DF62-13EP-2.2C(10)
DF62-13EP-2.2C(10)
    HRS(广濑)
    CONNPLUGHOUSING13POS
DF62-13EP-2.2C(10) 数据手册
DF62W Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Water Resistant, Slim In-line Connector for Internal Wiring Jun. 2022 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Features Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. The slim, sleek design and smooth contour combine to complete connections in tight spaces. No Metal Exposure Multi-Row Pin Layout No metal component is exposed so no unexpected conduction occurs even when wiring inside a metal pipe. Contacts are arranged in a grid, shortening the diagonal length. 【Other Suppliersʼ (8pos.)】 These connectors were designed to take full advantage of small/ narrow spaces. The contacts are arranged in a grid pattern which shortens the diagonal distances and the body was slimmed down by creating smooth outer surfaces. This design helps to save precious space and makes these connectors virtually tangle free. There is no visible or exposed metal which eliminates the possibility of electrical arcing between the connector and the inside of a metal conduit. ⌀14.7mm 【DF62W (9pos.)】 OMax. ︓ Dia. : ⌀13.3mm Smooth Contour Rounded connector outline for smooth wiring inside narrow spaces 2. Secure Lock Mechanism The friction lock emits a clear tactile click upon lock completion. The design prevents incomplete mating and connector disconnection. The socket lock can be visually checked through the plug window after mating. Visible Lock Design Lock on socket is visible through the slit on the plug when locking is complete, which prevents incomplete mating. 3. Reliable Contact Design Two- point contact design that maintains contact reliability. 4. Robust Contact Design (Waterproof type (DF62W)) The unique design protects the contacts and lance areas. It prevents any bending or deformity that might occur during mating, assembly or transportation. Robust Box-shaped Contact design Designed for easy contact insertion. 2 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring 5. Multiple Variations Available Several product variation are available so designers can choose the one most suited to their application. Compatible with a wide range of cable sizes and available in in- line and pin header types. 6. Applicator Sharing Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF62W is compatible with the DF11, DF59 and DF62 Series applicators by exchanging the parts. Note 1 : DF62W requires a dedicated die and hand tool. Note 2 : Some products are not compatible. Please contact Hirose for additional details. 7. Condensation Prevention Housing seal IP67 level water- resistance in mated condition. IP67 waterproof equivalent under specific conditions. Please contact a Hirose representative for detailed specifications and conditions. Wire seal 8. Panel Waterproof Type Wire seal [Example] E-Bike Drive Unit A panel waterproof type combining 2, 3, 4, and 6pos. is also available. IP67 level waterproofing prevents water immersion from outside the housing. Note : The inside of the housing is not waterproof. Inside of the Housing Outside of the Housing 3 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Product Specifications Rated Current (Note1) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rated Voltage UL No of Pos. 20 AWG 22 AWG 24 AWG 26 AWG Operating Temperature (Note 2) -40 to +105℃ 2 5A/pin 4A/pin 3.5A/pin 3A/pin Storage Temperature Range (Note 4) -10 to +60℃ 3 3.5A/pin 3A/pin 2A/pin 1A/pin Operating Humidity Range (Note 3) 20 to 80% 4 3.5A/pin 3A/pin 2A/pin 1A/pin Storage Humidity Range (Note 4) 40 to 70% 6 3.5A/pin 3A/pin 2A/pin 1A/pin 9 3.5A/pin 3A/pin 2A/pin 1A/pin 250V AC/DC Rated Voltage C-UL Rated Voltage 29.9V AC/DC 29.9V AC/DC Operating Temperature (Note 2) -40 to +75℃ Operating Temperature (Note 2) -40 to +75℃ UL, C-UL File Name UL : E52653 C-UL : E52653 Items Specifications Conditions Insulation Resistance 1000M Ω Min. 500V DC Withstanding Voltage No flashover or insulation breakdown 650V AC for 1 min. Contact Resistance 30m Ω Max. 20mV Max., 1mA (DC or 1000Hz) Vibration Resistance No electrical discontinuity of 1μ s. 10 cycles in each of three directions at frequency 10 to 55Hz, half amplitude 0.75mm Shock Resistance No electrical discontinuity of 1μ s. Accelerated velocity : 490 m/s2 for 11ms, half-sine wave in 3 directions, 3 times for each direction Humidity Resistance Contact Resistance : 30m Ω Max. Insulation Resistance : 1000M Ω Min. 96 hours at temperature of +40 ± 2℃ and humidity of 90 to 95% Temperature Cycles Contact Resistance : 30m Ω Max. Insulation Resistance : 1000M Ω Min. -55℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes → 85℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes, 5 cycles Mating Durability Contact Resistance : 30m Ω Max. Tin plating : 30 times Gold plating : 50 times Solder Heat Resistance No deformation in appearance or significant damage to contacts. Flow : 260℃ , 10sec. Hand soldering : temperature of soldering iron at 300℃ for 3sec. Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple circuits, current ratings may go above the stated current ratings. Please consult Hirose for details before doing this. Note 2 : The connector should be completely dry (no condensation present) Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. Note 4 : Applicable to unused items in packed condition. Note 5 : The panel waterproof type is not UL/C-UL certified. 4 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Materials / Finish Item Socket Crimp Contact Plug Crimp Contact Crimp Socket Crimp Plug Crimp Socket Crimp Plug Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Header Component Material Finish Contact Phosphorous Bronze Gold Plating or Tin Plating Insulator PBT Seal White Black UL Flame Retardant Grade RoHS2 UL94V-0 Silicone Rubber Bengala or Gray - Insulator PBT Black UL94V-0 Contact Copper Alloy Gold Plating or Tin Plating - Brass Tin Plating - Silicone Rubber Bengala - Retention Tab Seal 5 Yes DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Note : The waterproof type (DF62W Series) and non-waterproof type (DF62 Series) are not intermateable. ● Connector (In-line) DF62W # - # S - 2.2 C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name DF62W ❹ Connector Type S : Socket EP : In-line Plug ❷ Shape Type None : Regular Type C : Thin Cable Type P : Panel Waterproof Type ❺ Contact Pitch 2.2mm ❻ Termination Type C : Crimp Housing ❸ No. of Pos. 2, 3, 4, 6, 9 ● Connector (DIP) DF62WZ - # P - 2.2 DSA (##) ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name DF62W or DF62WZ ❹ Contact Pitch 2.2mm ❷ No. of Pos. 3,6,9 ❺ Termination Type DSA : Straight Pin Header ❸ Connector Type P : Pin Header ❻ Plating Type 20 : Tin Plating 50 : Gold Plating ❷ Usage WP : Waterproof Pin ❹ Contact Type / Packaging Type SCF SC PCF PC ❺ Plating Type A : Gold Plating None : Tin Plating ● Waterproof Pin DF62W - WP ❶ ❶ ❷ Series Name DF62W ● Contact DF62W - EP 2226 PCF A ❶ ❷ ❸ ❹ ❶ Series Name DF62W ❷ Terminal Type EP : In-line Plug ❸ Applicable Wire Size 2022 : 20 - 22 AWG 2226 : 22 - 26 AWG ❺ 6 : Socket Crimp Contact, Reel : Socket Crimp Contact, Pieces : Plug Crimp Contact, Reel : Plug Crimp Contact, Pieces DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Connector Mating Combinations Diagram Crimp Socket (Note) DF62W-#S-2.2C (Standard type) DF62WC-#S-2.2C (Thin cable type) Socket Crimp Contact DF62W-#EP-2.2C (Standard type) DF62W-2022SC(F)(A) DF62W-2226SC(F)(A) Note) When using without the crimp contact inserted, fill the contact hole of socket and plug with the DF62W-WP waterproof pin. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Crimp Plug (Note) DF62WC-#EP-2.2C (Thin cable type) Plug Crimp Contact DF62W-EP2022PC(F)(A) DF62W-EP2226PC(F)(A) Note) When using without the crimp contact inserted, fill the contact hole of socket and plug with the DF62W-WP waterproof pin. Crimp Plug (Panel Waterproof Type) DF62WP-3/4/6/2EP-2.2C Plug Crimp Contact DF62W-EP2022PC(F)(A) DF62W-EP2226PC(F)(A) Note : The compatible sockets are 2,3,4, and 6pos. Straight Pin Header DF62W(Z)-#P-2.2DSA(##) 7 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Crimp Socket Contact No. CAV No. B 14.05 A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P=2.2 P=2.2 9pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. DF62W-2S-2.2C CL0544-1002-7-00 2 DF62W-3S-2.2C CL0544-1004-2-00 3 DF62W-4S-2.2C CL0544-1006-8-00 4 DF62W-6S-2.2C CL0544-1008-3-00 6 DF62W-9S-2.2C CL0544-1010-5-00 9 DF62WC-2S-2.2C CL0544-1046-0-00 2 DF62WC-3S-2.2C CL0544-1054-0-00 3 DF62WC-4S-2.2C CL0544-1051-0-00 4 DF62WC-6S-2.2C CL0544-1057-0-00 6 DF62WC-9S-2.2C CL0544-1032-0-00 9 A B Applicable Jacket Outer Diameter Purchase Unit φ 1.4 to 1.6mm 100pcs per bag φ 0.98 to 1.2mm 100pcs per bag 7.55 7.5 9.75 9.7 11.95 7.55 7.5 9.75 9.7 11.95 ■ Position Number Pin Configuration (Shown from the Mating Side) 2 Pos. 3 Pos. 1 2 4 Pos. 1 2 3 φ9.2mm φ10.4mm φ10.8mm 6 Pos. 9 Pos. 1 2 1 2 3 1 2 3 3 4 4 5 6 4 5 6 7 8 9 φ11.6mm φ13.3mm 8 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Crimp Plug P=2.2 P=2.2 B 23.05 A CAV No. Contact No. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. A B 6.7 DF62W-2EP-2.2C CL0544-1003-0-00 2 7.5 DF62W-3EP-2.2C CL0544-1005-5-00 3 8.0 DF62W-4EP-2.2C CL0544-1007-0-00 4 9.1 DF62W-6EP-2.2C CL0544-1009-6-00 6 DF62W-9EP-2.2C CL0544-1011-8-00 9 DF62WC-2EP-2.2C CL0544-1047-0-00 2 7.5 DF62WC-3EP-2.2C CL0544-1053-0-00 3 8.0 DF62WC-4EP-2.2C CL0544-1052-0-00 4 9.1 DF62WC-6EP-2.2C CL0544-1058-0-00 6 DF62WC-9EP-2.2C CL0544-1037-0-00 9 Applicable Jacket Outer Diameter φ 1.4 to 1.6mm 9.15 11.3 11.35 100pcs per bag 6.7 9.15 11.3 φ 0.98 to 1.2mm 11.35 ■ Position Number Pin Configuration (Shown from the Mating Side) 2 Pos. 3 Pos. 2 1 4 Pos. 2 1 3 φ8.5mm φ9.7mm φ10.2mm 6 Pos. 9 Pos. 2 1 3 2 1 3 2 1 4 3 6 5 4 6 5 4 9 8 7 φ11.5mm φ12.8mm 9 Purchase Unit DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Crimp Plug (Panel Waterproof Type) 52.2 19 φ3 .5± 0.2 9.3 61.8 41.8 CAV No. Contact No. 44.8 Based on the above diagram, the number of positions for each mating port is as follows from left to right : 3, 4, 6 and 2pos. ■Panel Cut-Out Dimensions 52.2 46.2±0.1 44±0.1 38.5±0.1 X A-A 2×M3 2 φ0.1 X Y 1 0. ± .3 R1 13±0.1 3±0.1 A 6.9±0.1 Y Rz3.2 C C 5.7±0.1 1 15.7±0.1 10.2±0.1 A R1 ±0 .1 R5.2 ±0.1 1 0. 3± 0. 0. 3± 0. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.5 15.7 37.6 0.05 Unit : mm Part No. DF62WP-3/4/6/2EP-2.2C HRS No. No. of Pos. CL0544-1056-0-00 2/3/4/6 Note: The panel waterproof type is not UL/C-UL certified. 10 Applicable Jacket Outer Diameter φ 0.98 to1.2mm φ 1.4 to 1.6mm Purchase Unit 24pcs per tray DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Waterproof Pin 3 φ1.7 2.9 3 (waterproof surface) φ1.65 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CAV No. φ1.65 HRS Logo Unit : mm Part No. DF62W-WP HRS No. CL0544-1014-6-00 Purchase Unit 100pcs per bag Note 1 : When using without the crimp contact inserted, fill the contact hole of socket and plug with a waterproof pin. Note 2 : Not compatible with the panel waterproof type. 11 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Straight Pin Header CAV No. Contact No.1 Marking B 15.5 A P=2.2 P=2.2 9pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. A B DF62W-3P-2.2DSA(##) CL0544-1021-0-## 3 12 9.9 Yes - 256pcs per tray DF62WZ-6P-2.2DSA(##) CL0544-1059-0-## 6 8.7 9.5 Yes - 240pcs per tray DF62WZ-9P-2.2DSA(##) CL0544-1050-0-## 9 12 12.1 Yes Yes 200pcs per tray Tin Plating Gold Plating 【Specification No. (##),-##】 (20) : Tin plating (50) : Gold plating ■ Recommended PCB Layout (Recommended Thickness t=1.6mm) 2.3±0.05 Contact No.2 P=2.2±0.05 .1 +0 0 8 0. φ 6× +0 .1 0 +0.1 0 Contact No.1 0.8 9×φ Contact No.1 P=2.2±0.05 12 P=2.2±0.05 P=2.2±0.05 0. 0 1 5.05±0.05 φ1 .8 P=2.2±0.05 5.05±0.05 φ1 .8 + [9 Pos.] P=2.2±0.05 P=2.2±0.05 1.4±0.05 8 1. φ P=2.2±0.05 Contact No.3 Contact No.1 +0 . 0 1 .1 +0 0 1.1±0.05 P=2.2±0.05 2.8±0.05 [6 Pos.] 4.5±0.05 [3 Pos.] 3× φ0 .8 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.85 □ 0.5 Purchase Unit DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Socket Crimp Contact (11.5) 3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.37 1.6 7.8 ● Reel Contact, Applicable Tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note) Part No. HRS No. Finish DF62W-2022SCF DF62W-2022SCFA CL0544-1015-9-00 CL0544-1027-0-00 Tin Plated Gold Plated DF62W-2226SCF DF62W-2226SCFA CL0544-1000-1-00 CL0544-1025-0-00 Tin Plated Gold Plated UL Stranded Calculated Jacket Compatible Connector AWG Wire Structure Cross-section Diameter 3443 20 7/0.32mm 0.563mm2 1007 22 17/0.16mm 0.342mm2 1007 22 24 17/0.16mm 11/0.16mm 0.342mm2 0.221mm2 1430 24 26 11/0.16mm 7/0.16mm 0.221mm 0.141mm2 1061 24 26 11/0.16mm 7/0.16mm 0.221mm2 0.141mm2 φ 1.4 to φ 1.6mm DF62W-#S-2.2C φ 0.98 to φ 1.2mm DF62WC-#S-2.2C 2 Purchase Unit 15,000pcs per reel Note 1 : When using cables not specified by Hirose, please contact a Hirose sales representative. Note 2 : There are cases in which use of a flexible wire (thin, stranded conductor or soft jacket material) may make insertion to socket difficult. Please contact a Hirose representative for more information. ● Loose Piece, Applicable Tool : Hand Crimping Tool Applicable Wire (Tin Plated Annealed Copper) (Note) Part No. HRS No. Finish DF62W-2022SC DF62W-2022SCA CL0544-1017-4-00 CL0544-1045-0-00 Tin Plated Gold Plated DF62W-2226SC DF62W-2226SCA CL0544-1012-0-00 CL0544-1044-0-00 Tin Plated Gold Plated UL Stranded Calculated Jacket Compatible Connector AWG Wire Structure Cross-section Diameter 3443 20 7/0.32mm 0.563mm2 φ1.53mm 1007 22 17/0.16mm 0.342mm 2 φ1.58mm 1007 22 24 17/0.16mm 11/0.16mm 2 0.342mm 0.221mm2 φ 1.58mm φ 1.42mm 1430 26 7/0.16mm 0.141mm2 φ1.48mm Note : The applicable cables include only those listed above. 13 DF62W-#S-2.2C Purchase Unit 100pcs per pac DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Plug Crimp Contact (15.3) 11.6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.37 1.6 3 ● Reel Contact, Applicable Tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish DF62W-EP2022PCF DF62W-EP2022PCFA CL0544-1016-1-00 CL0544-1028-0-00 Tin Plated Gold Plated DF62W-EP2226PCF DF62W-EP2226PCFA CL0544-1001-4-00 CL0544-1026-0-00 Tin Plated Gold Plated Stranded Calculated Jacket Compatible Connector Wire Structure Cross-section Diameter UL AWG 3443 20 7/0.32mm 0.563mm2 1007 22 17/0.16mm 0.342mm2 1007 22 24 17/0.16mm 11/0.16mm 0.342mm2 0.221mm2 1430 24 26 11/0.16mm 7/0.16mm 0.221mm2 0.141mm2 24 11/0.16mm 0.221mm2 26 7/0.16mm 0.141mm 1061 2 φ 1.4 to φ 1.6mm DF62W-#EP-2.2C DF62WP-3/4/6/2EP-2.2C φ 0.98 to φ 1.2mm DF62WC-#EP-2.2C DF62WP-3/4/6/2EP-2.2C Purchase Unit 15,000pcs per reel Note 1 : When using cables not specified by Hirose, please contact a Hirose sales representative. Note 2 : There are cases in which use of a flexible wire (thin, stranded conductor or soft jacket material) may make insertion to socket difficult. Please contact a Hirose representative for more information. ● Loose Piece, Applicable Tool : Hand Crimping Tool Applicable Wire (Tin Plated Annealed Copper) (Note) Part No. HRS No. Finish DF62W-EP2022PC DF62W-EP2022PCA CL0544-1018-7-00 CL0544-1043-0-00 DF62W-EP2226PC DF62W-EP2226PCA CL0544-1013-3-00 CL0544-1042-0-00 Stranded Calculated Jacket Compatible Connector Wire Structure Cross-section Diameter UL AWG Tin Plated Gold Plated 3443 20 7/0.32mm 0.563mm2 1007 22 Tin Plated Gold Plated 1007 1430 17/0.16mm 0.342mm 2 φ 1.53mm φ 1.58mm 22 24 17/0.16mm 11/0.16mm 0.342mm2 0.221mm2 φ 1.58mm φ 1.42mm 26 7/0.16mm 0.141mm2 φ1.48mm Note : The applicable cables include only those listed above. 14 DF62W-#EP-2.2C DF62WP-3/4/6/2EP-2.2C Purchase Unit 100pcs per pack DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Mated Dimensions ●Wire-to-Wire Connection 【Panel Waterproof Type】 DF62W(C)-#S-2.2C DF62WP-3/4/6/2EP-2.2C DF62W(C)-#EP-2.2C ●Wire-to-Board Connection  (Straight Pin Header) DF62W(C)-#S-2.2C DF62W(Z)-#P-2.2DSA(##) (19.55) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (27.1) (23.25) DF62W(C)-#S-2.2C 15 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Applicable Crimping Tools Tool Applicator Press Body Part No. HRS No. AP105-DF62W-2022 CL0901-4500-0-00 EHS899800H-UP(Note 2) - AP105-DF62W-2226 CL0901-4637-0-00 EHS888400H-UP(Note 2) - DF62W-2226SCF(A) DF62W-EP2226PCF(A) CM-105C CL0901-0001-0-00 - HT802/DF62W-2022(Note 4) CL0550-0431-0-00 DF62W-2022SC(A) DF62W-EP2022PC(A) HT802/DF62W-2226(Note 5) CL0550-0416-6-00 DF62W-2226SC(A) DF62W-EP2226PC(A) CL0902-4666-4-00 DF62W-2022SC(F)(A) DF62W-EP2022PC(F)(A) DF62W-2226SC(F)(A) DF62W-EP2226PC(F)(A) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Hand Tool Extraction Tool Applicable Contact DF62W/RE-MD DF62W-2022SCF(A) DF62W-EP2022PCF(A) Note 1 : Issues with non-Hirose specified tools are outside the scope of warranty. Note 2 : Applicator manufactured by JAPAN AUTOMATIC MACHINE(J.A.M.). Please contact J.A.M. via the URL below regarding inquiries on the applicator or crimp defects. (URL : http://www.jam-net.co.jp) Note 3 : Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0762-00, ETAD-H0763-00)" and "Crimping Condition Table". Note 4 : The compatible wire is limited to UL3443 (20 AWG) or UL1007 (22 AWG). Note 5 : The compatible wire is limited to UL1007 (22 to 24 AWG) or UL1430 (24 to 26 AWG). Note 6 : When using non-Hirose specified tools, please consult with a Hirose sales representative regarding requests for the tool die drawing. 16 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Crimping ■ Items Required Prior to Starting Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The work- related documents listed below are required before starting harness assembly. ( The ● mark indicates a required document. ) When the documents shown below are not available, ask a Hirose sales personnel to provide them. Automatic Hand Crimping Crimping Machine Tool Document Title Description Remarks (1) Main Unit of Crimping Machine Instruction Manual Explanation of main press machine unit ● - (2) Applicator Spare Parts Identification Explanation for Applicator installation ● - (3) Crimp Conditions Standard values of : Crimp height, tensile strength ● - (4) Crimp Quality Standards Various standards for crimping conditions ● - (5) Operating lnstructions for Hand Tool Inspection items of : Crimp height, tensile strength, other - ● Bundled with the purchase of hand tool. (6) DF62W Series Cable Assembly Procedure : ETAD-H0760-00 Cable assembly procedure ● ● Ask a HRS sales representative. Bundled with the purchase of the main press machine unit. Bundled with the purchase of applicator. ■ Tools Use tools designated by Hirose when crimping. ・Crimping performed using tools other than those specified is outside the scope of warranty. ・The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual before implementing the work. ■ Applicable Electric Wires When using a wire other than the applicable wires please contact a Hirose representative. [ Precautions] ・Electric wires that are suitable for crimping connectors are tin- plated stranded soft copper wire. ・Avoid crimping solid wires, wires with polyester threads or tin- coated wires. ・Avoid crimping two electric wires together. ・The crimp height setting value ( Note) may vary between tin- plated and gold- plated contacts even if the same electric wires are used. ・The crimp height setting value ( Note) may vary depending on the difference in the core wire configuration even if the computed cross- sectional area is the same. Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 17 DF62W Series/Water Resistant, Slim In-line Connector for Internal Wiring Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Precautions 1.Cleaning Conditions Please refer to the "Board-to-Wire Connector Guidelines (ETAD-H1023-00) ". Cleaning with IPA is allowed.(Other cleaning agents may change the insertion/removal feeling and are not recommended. Please contact us when considering use of other cleaning agents.) 2.Important Notes 1. Be careful when mating and un-mating the connector when it is not mounted to the board as it may result in damage. 2. During hand soldering, do not apply excess amounts of flux which can migrate onto the connector. 3. This product may have a slight differences in color depending on the production lot. This difference does not have any influence on the performance. 3.Handling Instructions Please refer to the materials listed below when handling this product. ■ Crimping Quality Standards : ETAD-H0762-00, ETAD-H0763-00 ■ DF62W Series Cable Assembly Procedure : ETAD-H0760-00 ■ DF62W Series Mating / Unmating Operation Instruction Manual : ETAD-H0761-00 ■ Board-to-Wire Connector Guidelines : ETAD-H1023-00 While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 6/ 2022. Contents are subject to change without notice for the purpose of improvements. 18
DF62-13EP-2.2C(10) 价格&库存
很抱歉,暂时无法提供与“DF62-13EP-2.2C(10)”相匹配的价格&库存,您可以联系我们找货
