TCSD-05-01-N
TCSD-05-01-N
    SAMTEC(申泰)
    P=2mm
TCSD-05-01-N 数据手册
REVISION AK DO NOT SCALE FROM THIS PRINT TCSD-XX-X-XX.XX-01-XXX-XXX NOTES: 1. HIDDEN LINES ARE USED TO SHOW POLARIZATION WHEN USING -N OPTION. 2. C REPRESENTS A CRITICAL DIMENSION. 3. AS OF REV 'C' ON TCB-50 CABLE ASSEMBLIES WILL BE LEAD FREE. 4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED FOR SHORTS AND OPENS. 5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 800V. 6. STRAIN RELIEF TO WITHSTAND 5LB STRAIGHT PULL. 7.WHEN CUTTING CABLE TO LENGTH, CONDUCTORS MAY NOT EXTEND PAST THE CABLE INSULATION. AK OPTIONS #1 SEE OPTIONS BELOW LEAD STYLE END ASSEMBY -S: SINGLE -D: DOUBLE -D: (DOUBLE END) C1 OPTIONS #2 SEE OPTIONS BELOW No OF POSITIONS 03, 04, 05, 07, 08, 10, 12, 13, 15, 17, 20, 22, 25 NOTE: OTHER POSITIONS AVAILABLE AS ASO. TOOL IS CAPABLE OF POSITIONS 2-25 ASSEMBLY LENGTH (2 INCH MINIMUM) XX.XX[XX INCHES x 25.4] ±.125[3.175] (SEE NOTE 7) AK -S (SINGLE END) C1 (SAME AS -D UNLESS OTHERWISE STATED) XX.XX[XX INCHES x 25.4] ±.125[3.175] (SEE NOTE 7) AK .125 3.18 REF .158 4.00 REF (No. OF POS. x .07874[2.0000]) + .15748[4.0000] REF C2 .200±.010 5.08±0.254 COLORED WIRE TO SIDE OF FIRST POS. INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. .010 0.25 MAX CABLE OVERHANG (TYP) (SEE NOTE 7) AK 2 -N OPTION -N OPTION -RN1 OPTION 1 .040 1.02 REF -RN2 OPTION -N: NOTCH POLARIZATION (USE TCSD-XX-XX-N) (AVAILABLE ON POS 04 THRU 25) 02 -RW: REVERSE WIRING (NOT AVAILABLE WITH -RN1 OR -RN2 OPTIONS) COLORED WIRE TO OPPOSITE SIDE OF FIRST POS. INDICATOR 01 .040 1.02 REF NOTCH DENOTES FIRST POSITION .125 3.18 REF F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. MATERIAL: DO NOT SCALE DRAWING INSULATOR: BLACK PBT CONTACT: HEAT TREATED BeCu STRAIN RELIEF: BLACK PBT PLATING: -L: .000015 GOLD ON CONTACT AREA, TIN ON REMAINDER -F: .000003 GOLD ON CONTACT AREA, TIN ON REMAINDER (STANDARD PLATING IS .000030 GOLD ON CONTACT AREA, TIN ON REMAINDER) SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-XXX-XXX BY: B RAY 11/20/2007 SHEET 1 OF 3 -M: MIDDLE REVERSED -O: OUTSIDE REVERSED REVISION AK -P"XX": POLARIZED MATING 01 03 02 02 01 03 01 NOTE: THE SAME POSITION WILL BE POLARIZED ON BOTH ENDS (USE PK-07-N) 01 02 01 01 01 COLORED WIRE TO SIDE OF FIRST POS. INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. 02 01 COLORED WIRE TO SIDE OF FIRST POS. INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. XX±.125[3.18] (MIN 2") XX±.125[3.18] (MIN 2") -RN1 OR -RN2 (REVERSE POLARIZATION NOTCH) TCSD-05-D-XX-01-RN2 SHOWN MIDDLE SOCKET REVERSED WHEN DAISY CHAINED OUTSIDE SOCKET REVERSED WHEN DAISY CHAINED -R: REVERSE CONNECTOR -D"XX": DAISY CHAINED (NOT AVAILABLE WITH -RN1 OR -RN2 OPTION) (2" MIN LENGTH, 1" INCREMENTS ONLY) FIRST CONNECTOR SECOND CONNECTOR TCSD-05-D-XX-01-RN1 SHOWN 01 01 01 01 02 02 COLORED WIRE TO SIDE OF FIRST POS. INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. 01 01 COLORED WIRE TO SIDE OF FIRST POS. INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. XX±.125[3.18] 6.70 (MIN 2") XX±.125[3.18] 6.70 (MIN 2") PROPRIETARY NOTE NOTE: -RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY AVAILABLE FOR POSITIONS 4 OR GREATER (NOT AVAILABLE WITH -R OR -RW OPTIONS) -RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY (NOT AVAILABLE WITH -R OR -RW OPTIONS) (REVERSE NOTCH NOT AVAILABLE WITH DAISY CHAIN OPTIONS) THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING BOTH SOCKETS REVERSED WHEN DAISY CHAINED F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-XXX-XXX BY: B RAY 11/20/2007 SHEET 2 OF 3 REVISION AK -SR: STRAIN RELIEF (NOT AVAILABLE WITH -O, -M, -R, -D"XX" OR -B"XX") (SAME AS -D, UNLESS OTHERWISE STATED) (SOLD IN ASSEMBLIES ONLY) (MUST USE HEAT BEND/STRAIN RELIEF TOOL ON POSITIONS 20-25) -B"XX": BREAKOUT OPTION 6 XX (No. OF POS.) x .07874[2.0000] + .31000[7.8740] REF 2 5.000[127.00] MAX 2.000[50.80] MIN .039 1.00 REF 4 .310±.010 7.87±0.25 5 "XX" = NO. OF CONDUCTORS BROKEN OUT FROM THE FIRST POSITION. 3 IN-PROCESS 2 IN-PROCESS 1 (-SR ONLY) (-SR ONLY) 3 3 (XX.XX[XX INCHES x 25.4]+.5[19.1]) ±.125[3.175] (XX.XX[XX INCHES x 25.4] ±.125[3.175] PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-XXX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-XXX-XXX BY: B RAY 11/20/2007 SHEET 3 OF 3
TCSD-05-01-N 价格&库存
很抱歉,暂时无法提供与“TCSD-05-01-N”相匹配的价格&库存,您可以联系我们找货
TCSD-05-01-N
  • 41+45.60726
  • 82+37.72393
  • 123+26.23748
  • 533+24.94374
  • 1025+23.32355
  • 2501+19.63579
  • 5002+17.14505
库存:250
