07ZR-8M-P
07ZR-8M-P
    JST
    P=1.5mm
07ZR-8M-P 数据手册
圧 接 Emboss Tape ZR CONNECTOR 1.5mm pitch/Disconnectable Insulation displacement connectors Specifications ––––––––––––––––––– The twin U-slots (IDC slots), the 3-point insulation grip, and the distortion resistant disconnectable construction ensure a reliable connection even during severe environmental conditions. • Compact • Twin U-slot insulation displacement section • 3-point grip construction • Distortion resistant construction • Compatible with the ZH crimp style connector • Current rating: 0.7A AC, DC (AWG #28) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/30m Ω max. • Insulation resistance: 500M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: UL1571(Contact JST for details regarding other UL styles.) AWG #30, #28 Conductor/7 strands, tin-coated Insulation O.D./0.7 to 0.8mm (Contact JST for diameters greater than 0.8mm.) • Applicable PC board thickness: 0.6 to 1.2mm,1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 Through-hole type PC board layout (viewed from soldering side) and Assembly layout Side entry type Top entry type 1.5 ±0.05 3.5 1.5 min 1.5 ±0.05 1.5 min 2.7 3.7 4.6 min 5.5 2.2 min 7.0 2.7 φ0.7 ±0.03 4.6 φ0.7 ±0.03 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 3. As for the PC board layout for the SMT type shrouded headers, refer to that of the ZH connector. 1 ZR CONNECTOR Socket Circuits 2 3 A 1.5 4 1.5 4.4 5 6 2.7 3.1 7 8 9 H JST B 4.1 10 11 12 13 Model No. AWG #30(natural/gray) AWG #28(green) 02ZR-8M-P 02ZR-3H-P 03ZR-8M-P 03ZR-3H-P 04ZR-8M-P 04ZR-3H-P 05ZR-8M-P 05ZR-3H-P 06ZR-8M-P 06ZR-3H-P 07ZR-8M-P 07ZR-3H-P 08ZR-8M-P 08ZR-3H-P 09ZR-8M-P 09ZR-3H-P 10ZR-8M-P 10ZR-3H-P 11ZR-8M-P 11ZR-3H-P 12ZR-8M-P 12ZR-3H-P 13ZR-8M-P 13ZR-3H-P Dimensions (mm) A B Q'ty / box 1.5 4.5 2,000 3.0 6.0 2,000 4.5 7.5 2,000 6.0 9.0 2,000 7.5 10.5 2,000 9.0 12.0 2,000 10.5 13.5 2,000 12.0 15.0 2,000 13.5 16.5 2,000 15.0 18.0 2,000 16.5 19.5 2,000 18.0 21.0 2,000 Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: Glass-filled PA 66, UL94V-0 RoHS compliance ¨ V approved. Note: Not TU As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02ZR-3H-Pstandard color AWG#30: H…gray AWG#28: M…green K…black R…red E…blue Shrouded header The shrouded headers are interchangeable with those of the ZH crimp style connectors. 2
07ZR-8M-P 价格&库存
很抱歉,暂时无法提供与“07ZR-8M-P”相匹配的价格&库存,您可以联系我们找货
07ZR-8M-P
    • 2000+0.67330
    库存:2000
