RP34L-5LP-3SC
RP34L-5LP-3SC
    HRS(广濑)
    CONN PLUG R/ANGLE POWR SUPPLY
RP34L-5LP-3SC 数据手册
NEW New Connectors For Low Profile Power Supply RP34L Series Receptacle installed height RP34L Existing RP34 (3-contact type) (2-contact type) Fig.-➀ ■Features Mated Size 1. Low profile: These receptacles are designed with their installation heights to be shorter than those of conventional RP34 series, such as 6.1mm (for 2-core type) and 5mm (for 3-core type). (See Fig.-1.) 2. Space saving: Both 2 and 3 position receptacles are miniaturized to 7mm in depth, resulting in a small board mounting area.Please refer Fig.-2 and Fig.-3. 3. With snap-lock mechanism: Audible click when connector is fully mated. RP34L-5PA-2SC(✽✽✽✽) & RP34L-5R-2PD 4. Tight fit: Designed to fit snugly in all three directions. This 2 contact plug is an over-molded (i.e., cable-integrated form) type. Recommended cable diameter is Ø3.5mm. Fig.-➁ 5. Sequence structure: The 3 contact type has sequenced mating so that one pin makes contact as a ground terminal before the other contacts engage. Mating Size 6. No Mismating Two polarized keys prevent any insertion error. 7. Ease of Mating An arrow on the top of the plug shows the proper direction for insertion. ■Applications Notebook PCs, portable remote terminals, AV equipment, etc. RP34L-5P-3SC & RP34L-5R-3PD This 3-contact plug is a fabricated type. Recommended cable diameter is Ø4mm. 99.4 Fig.-➂ 1 ■Product Specifications RATINGS Rated Current 5A Available Temp. Range -25ç~+85ç Rated Voltage AC30V,DC42A Storage Temp. Range -10ç~+60ç Description Specifications 1.contact resistance Requirements Should be measured at DC 1A. 30mø or less 2.insulation resistance 1000mø or more Should be measured at DC 100V. 3.voltage resistance AC 150V for 1 minute No flashover/dielectric4.vibration Breakdown 4.vibration resistance No instantaneous electric Disconnection of 10µs or More 10~55Hz, one-sided amplitude 0.75mm, 3 directions for 2hours, respectively 5.temperature cycle -55ç for 30 min./normal temp. for 10~15 min./+85ç for 30 min./normal temp. for 10~15 min. 5 cycles Insulation resistance:100mø or more 6.corrosion resistance No excessive corrosion For 48 consecutive hours in 5% salt water 7.Duration against consecutive Contact resistance:60mø or less plugging/unplugging. 5,000 time Note.1) Above-stated specifications are typical of this series. For part specific data, please consult factory. ■Material Quality Description 2 position receptacle 2-position plug 3-position receptacle Material Remarks Phosphor bronze Solder-plating Dielectric Nylon resin Black color Terminal Brass Palladium-plating Cover Vinyl chloride resin Black color UL94V-0 Insert insulator Nylon resin Black color UL94HB Terminal Phosphor bronze Metal fixture Phosphor bronze Solder-plating Insulator PPS resin Black color Terminal Brass Palladium-plating Polycarbonate resin Black color UL94V-0 Cover 3-position plug Processing Metal fixture UL94HB UL94V-0 Vinyl chloride Black color UL94V-0 Insulator PPS resin Black color UL94V-0 Terminal Phosphor bronze Palladium-plating ■Product Name Configuration This is available for you to determine the product specifications from a part number, not to produce part numbers. When ordering, please select from existing part numbers shown in page 3-4 of this catalog.[For plugs, Hirose will produce cable assemblies to customer specifications. Please consult Hirose for quote.] RP34L - 5 PA - 2 SC 1 1 Series name: RP34L 2 Shell: 5-shell.size 2 3 Type: Receptacle: R Assembled straight plug: P Assembled right angle plug: LP Cable-integrated forming straight plug: PA 2 3 4 (✽ ✽ ✽ ✽ ) 5 6 4 Number of positions: Shows the numberof terminals.2contacts.3 contacts 5 Type of contact: PD: dip-solder male terminal SC: crimp-style female terminal 6 Cable length:(✽✽✽✽) depends on each cable. ■Receptacles ●2-position RP34L-5R-2PD ●3-position RP34L-5R-3PD HRS No. Parts No. 113-5154-6-00 RP34L-5R-2PD 113-5157-4-00 RP34L-5R-3PD 3 ■Plugs ■RP34L-5PA-2SC(1857) ■RP34L-5P-3SC ■RP34L-5LP-3SC 4 HRS No. Parts No 113-5153-3-00 RP34L-5PA-2SC(1857) 113-5158-7-00 RP34L-5P-3SC 113-5161-1-00 RP34L-5LP-3SC ■Crimp Terminal ■RP34L-SC1-212(01) HRS No. Parts No 113-5151-8-01 RP34L-SC1-212(01) ■Applicable Tools TYPE HRS No. Parts No. Conformant terminal Conformant Cable Manual crimping tool -------------- HT-102/RP34L-SC1-212 RP34L-SC1-212(01) AWG#18~#22 -------------- -------------- RP34L-SC1-212(01) AWG#18~#22 Automatic 901-0005-4 CM-105 Crimper body 901-2043-4 AP105-RP34L-SC1-212 Cable crimping tool 150-0074-1 RP34-TC-01 -------------- Drawing tool 150-0039-0 RP6-SC-TP -------------- Crimper Ø4 -------------- 5 ■Assembly Instructions(3-Position Plug) ●Straight Plug 1. First, pull the bushing through the terminalprocessed cable to crimp and wire that terminal. 2. Insert such crimped/wired terminal into the terminal hole of S insulation P case.Then verify that the crimp terminal is firmly engaged in the terminal hole of S insulation P case by pulling the cable slightly. In such cases as incorrect wiring, insert the drawing jig (RP6-SC-TP) from the fitting section to draw the terminal out of wiring side and rearrange it. 3. Next, crimp the clamp to the cable with an applicable tool (RP34-tc-01). 4. Install the convex section of S insulation P case in the cord tube(B) by adjusting to its round hole. 5. Then put the rim of clamp into the concave section of cord tube(B), and install bushing/clamp in cord tube(B). 6. Install cord tube(A) in cord tube(B). At that time, verify that four claw sections of cord tube(B) are mounted on the square hole section of cord tube(A). ●Right Angle Plug 1. The right angle plug can also be assembled by using the same procedure as the straight plug. 6 ■Precautions 1. Use the connector section with its panel held down so as not to have excessive load.For 2-contact type, hold the outer shellsection of the receptacle, and for 3 contact type, the outer shell section of the plug. 2. After connector assembly, cable must not be pulled over 30N in the arrow-indicated direction. Be careful not to add excessive tensile load because it will lead the damage of connectors. 7 8 The contents of this catalog are current as of April 1999. Contents are subject to change without notice for the purpose of improvements.
RP34L-5LP-3SC 价格&库存
很抱歉,暂时无法提供与“RP34L-5LP-3SC”相匹配的价格&库存,您可以联系我们找货
