08SR-3S
08SR-3S
    JST
    P=1mm
08SR-3S 数据手册
Emboss Tape SR /SZ CONNECTOR 1.0mm pitch/Disconnectable Insulation displacement connectors Specifications ––––––––––––––––––– JS T 9 • Compact insulation displacement connector • Header designed for vacuum pick and place robotics • Twin U-slot insulation displacement section • 3-point grip construction • Through-hole type (SZ) • Current rating: 0.7A DC • Voltage rating: 50V DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: Conductor size/AWG #30 Conductor/7 strands, tin-coated annealed copper Insulation O.D./0.54 to 0.58mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout (viewed from component side) and Assembly layout Top entry type Side entry type 3.5 Circuit No.1 5.4 Header outline 2±0.05 φ0.7±0.03 5.1 2±0.05 Circuit No.1 4 2.5±0.05 2±0.05 2±0.05 φ0.7±0.03 Header outline 1±0.05 2±0.05 1±0.05 Top entry type Side entry type 0.6±0.05 1.0±0.05 2.9 0.7±0.1 1.2±0.1 5.55±0.1 4.0±0.1 1.8±0.1 Header outline 0.2±0.1 4.2±0.1 1.8±0.1 0.7±0.1 1.2±0.1 0.2±0.1 4.9 Header outline 2.95 4.85 1.0±0.05 2.65±0.1 0.6±0.05 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Dimensions above should serve as a guideline. Contact JST for details. 3. Hole dimensions differ according to the kind of PC board and piercing method. 4. If using double-sided through-hole PC board, it is necessary to confirm the resistance to the soldering heat on the PC board to be used and the soldering condition. Single sided paper based phenolic resin copper-clad PC board (t1.6) is recommended for a PCB used. 1 SR /SZ CONNECTOR Socket Circuits Model No. 2 1.0 3.0 2,000 3 03SR-3S 2.0 4.0 2,000 4 04SR-3S 3.0 5.0 2,000 5 05SR-3S 4.0 6.0 2,000 6 06SR-3S 5.0 7.0 2,000 7 07SR-3S 6.0 8.0 2,000 8 08SR-3S 7.0 9.0 2,000 9 09SR-3S 8.0 10.0 2,000 10 10SR-3S 9.0 11.0 2,000 11 11SR-3S 10.0 12.0 2,000 12 12SR-3S 11.0 13.0 2,000 13 13SR-3S 12.0 14.0 2,000 14 14SR-3S 13.0 15.0 2,000 3.6 1.0 A 2.1 Q'ty / box B 02SR-3S 2.45 B Dimensions (mm) A Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA, UL94V-0, natural RoHS compliance Shrouded header (Through-hole type) Model No. Circuits Top entry type Side entry type 3 B03B-SZ S03B-SZ Side entry type B 2.0 5.2 12,825 9,405 4 B04B-SZ S04B-SZ 3.0 6.2 10,800 7,920 5 B05B-SZ S05B-SZ 4.0 7.2 9,225 6,765 6 B06B-SZ S06B-SZ 5.0 8.2 8,100 5,940 7 B07B-SZ S07B-SZ 6.0 9.2 7,200 5,280 8 B08B-SZ ― 7.0 10.2 6,525 ― 9 B09B-SZ ― 8.0 11.2 5,850 ― 11 B11B-SZ ― 10.0 13.2 4,950 ― 14 *B14B-SZ ― 13.0 16.2 4,050 ― 2.7 4 4.5 Circuit No.1 Q'ty / box Dimensions (mm) A B Top entry type Side entry type Material and Finish 1 2.5 0.45 Contact: Brass, tin-plated (reflow treatment) Housing: Glass-filled PBT, UL94V-0, natural (white) A Top entry type RoHS compliance Note: *Marked product is not UL approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3.5 B S03B-SZLE(blank)...natural (white) LE...light blue 2.7 4.8 ex. Circuit No.1 1 A 0.55 2 2 SR /SZ CONNECTOR Shrouded header (SMT type) Model No. Circuits Top entry type Side entry type 2 BM02B-SRSS-TB SM02B-SRSS-TB Side entry type 2.9 B A 1.5 1.0 0.7 4.25 Top entry type B 1.0 4.0 1,500 3,000 3 BM03B-SRSS-TB SM03B-SRSS-TB 2.0 5.0 1,500 3,000 4 BM04B-SRSS-TB SM04B-SRSS-TB 3.0 6.0 1,500 3,000 5 BM05B-SRSS-TB SM05B-SRSS-TB 4.0 7.0 1,500 3,000 6 BM06B-SRSS-TB SM06B-SRSS-TB 5.0 8.0 1,500 3,000 7 BM07B-SRSS-TB SM07B-SRSS-TB 6.0 9.0 1,500 3,000 8 BM08B-SRSS-TB SM08B-SRSS-TB 7.0 10.0 1,500 3,000 9 BM09B-SRSS-TB SM09B-SRSS-TB 8.0 11.0 1,500 3,000 10 BM10B-SRSS-TB SM10B-SRSS-TB 9.0 12.0 1,500 3,000 11 BM11B-SRSS-TB SM11B-SRSS-TB 10.0 13.0 1,500 3,000 12 BM12B-SRSS-TB SM12B-SRSS-TB 11.0 14.0 1,500 3,000 13 BM13B-SRSS-TB SM13B-SRSS-TB 12.0 15.0 1,500 3,000 14 BM14B-SRSS-TB SM14B-SRSS-TB 13.0 16.0 1,500 3,000 4.25 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 1.0 A 3 Q'ty / reel Dimensions (mm) A B Top entry type Side entry type 1.5 0.7 2.9 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the top entry type headers with suction cap.
08SR-3S 价格&库存
很抱歉,暂时无法提供与“08SR-3S”相匹配的价格&库存,您可以联系我们找货
08SR-3S
  • 1+4.687521+0.60641
08SR-3S
    • 2000+1.38080
    库存:4000
    08SR-3S
    • 1+3.869591+0.50059
    • 5+3.502725+0.45313
    • 10+3.2668810+0.42262
    • 25+2.9524225+0.38194
    • 50+2.7427850+0.35482
    • 100+2.57682100+0.33335
    • 250+2.40212250+0.31075
    • 2000+2.192482000+0.28363
    库存:955
    08SR-3S
      08SR-3S
        • 1+3.502721+0.45313
        • 10+2.7427810+0.35482
        • 50+2.2099550+0.28589
        • 100+1.85181100+0.23956
        • 500+1.78194500+0.23052
        • 1000+1.720791000+0.22261
        • 2000+1.694592000+0.21922
        库存:1177
        08SR-3S
          库存:2000
