06KR-6H-P
06KR-6H-P
    JST
    P=2mm
06KR-6H-P 数据手册
Emboss Tape KR CONNECTOR 2.0mm pitch/Disconnectable Insulation displacement connectors Specifications ––––––––––––––––––– The KR connector features a mounting height as low as 6.9 mm and a thickness as thin as 4.8 mm (for top entry type). It is suitable for interconnection of a wide range of electronic equipment such as VCRs, video cameras, car stereo systems and communication equipment. • Folded beam double-leaf contact construction • Twin U-slot insulation displacement section • Strain relief • Compatible with the PH crimp style connector • Surface mount model (SMT) • Current rating: 1.0 A AC, DC (AWG #26) • Voltage rating: 100 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: UL1571, 1061 (Contact JST for details regarding other UL styles.) AWG #28, #26 Conductor/ 7 strands, tin-coated Insulation O.D./ 0.9 to 1.0 mm (The standard applicable wire for connectors having 13 circuits or more is UL 1061.) • Applicable panel thickness: 0.8 to 1.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1Certified LR20812 PC board layout and Assembly layout Top entry type Side entry type 4.8 2 ±0.05 8.5 4.8 7.6 6 +0.1 6.9 2 ±0.05 +0.1 φ0.7  0 φ0.7  0 6.25 Note: 1. The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. If PC board made of hard material are used, the hole dimensions should be larger. The hole dimensions above should serve as a guideline. Contact JST for details. Top entry type 1.6 ±0.1 1.6 Side entry type ±0.1 2 5 1.5 (2) ±0.1 1.6 ±0.1 2 ±0.05 ±0.05 8.5 End face of wafer on the mating side 7.6 3 5.5 5.5 max 9 min 0.2 ±0.1 3.4 6.6 7.5 7.5 min ±0.1 2 max 1 End face of wafer on the mating side 1 min 1 min Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 (1) KR CONNECTOR Socket Model No. Normal type 02KR-6H-P 03KR-6H-P 04KR-6H-P 05KR-6H-P 06KR-6H-P 07KR-6H-P 08KR-6H-P 09KR-6H-P 10KR-6H-P 11KR-6H-P 12KR-6H-P 13KR-6H-P 14KR-6H-P 15KR-6H-P 16KR-6H-P Circuits 2 5.15 B 2 3 0.9 A 4 2 5 6 3.5 4.2 7 H JST 8 9 10 11 Circuit No.1 12 13 14 15 16 Dimensions (mm) A B Q'ty/ box 2.0 6.0 2,000 4.0 8.0 2,000 6.0 10.0 2,000 8.0 12.0 2,000 10.0 14.0 2,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 20.0 24.0 1,000 22.0 26.0 1,000 24.0 28.0 500 26.0 30.0 500 28.0 32.0 500 30.0 34.0 500 Material and Finish 2 Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: 2 to 12 circuits/ PA 66, UL94V-0, gray 13 to 16 circuits/ Glass-filled PA 66, UL94V-0, gray 5.15 B A 0.9 2 3.5 4.2 RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. H JST Circuit No.1 02KR-6H-PStandard color: H…gray Others: K…black E…blue R…red Shrouded header The shrouded headers are interchangeable with those of the PH crimp style connectors and CR and KRD insulation displacement connectors. 2
06KR-6H-P 价格&库存
很抱歉,暂时无法提供与“06KR-6H-P”相匹配的价格&库存,您可以联系我们找货
06KR-6H-P
    • 2000+0.42030
    库存:8000
    06KR-6H-P
    • 1+1.03957
    • 10+0.90386
    • 25+0.80624
    • 50+0.71784
    • 100+0.65280
    • 250+0.61747
    • 500+0.59231
    • 1000+0.56812
    • 2000+0.54488
    • 6000+0.50487
    库存:2197
    06KR-6H-P
    • 1+3.353331+0.43385
    • 10+2.8439310+0.36794
    • 25+2.6634425+0.34459
    • 50+2.5363650+0.32815
    • 100+2.41451100+0.31238
    • 250+2.26301250+0.29278
    • 500+2.15491500+0.27880
    • 2000+1.953902000+0.25279
    • 4000+1.860604000+0.24072
    库存:7155
