SFH413-PPPB-D13-ID-BK
    SULLINS
    CONN RCPT 26POS 1.27MM IDT GOLD
SFH413-PPPB-D13-ID-BK 数据手册
Headers .050” [1.27 mm] Contact Centers, IDC Sockets, .100” [2.54 mm] Row Spacing Insulation Displacement With or Without Strain Relief - SFH Series Mates with SBH41 series (See opposite page) SPECIFICATIONS • • • • • • • Centered Polarizing Key Operating Temperature: -40°C to +105°C UL Flammability Rating: 94V-0 Contact Resistance: 30 Megohms Max. Current Rating: 1 Amp Dielectric Withstanding: 500 VAC Insulation Resistance: 1000 Megohms PART NUMBER OPTIONS SFH41 - P P P B - D 10 - ID - BK SERIES SFH41 = IDC Socket Without Strain Relief, .050” [1.27 mm] Contact Centers by .100” [2.54 mm] Row Spacing SFH413 = IDC Socket With Strain Relief, .050” [1.27 mm] Contact Centers by .100” [2.54 mm] Row Spacing INSULATOR MATERIAL P = PBT CONTACT MATERIAL P = Phosphor Bronze COLOR BK = Black TERMINATION TYPE ID = Insulation Displacement NUMBER OF CONTACT POSITIONS 05, 08, 10, 13, 15, 17, 20, 25, 30, 34, 40, 50 NUMBER OF ROWS D = Dual Row CONTACT CENTERS B = .050” [1.27 mm] CONTACT FINISH - RoHS Compliant P = Gold Flash Overall E = .000100” Pure Tin, Matte, Overall V = Gold Flash on Contact Surface, Nickel on Termination Dimensions in [ ] are in millimeters, all others are in inches. .305[7.75] .025[0.64] Headers DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com .025[0.64] .209[5.30] INSULATION DISPLACEMENT (ID) without Strain Relief Requires SFH41 .100[2.54] .236[6.00] .050[1.27] Example P/N: SFH41-PPPB-D20-ID-BK .354[9.00] .025[0.64] .305[7.75] .025[0.64] .209[5.30] INSULATION DISPLACEMENT (ID) with Strain Relief Requires SFH413 Example P/N: SFH413-PPPB-D20-ID-BK .100[2.54] .236[6.00] .050[1.27] www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 103
PDF文档中提到的物料型号为SFH41系列,具体型号为SFH41-PPPB-D20-ID-BK和SFH413-PPPB-D20-ID-BK。
这些是IDC插座,具有不同的接触中心间距和排间距,以及有无应变缓解选项。
器件简介包括: - 中心极化键 - 工作温度范围:-40°C至+105°C - UL阻燃等级:94V-0 - 接触电阻:最大30兆欧 - 电流额定值:1安培 - 介质耐压:500 VAC - 绝缘电阻:1000兆欧
引脚分配参数特性包括: - 接触中心间距:.050" [1.27 mm] - 排间距:.100" [2.54 mm] - 接触材料:磷青铜(P)或金闪光(P) - 接触完成:纯锡,亚光整体或金闪光接触表面,镍在终止接触 - 绝缘体材料:PBT(P)
封装信息包括尺寸和颜色选项,具体尺寸图可在Sullins官方网站上查看。
功能详解应用信息未在文档摘要中提及,可能需要查看完整的PDF文档以获取更多信息。
SFH413-PPPB-D13-ID-BK 价格&库存
很抱歉,暂时无法提供与“SFH413-PPPB-D13-ID-BK”相匹配的价格&库存,您可以联系我们找货
