02SUR-32S
02SUR-32S
    JST
    P=0.8mm
02SUR-32S 数据手册
Emboss Tape SUR CONNECTOR 0.8mm pitch/Disconnectable Insulation displacement connectors Specifications ––––––––––––––––––– The world's first 0.8 mm pitch wire-to-board insulation displacement connector. Side entry type is only 3.9 mm depth and 1.75 mm height after mounting on the PC board, and top entry type is only 2.2 mm depth and 3.9 mm height. Compared to the conventional 1.0 mm pitch SSR connector, occupation space on the board is reduced by 34% (side entry type). • 3-point grip construction • Super fine wires are applicable • Shrouded header • Twin U-slot insulation displacement section • Current rating: 0.5 A AC, DC (AWG #32) 0.2 A AC, DC (AWG #36) • Voltage rating: 30 V DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests / 40 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 200 VAC/minute • Applicable wire: Conductor size/ AWG #32, #36 Conductor/ 7 strands, tin-coated copper alloy Insulation O.D./ 0.39 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout and Assembly layout Top entry type Side entry type 2.25 2 0.8 ±0.05 ±0.1 1 0.7 ±0.1 1.2 ±0.1 ±0.1 ±0.1 1.7 Header outline 0.35 ±0.1 ±0.1 1.1 0.8±0.05 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Dimensions above should serve as a guideline. Contact JST for details. 1 1.75 ±0.1 1.7 3.95 0.5±0.05 2.3 1.2 0.5 ±0.05 3.9 ±0.1 ±0.1 0.7 ±0.1 0.3 Header outline SUR CONNECTOR Socket Circuits 2 3 4 5 Circuit No.1 6 1.25 1.45 1.65 8 10 12 H JST 5 14 0.8 A 15 1.7 0.8 2.9 16 17 B 20 22 Model No. Dimensions (mm) #32(Natural) #36(Lemon yellow) A B 02SUR-32S 0.8 2.4 02SUR-36L 1.6 3.2 03SUR-32S 03SUR-36L 2.4 4.0 04SUR-32S 04SUR-36L 4.8 3.2 05SUR-32S 05SUR-36L 4.0 5.6 06SUR-32S 06SUR-36L 5.6 7.2 08SUR-32S 08SUR-36L 7.2 8.8 10SUR-32S 10SUR-36L 10.4 8.8 12SUR-32S 12SUR-36L 12.0 10.4 14SUR-32S 14SUR-36L 11.2 12.8 15SUR-32S 15SUR-36L 12.0 13.6 16SUR-32S 16SUR-36L 12.8 14.4 17SUR-32S 17SUR-36L 15.2 16.8 20SUR-32S 20SUR-36L 16.8 18.4 22SUR-32S 22SUR-36L Q'ty /box 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 Material and Finish Contact: Copper alloy, tin-plated (reflow treatment) Housing: PA, UL94V-0 RoHS compliance Shrouded header Top entry type Circuits 2 B 2 3 4 2.7 5 6 8 10 0.6 A 12 1 14 15 Side entry type 16 17 B 20 A 0.8 22 2.7 Q'ty/reel Top entry type Side entry type 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 2,500 3,500 ― 3,500 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 1.75 Circuit No.1 Dimensions (mm) Model No. A B Top entry type Side entry type BM02B-SURS-TF SM02B-SURS-TF 0.8 3.8 1.6 4.6 BM03B-SURS-TF SM03B-SURS-TF 5.4 2.4 BM04B-SURS-TF SM04B-SURS-TF 3.2 6.2 BM05B-SURS-TF SM05B-SURS-TF 7.0 4.0 BM06B-SURS-TF SM06B-SURS-TF 5.6 8.6 BM08B-SURS-TF SM08B-SURS-TF 7.2 10.2 BM10B-SURS-TF SM10B-SURS-TF 11.8 8.8 BM12B-SURS-TF SM12B-SURS-TF 10.4 13.4 BM14B-SURS-TF SM14B-SURS-TF 11.2 14.2 BM15B-SURS-TF SM15B-SURS-TF 12.0 15.0 BM16B-SURS-TF SM16B-SURS-TF 12.8 15.8 BM17B-SURS-TF SM17B-SURS-TF 15.2 18.2 BM20B-SURS-TF SM20B-SURS-TF 16.8 19.8 ― SM22B-SURS-TF 1 0.2 1 0.45 RoHS compliance This product displays (LF)(SN) on a label. Note: These products listed above are supplied on embossed-tape. 2
02SUR-32S 价格&库存
很抱歉,暂时无法提供与“02SUR-32S”相匹配的价格&库存,您可以联系我们找货
02SUR-32S
    • 2000+0.51700
    库存:48000
    02SUR-32S
      • 1+1.377171+0.17741
      • 10+1.2017310+0.15481
      • 50+0.8420950+0.10848
      • 100+0.76314100+0.09831
      • 500+0.71051500+0.09153
      • 1000+0.684201000+0.08814
      • 2000+0.666662000+0.08588
      库存:4624
      02SUR-32S
        02SUR-32S
          • 2000+0.51240
          库存:66000
          02SUR-32S
            • 2000+0.68190
            库存:20000
