04HR-6S-P-N
04HR-6S-P-N
    JST
    P=2.5mm
    这款用于印刷电路板的2.5mm间距连接器结构轻薄。直插式方法为终端用户提供了高密度连接能力。
04HR-6S-P-N 数据手册
Radial Tape HR CONNECTOR 2.5mm pitch/Disconnectable Insulation displacement connectors Specifications ––––––––––––––––––– JS T5 This 2.5mm pitch connector for printed circuit boards has a thin construction. The in-line method provides high-density capability to the end user. • Twin U-slot insulation displacement section • Thin design • High reliability • Strain relief • Interchangeability • Current rating: 2A AC, DC (AWG #24) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,000V AC/minute • Applicable wire: UL1007(Contact JST for details regarding other UL styles.) AWG #28, #26, #24 Conductor/7 strands, tin-coated Insulation O.D./1.0 to 1.5mm • Applicable PC board thickness: 0.8 to 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R50082349 PC board layout (viewed from soldering side) and Assembly layout Top entry type Side entry type 4.1 2.5 ±0.05 2.5 min 2.5 min 11.3 4.2 6.7 min 13.5 2.2 min 2.5 ±0.05 φ0.9 +0.1  0 φ0.9 +0.1  0 6.7 Top entry type on radial-tape 4.4 2.5 min 11.8 2.2 min 2.5 ±0.05 φ0.9 +0.1  0 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 1 HR CONNECTOR Socket Model No. 4.1 AWG #28 (green) AWG #26 (natural/white) AWG #24 (black) 2 02HR-8M-P-N 03HR-8M-P-N 04HR-8M-P-N 05HR-8M-P-N 06HR-8M-P-N 07HR-8M-P-N 08HR-8M-P-N 09HR-8M-P-N 10HR-8M-P-N 11HR-8M-P-N 12HR-8M-P-N 13HR-8M-P-N ― 02HR-6S-P-N 03HR-6S-P-N 04HR-6S-P-N 05HR-6S-P-N 06HR-6S-P-N 07HR-6S-P-N 08HR-6S-P-N 09HR-6S-P-N 10HR-6S-P-N 11HR-6S-P-N 12HR-6S-P-N 13HR-6S-P-N *15HR-6S-P-N 02HR-4K-P-N 03HR-4K-P-N 04HR-4K-P-N 05HR-4K-P-N 06HR-4K-P-N 07HR-4K-P-N 08HR-4K-P-N 09HR-4K-P-N 10HR-4K-P-N 11HR-4K-P-N 12HR-4K-P-N 13HR-4K-P-N *15HR-4K-P-N 3 4 5 10.3 6 7 8 9 10 3.6 2.5 2.5 A B Dimensions (mm) Circuits 11 12 13 15 B Q'ty / box 2.5 7.5 1,000 5.0 10.0 1,000 7.5 12.5 1,000 10.0 15.0 1,000 12.5 17.5 1,000 15.0 20.0 500 17.5 22.5 500 20.0 25.0 500 22.5 27.5 500 25.0 30.0 500 27.5 32.5 500 30.0 35.0 250 35.0 40.0 250 A Material and Finish Contact: coppe alloy, tin-plated (reflow treatment) Housing: PA 66, UL94V-0 ¨ V approved. Note: 1. Not TU 2. *Marked products are not also UL/CSA approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02HR-4K-P-Nstandard color AWG#28: M…green, AWG#26: S…natural (white) AWG#24: K…black R…red TR…tomato red Y…yellow L…lemon yellow N…brown E…blue O…orange Shrouded header The shrouded headers are interchangeable with those of the EH and HR crimp style connectors. 2
04HR-6S-P-N 价格&库存
很抱歉,暂时无法提供与“04HR-6S-P-N”相匹配的价格&库存,您可以联系我们找货
04HR-6S-P-N
    • 1000+0.48880
    库存:15000
    04HR-6S-P-N
    • 10+2.01300
    • 250+1.97343
    • 500+1.93385
    库存:520
    04HR-6S-P-N
    • 1+2.022491+0.26249
