN.99.060.11K DPN.99.065.11K ● Dies material: Blackened steel Modification 08.05 19 REDEL Kft PANEL CUT-OUT K series S series ø 3.2 R 2.9 R ø 3.2 33.4 31.3 23.8 21.8 2.9 11.8 15 RECOMMANDED CABLES Cable group Manufacturer Part Number 1 SILISOL CEPMB 56x0.12 mm2 1 ABBNK - 45/94 2 HABIA 31789-004-001 CERN Type Type/Nb. of conductor Conductor Constr. Mat. ø Construction and dimensions Dielectric Screen Sheath Mat. ø Mat. Mat. ø Corona screen Multi/56 7x0.15 CuSn 0.45 PE 1.5 CuSn + Alu Silic 14.5 no HTC 50-1-1 Mono/1 7x0.17 CuSn 0.51 PE solid 1.5 CuSn 16x4x0.1 Polyolefine 3.3 yes HFI 150 mini coax Mono/1 Mono 0.16 HFI 150 0.5 Drain 2x0.1 HFI 150 + Alu polyester 1.15 no Cu EARTHING CONTACT Usually, some H.V. contacts are used to connect earthing from the cable shield to the instrument panel. For such earthing connection it is also possible to use L.V. crimp contacts. With a crimp barrel of 1,4 mm, these contacts can be used with wires AWG 18-20. Connector models Contact type Contact part number KAG-KLA-KRA-SAG-SLA-SRA KAA-KLG-KRG-SAA-SLG-SRG KAG-KLA-KRA-SAG-SLA-SRA KAA-KLG-KRG-SAA-SLG-SRG male female male female KAG.565.ZZC EGG.3B.665.ZZM KAG.567.ZZC EGG.3B.667.ZZM Crimp hole Ø AWG range Positioner part number DCE.91.132.BVC 1.4 mm 18-20 DCE.91.133.BVM 1.4 mm 18-20 0.8 mm 22-24-26 DCE.91.132.BVC 0.8 mm 22-24-26 DCE.91.133.BVM Selector position Crimp tool part number 8-7 8-7 6-5-5 6-5-5 DPC.91.701.V1) Note: 1) according to specification MIL-C-22520/7-01 Termination instructions Refer to 05 series (page 6 & 7) for each individual H.V. contacts 20 Modification 08.05 Headquarter, Ecublens Switzerland ■ AUSTRALIA JOHN BARRY GROUP Pty. Ltd Unit 1, 706 Mowbray Road Lane Cove, NSW 2066 Tel: (+61 2) 93 55 23 80 Fax: (+61 2) 93 55 23 81 lemo@johnbarry.com.au ● AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax: (+43 1) 914 23 20 11 sales@lemo.at ■ BRAZIL RAIMECK Industria e Comércio Ltda Rua Dr. S. Lappetina Russo, 11 04753-110 São Paulo - SP Brasil Tel: (+55 11) 55 24 58 21 Fax: (+55 11) 55 24 58 21 raimeck@raimeck.com.br ■ CANADA BIRDE Marketing Inc 111 Esna Park Drive, Unit 1, Markham, Ontario L3R 1H2 Tel: (+1 905) 477 77 22 Fax: (+1 905) 477 78 13 toronto@birde.ca ● CHINA LEMO Trading (Shanghai) Co., Ltd LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com ■ CZECH REPUBLIC MECHATRONIC SPOL. s.r.o. Kloknerova 9, 148 00 Praha 4 Tel: (+420 2) 679 13973 Fax: (+420 2) 679 13973 mechatronic@volny.cz ● DENMARK LEMO DENMARK A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com ● FRANCE LEMO France Sàrl 24/28, avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com ● GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de ■ GREECE CALAVITIS S.A. 11, Antinoros Street 116 34 Athens Tel: (+30 210) 7248 144 Fax: (+30 210) 7291 613 technical@calavitis.gr ● HONG KONG LEMO Hong Kong Ltd Unit 1207, 12/F, Corporation Square, 8 Lam Lok Street, Kowloon Bay, Kowloon - Hong Kong Tel: (+852) 21 74 04 68 Fax: (+852) 21 74 04 92 hk.sales@lemo.com ● HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 redelemo@lemo.hu ■ INDIA PT INSTRUMENTS Pvt. Ltd 204 - D, Twin Arcade P. Box No 17436, Military Road, Marol, Andheri (East) Mumbai - 400 059, India Tel: (+91 22) 2925 13 53 Fax: (+91 22) 2920 18 86 ptinst@vsnl.com ■ ISRAEL AVDOR TECHNOLOGY LTD 16 Moshe Shapira St. Rishon Lezion 75704 Tel : (+972 3) 952 02 22 Fax :(+972 3) 962 34 20 sales@avdor.com ● ITALY LEMO ITALIA srl Viale Lunigiana 25, 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com ● JAPAN LEMO JAPAN Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: (+81 3) 54 46 55 10 Fax: (+81 3) 54 46 55 11 lemoinfo@lemo.co.jp ● NETHERLAND / BELGIUM LEMO Connectors Benelux De Trompet 1060 1967 DA Heemskerk Tel: (+31) 251 25 78 20 Fax: (+31) 251 25 78 21 info@lemo.nl ■ NEW ZEALAND CONNECTOR SYSTEMS HOLDINGS Ltd 5a Pacific Rise Mt Wellington, Auckland Tel: (+64 9) 580 28 00 Fax: (+64 9) 580 28 80 sales@connectorsystems.co.nz ● NORWAY / ICELAND LEMO NORWAY A/S Stanseveien 6B, 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com ■ PAKISTAN ZEESHAN ELECTRONICS #62 Khayaban-e-Jouhar Sector I - 10/3 Islamabad 44000 Tel: (+92 51) 444 99 45 Fax: (+92 51) 444 99 48 zain.sheikh@zeeshanelectronics.com ■ POLAND SEMICON 43, Zwolenska St. 04-761 Warsaw Tel: (+48) 22 615 64 31 Fax: (+48) 22 615 73 75 info@semicon.com.pl ■ RUSSIA SCS PO Box 27, Moscow, 115551 Krzhizhanovskogo str., 14, build. 3 Moscow, 117218, Russia Tel: (+7 495) 223-4638 (multi-channel) (+7 495) 997-6067 Fax: (+7 495) 223-4638 info@lemo.ru ● SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building, Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com ■ SOUTH AFRICA JAYCOR INTERNATIONAL (PTY) Ltd Head Office, Sandgate Park, 16 Desmond Street, Eastgate Ext. 9 Sandton, Johannesburg Tel: +27 11 444 1039 Fax: +27 11 444 1311 jeff@jaycor.co.za ■ SOUTH KOREA SUNG SHIN I&C CO., Ltd #2-801, Lotte IT Castle, 550-1, Gasan-Dong, Geumcheon-Gu, Seoul, 153-803, Korea Tel: (+82 2) 2026 8350 Fax: (+82 2) 2026 8360 mail@sung-shin.com ■ TURKEY / GULF STATES MAK SAVUNMA LTD STI Baskent Oto Galericileri Sitesi 668. SOK No 9, Ergazi - Ankara 06820 Turkey Tel: (+90 312) 256 16 06 Tel: (+90 312) 257 13 06 Fax: (+90 312) 256 15 41 sales@maksavunma.com ■ UKRAINE U.B.I. Mr. Ivan Baryshnikov Layosha Gavro str., 17a, appt. 50 04211, Kiev, Ukraine Tel: (+380 44) 568-5765 Fax: (+380 44) 568-5779 info@lemo.ua ● UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com ● USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax: (+1 707) 578 08 69 info@lemousa.com ● SPAIN / PORTUGAL IBERLEMO S.A. Brasil, 45, 08402 Granollers, Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com Madrid Office Antonio López, 96, 28019 Madrid Tel: (+34 91) 469 99 19 Fax: (+34 91) 469 99 59 ● SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com ● SWITZERLAND LEMO VERKAUF AG Grundstrasse 22B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com ■ TAIWAN EVERHARMONY ENTERPRISE Inc P.O. Box 96-47 Taipei 26, Lane 63, Tung Hwa South Rd sec. 2, Taipei, Taiwan, R.O.C. Tel: (+886 2) 27 07 00 69 Fax: (+886 2) 27 02 47 23 ever.harmony@msa.hinet.net Printed in Switzerland, july 2000 © LEMO SA Pdf updated, april 2012
SAG.H51.LLZBG 价格&库存
很抱歉,暂时无法提供与“SAG.H51.LLZBG”相匹配的价格&库存,您可以联系我们找货
SAG.H51.LLZBG
  • 50+1866.8520650+241.97957
