SIP110-PPJC-D10-ST-BK
    SULLINS
    20 Position Ribbon Cable, DIP Header Connector Black IDC 28 AWG Through Hole
SIP110-PPJC-D10-ST-BK 数据手册
Headers .100” [2.54 mm] Contact Centers, IDC Dip Plug Straight - SIP110 Series SPECIFICATIONS • • • • • • Operating Temperature: -40°C to +105°C Current Rating: 1 Amp Dielectric Withstanding: 1,000 VAC Insulation Resistance: 5,000 Megohms For .050” [1.27 mm] Pitch AWG 26-28 Flat Ribbon Cable UL Flammability Rating: 94V-0 PART NUMBER OPTIONS SIP110 - P P P C - D 10 - ST - BK SERIES SIP110 = IDC Dip Plug COLOR BK = Black INSULATOR MATERIAL P = PBT TERMINATION TYPE ST = Straight SK = Straight with Kink CONTACT MATERIAL P = Phosphor Bronze NUMBER OF CONTACT POSITIONS 03 thru 10, 12, 13, 14, 15, 17, 20, 25, 30, 32 CONTACT FINISH - RoHS Compliant P = Gold Flash Overall E = .000100” Pure Tin, Matte, Overall V = Gold Flash on Contact Surface, Nickel on Termination J = .000015” Gold on Contact Surface, Gold Flash on Termination K = .000015” Gold on Contact Surface, Nickel on Termination NUMBER OF ROWS D = Dual Row CONTACT CENTERS C = .100” [2.54 mm] Dimensions in [ ] are in millimeters, all others are in inches. Headers DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com .291 [7.40] STRAIGHT (ST) ASSEMBLED FRONT VIEW WITH KINK (SK) .100 [2.54] .236 [6.00] .236 [6.00] .362 [9.20] .283 [7.20] .050 [1.27] .134 [3.40] STRAIGHT (ST) Example P/N: SIP110-PP_C-D10-ST-BK .091 [2.30] (SK) .094 [2.40] (ST) .100 [2.54] .236 [6.00] 0.358 [9.10] .128 [3.25] .100 [2.54] .024 [0.62] X .012 [0.30] .064 [1.63] WITH KINK (SK) Example P/N: SIP110-PP_C-D15-SK-BK www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 125
- 物料型号:SIP110系列,包括不同配置的IDC排针。 - 器件简介:这些排针适用于0.050" [1.27 mm]间距的AWG 26-28扁平电缆,具有UL 94V-0的阻燃等级。 - 引脚分配:提供不同数量的引脚位置,从3到32不等。 - 参数特性: - 工作温度范围:-40°C 至 +105°C - 电流额定值:1安培 - 介质耐压:1,000 VAC - 绝缘电阻:5,000兆欧 - 功能详解:排针设计有直型(ST)和带弯曲(SK)两种类型,提供不同的接触材料和表面处理,如磷青铜镀金或镍。 - 应用信息:适用于需要高可靠性电气连接的应用。 - 封装信息:提供了详细的尺寸信息,包括引脚中心距、排针长度等,具体尺寸图可在Sullins官网获取。
SIP110-PPJC-D10-ST-BK 价格&库存
很抱歉,暂时无法提供与“SIP110-PPJC-D10-ST-BK”相匹配的价格&库存,您可以联系我们找货
