REVISION Y
SIB-1XX-XX-XX-S-XX-XX
C
+.0043
+0.109
.0030 - .0017 0.076 - 0.043
No OF POSITIONS
-02 THRU -30
(PER ROW)
(SEE NOTES 9 & 10)
DO NOT
SCALE FROM
THIS PRINT
DETAIL 'A'
SCALE 10 : 1
No OF POSITIONS x .100[2.54]
LEAD STYLE
-02: SURFACE MOUNT
(USE C-228-X)
PLATING SPECIFICATION
-F: FLASH SELECTIVE
(USE C-228-F)
-FM: FLASH SELECTIVE, PURE TIN,
MATTE FINISH
(USE C-228-F)
((No OF POSITIONS -1) x .100[2.54]) .005[.13]
.264 6.706
.335 8.509
REF
01
.015 0.38 REF
OPTION
-LC: LOCKING CLIPS
(USE LC-09-TM)(SEE NOTE 13)
[N/A WITH THREADED INSERT OPTION
-E, -M OR -TI]
.015[.38]
.005[.13]
C
.050 1.27
REF
[NOT AVAILABLE ON 30 POS]
-E: TI-2-56-115 (ENGLISH)
-M: TI-M2-4-115-N (METRIC)
(SEE FIG. 2, SHEET 2)
-TI: NO INSERTS PLACED IN BODY
(SEE TABLE 1 ON SHEET 2 FOR
-TI POSITIONAL OFFERINGS)
ROW SPECIFICATION
-S: SINGLE (USE SIBC-XX-02-S)
* AVAILABLE TO EXISTING CUSTOMERS ONLY
REF
SIBC-XX-02-S
.0287 0.729 MIN END
WALL ON CUT PART
FIG 1
SIB-120-02-X-S-LC SHOWN
C-228-X
"A"
.172 4.38 REF
C
.150 3.810
REF
.045 1.143
'A'
.207±.005 5.268±0.127
"A"
.0560 1.422
LC-09-TM
C
(No OF POSITIONS -2) x .100[2.54] REF
REF
.203 5.16
.071±.003 1.803±0.08
(No OF POSITIONS -1) x .100(2.54) REF
.044 1.13 REF
NOTES:
C
1.
2.
3.
4.
5.
6.
7.
REPRESENTS A CRITICAL DIMENSION.
COPLANARITY: SEE TABLE 2.
BURR ALLOWANCE: .0015[.038] MAX.
MAXIMUM CUT FLASH: .010[.3], CAN NOT EXTEND PAST TAIL.
MINIMUM PUSHOUT FORCE: 1 LB.
MAXIMUM ALLOWABLE BOW: .004[.10] INCH/INCH AFTER ASSEMBLY.
THREADED INSERT MUST HANDLE 25 IN-OZ OF TORQUE WITHOUT
ROTATING OR LOOSENING.
8. THREADED INSERT RETENTION: 10 LBS. MINIMUM.
9. MAX VARATION FROM PIN TO PIN TO BE .002.
10. MEASURED ON UNCUT PARTS.
11. NOTE DELETED.
12. NOTE DELETED.
13. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION
SECTION "A"-"A"
C
IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS
MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION.
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACT: PHOSPHOR BRONZE
F:\DWG\MISC\MKTG\SIB-1XX-XX-XX-S-XX-XX-MKT.SLDDRW
SHEET SCALE: 2:1
DESCRIPTION:
.100 SINGLE INTERFACE BEAM ASSEMBLY
DWG. NO.
BY:
DEAN P
9/20/2000
SHEET 1 OF 2
REVISION Y
FIG 2
SIB-120-02-X-S-E SHOWN
"D" REF
"B"
THREADED INSERT
("C" PLCS)
"B"
SIB-XX-02-S-TI
THREADED INSERT TO BE
FLUSH TO BELOW TOP OF BODY
SECTION "B"-"B"
"B" REF
"A" REF
FIG 3
SIB-120-02-X-S-TI SHOWN
PACKAGING VIEW
(PARTS TO HAVE POSITION #1 LOADED IN
SAME DIRECTION AS ARROW ON TUBE)
NO -LC OPTION
-LC OPTION
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
TUBE: PT-1-24-01-118
PLUG: TP-03
PLUG: TP-03
SHEET SCALE: 2.5:1
DESCRIPTION:
DWG. NO.
BY:
DEAN P
9/20/2000
SHEET 2 OF 2
很抱歉,暂时无法提供与“SIB-106-02-F-S-LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.727251+5.27172
- 25+36.8186325+4.76579
- 50+34.2104650+4.42819
- 100+32.57603100+4.21663
- 500+23.78480500+3.07870
- 1000+20.873541000+2.70187
- 国内价格
- 1+37.83240
- 10+37.00080
- 37+36.43920
