Emboss Tape
KR CONNECTOR
2.0mm pitch/Disconnectable Insulation displacement connectors
Specifications –––––––––––––––––––
The KR connector features a mounting
height as low as 6.9 mm and a thickness as
thin as 4.8 mm (for top entry type).
It is suitable for interconnection of a wide
range of electronic equipment such as
VCRs, video cameras, car stereo systems
and communication equipment.
• Folded beam double-leaf contact construction
• Twin U-slot insulation displacement section
• Strain relief
• Compatible with the PH crimp style connector
• Surface mount model (SMT)
• Current rating: 1.0 A AC, DC (AWG #26)
• Voltage rating: 100 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 800 VAC/minute
• Applicable wire: UL1571, 1061
(Contact JST for details regarding other UL styles.)
AWG #28, #26
Conductor/ 7 strands, tin-coated
Insulation O.D./ 0.9 to 1.0 mm
(The standard applicable wire for connectors
having 13 circuits or more is UL 1061.)
• Applicable panel thickness: 0.8 to 1.6 mm
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards ––––––––––––––––––––––
Recognized E60389
1Certified LR20812
PC board layout and Assembly layout
Top entry type
Side entry type
4.8
2 ±0.05
8.5
4.8
7.6
6
+0.1
6.9
2 ±0.05
+0.1
φ0.7 0
φ0.7 0
6.25
Note: 1. The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method. If PC board made of hard material are used, the hole dimensions should
be larger. The hole dimensions above should serve as a guideline. Contact JST for details.
Top entry type
1.6
±0.1
1.6
Side entry type
±0.1
2
5
1.5
(2)
±0.1
1.6
±0.1
2
±0.05
±0.05
8.5
End face of wafer on the mating side
7.6
3
5.5
5.5 max
9 min
0.2
±0.1
3.4
6.6
7.5
7.5 min
±0.1
2 max
1
1 min
1 min
Note: 1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details.
1
(1)
KR CONNECTOR
Socket
Model No.
Normal type
02KR-6H-P
03KR-6H-P
04KR-6H-P
05KR-6H-P
06KR-6H-P
07KR-6H-P
08KR-6H-P
09KR-6H-P
10KR-6H-P
11KR-6H-P
12KR-6H-P
13KR-6H-P
14KR-6H-P
15KR-6H-P
16KR-6H-P
Circuits
2
5.15
B
2
3
0.9
A
4
2
5
6
3.5
4.2
7
H JST
8
9
10
11
Circuit No.1
12
13
14
15
16
Dimensions (mm)
A
B
Q'ty/
box
2.0
6.0
2,000
4.0
8.0
2,000
6.0
10.0
2,000
8.0
12.0
2,000
10.0
14.0
2,000
12.0
16.0
1,000
14.0
18.0
1,000
16.0
20.0
1,000
18.0
22.0
1,000
20.0
24.0
1,000
22.0
26.0
1,000
24.0
28.0
500
26.0
30.0
500
28.0
32.0
500
30.0
34.0
500
Material and Finish
2
Contact: Phosphor bronze, tin-plated (reflow treatment)
Housing: 2 to 12 circuits/ PA 66, UL94V-0, gray
13 to 16 circuits/ Glass-filled PA 66, UL94V-0, gray
5.15
B
A
0.9
2
3.5
4.2
RoHS compliance
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
H JST
Circuit No.1
02KR-6H-PStandard color: H…gray
Others: K…black
E…blue
R…red
Shrouded header
The shrouded headers are interchangeable with those of the PH crimp style connectors and CR and KRD insulation displacement
connectors.
2
很抱歉,暂时无法提供与“04KR-6H-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.13570
- 25+1.91027
- 100+1.81535
- 250+1.62551
- 2000+1.40007
- 10000+1.38821
- 国内价格 香港价格
- 1+0.973671+0.12543
- 10+0.6403410+0.08249
- 50+0.5701750+0.07345
- 100+0.51754100+0.06667
- 500+0.49122500+0.06328
- 1000+0.482451000+0.06215
- 2000+0.473682000+0.06102
- 国内价格 香港价格
- 1+2.816531+0.36284
- 10+2.3903310+0.30793
- 25+2.2362225+0.28808
- 50+2.1305750+0.27447
- 100+2.02865100+0.26134
- 250+1.90104250+0.24490
- 500+1.81015500+0.23319
- 2000+1.641352000+0.21145
- 4000+1.562984000+0.20135
