03KR-6H-P
03KR-6H-P
    JST
    P=2mm
03KR-6H-P 数据手册
KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS ラジアル ラジアル 2.0 mm pitch/Disconnectable IDC and Crimp style connectors PH connector: Side entry type header (for PHN and   KR receptacles) TR connector: Unit for wire-to-wire connection (for PHN and KR receptacles) KR connector: IDC receptacle ● Multi-IDC-harnesses are possible ● Various types of connectors ● KR一般仕様 Cost reduction ● Two types of circuit layouts KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS PHN connector: Crimp style receptacle KRW connector: Holder PHN connector: Crimp style receptacle KRW connector: Side entry type header ■一般仕様 Specifications Series Item KRW connector Curren rating TR・TRW connector 1.0 A AC/DC(AWG#26) Voltage rating 100 V AC/DC Temperaure rise Contact rasistance KRW connector: Top entry type header KR connector: IDC receptacle PH connector: Top entry type header (for PHN and KR receptacles) With the JST standard product KR connector KRファミリー姿図 as the core, according to using multi-harness insulation displacement connection by an automatic IDC machine, a holder for making a dual-row socket, a corresponding dual-row header, a header for wire-to-wire connection and so on, the high-density mounting of harnesses such as complicated shape is enabled. ® -25℃ to +85℃(including temperature rise) Initial/10 mΩ max. After environmental tests/20 mΩ max. Insulation resistance 1,000 MΩ min. Withstanding voltage 800 VAC/minute Applicable connector KR connector, CR connector, PHN connector Applicable PC board thickness 1.6 mm - Applicable panel thickness - 0.5 mm to 2 mm * In using the products, refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards Recognized E60389 Certified LR20812 R75087: PH, PHN connectors ® ® ® Top entry type Top entry type (2) 1 Reverse type: Circuit No.1 7.5 min. 6.9 1.5±0.05 2 ±0.05 3 ±0.1 +0.1 φ0.7 0 5 Normal type: Circuit No.1 2 max. 1.5±0.05 Reverse type: Circuit No.1 4.8 6 +0.1 φ0.8 0 7.5 Single-row header ® 6.6 PC board layout and Assembly layout Normal type: Circuit No.1 1 min. 2 ±0.05 1.6±0.1 1.6±0.1 Edge of the shrouded header (mating side) Side entry type 8.5 +0.1 φ0.7  0 Side entry type Normal type: Circuit No.1 7.6 2±0.05 Reverse type: Circuit No.1 8.5 (1) 1.6±0.1 1 Note: 1. Tolerances are non-cumulative: ± 0.05 mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method.  Please contact JST for details as the dimensions     shown in the above figure are reference values. 5.5 6.25 1 min. 2 ±0.05 0.2 Normal type: Circuit No.1 3.4±0.1 9 min. Reverse type: Circuit No.1 5.5 max. 4.8 7.6 1.5±0.1 Edge of the shrouded header (mating side) Note: 1 . Tolerances are non-cumulative: ± 0.05 mm for all centers. 2. Please contact JST for details as the dimensions shown in the above figure are reference values. KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS PC board layout and Assembly layout Dual-row header (viewed from component side) Top entry type Reverse type: Line A/Circuit No.1 KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS A±0.1 2 ±0.05 6.5±0.05 Normal type: Line A/Circuit No.1 A 2±0.05 6.5±0.05 Line A +0.1 φ0.8 0 Line B Normal type: Line B/Circuit No.1 Line B/ Circuit No.1 Line B/Circuit No.1 (With a compact boss) Side entry type 2±0.05 5.8±0.1 Normal type: Line B/Circuit No.1 SIDE TYPE A±0.1 Reverse type: +0.1 Lineφ0.8 A/Circuit No.1  0 with PHN receptacles (With a standard boss) Reverse type: LineNormal B/Circuit No.1 type: Line A/Circuit No.1 2±0.05 10.95 11.15 +0.1 2.8±0.05 5.8±0.1 with KR receptacles (With a standard boss) 2 ±0.05 +0.1 φ0.8 0 Line B Reverse type: +0.1 φ0.8 0 (With a standard boss) 2.65±0.05 Boss hole φ1.2±0.1 2 ±0.05 Line A Normal type: Line B/ Line B/Circuit No.1Circuit No.1 A±0.1 SIDE TYPE A±0.1 Line A/ B Line Circuit No.1 11.5 2.65±0.05 Boss hole φ1.6 ±0.1 0.4±0.05 Reverse type: Line B/Circuit No.1 with PHN receptacles type: LineNormal A Line B/Circuit No.1 +0.1 φ0.8 0 6.5±0.05 2 ±0.05 with KR receptacles Line B 1.1±0.05 6.5±0.05 A±0.1 Line A/ Circuit No.1 +0.1 type: Reverse φ0.8  0 Line A/Circuit No.1 ±0.1 Reverse type: Line B/Circuit No.1 With locks 8.4 Line A TOP TYPE 8.6 Normal type: Line A/Circuit No.1 11.5 TOP TYPE φ1.6 0 Normal type: Line A/Circuit No.1 Reverse type: Line A/Circuit No.1 2±0.05 2.8 +0.1 ±0.05 φ1.6 0 with KR receptacles with PHN receptacles Note: 1 . Tolerances are non-cumulative: ± 0.05 mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method.     Please contact JST for details as the dimensions shown in the above figure are reference values. IDC style connector (Receptacle) (2 to 12 circuits) 2 No. of circuits 5.15 B A 0.9 3.5 4.2 2 H JST Reverse type: Circuit No.1 Normal type: Circuit No.1 (13 to 16 circuits) 2 5.15 B A 0.9 Model No. Normal type Reverse type 02KR-6H-PC 02KR-6H-P 03KR-6H-PC 03KR-6H-P 04KR-6H-PC 04KR-6H-P 05KR-6H-PC 05KR-6H-P 06KR-6H-PC 06KR-6H-P 07KR-6H-PC 07KR-6H-P 08KR-6H-PC 08KR-6H-P 09KR-6H-PC 09KR-6H-P 10KR-6H-PC 10KR-6H-P 11KR-6H-PC 11KR-6H-P 12KR-6H-PC 12KR-6H-P 13KR-6H-PC 13KR-6H-P 14KR-6H-PC 14KR-6H-P 15KR-6H-PC 15KR-6H-P 16KR-6H-PC 16KR-6H-P Dimensions (mm) A B 組立レイアウト 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 Q'ty/ box 2,000 2,000 2,000 2,000 2,000 1,000 1,000 1,000 1,000 1,000 1,000 500 500 500 500 Material and Finish 2 Normal type: Circuit No.1 3.5 4.2 Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: 2 to 12 circuits...PA 66, UL94V-0, gray 13 to 16 circuits...Glass-filled PA 66, UL94V-0, gray H JST Reverse type: Circuit No.1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Applicable wire UL1571, 1061(Contact JST for other UL styles.) AWG#28, #26 Conductor / 7 strands, tin-plated annealed copper Insulation O.D. / 0.9 to 1.0 mm RoHS2 compliance 2 KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS PHコネクタ表1 Crimp style connector (Contact) Applicable wire AWG # mm2 Model No. SPH-002T-P0.5L 0.08~0.22 28~24 Insulation O.D. (mm) Q'ty/ reel 0.8~1.5 8,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 1.5 1 5.7 2.05 RoHS2 compliance Note: SPH-002T-P0.5S is also available. 2.08 2.85 Contact Crimping machine Crimp applicator SPH-002T-P0.5L AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SPH-002-05L APLMK SPH002-05L Note: Contact JST for fully automatic crimping applicator. Crimp style connector (Housing) Normal type (2 circuits) No. of circuits B A 4.2 3.5 6.25 H JST 2 No. of circuits Circuit No.1 (3 to 16 circuits) 2 2 B A 4.2 3.5 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Model Normal type PHNR-02-H PHNR-03-H PHNR-04-H PHNR-05-H PHNR-06-H PHNR-07-H PHNR-08-H PHNR-09-H PHNR-10-H PHNR-11-H PHNR-12-H PHNR-13-H PHNR-14-H PHNR-15-H PHNR-16-H No. Reverse type PHNR-02C-H PHNR-03C-H PHNR-04C-H PHNR-05C-H PHNR-06C-H PHNR-07C-H PHNR-08C-H PHNR-09C-H PHNR-10C-H PHNR-11C-H PHNR-12C-H PHNR-13C-H PHNR-14C-H PHNR-15C-H PHNR-16C-H Dimensions (mm) A B Material and Finish PA 66, UL94V-0, gray 6.25 H JST RoHS2 compliance No. of circuits Circuit No.1 Reverse type (2 circuits) 4.2 B 3.5 2 Circuit No.1 No. of circuits (3 to 16 circuits) 6.25 H JST A 4.2 B 2 2 No. of circuits 3 3.5 6.25 H JST A Circuit No.1 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 Q'ty/ bag 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS KR(DIP)表 Single-row header (Through-hole type) Top entry type (2 circuits) 4.5 (1.7) Normal type: Circuit No.1 0.5 (3 to 16 circuits) 1.7 4.5 2 Reverse type: Circuit No.1 1.95 A 0.5 0.5 Normal type: Circuit No.1 Side entry type 4.8 6 Dimensions( mm) A B 1.6 6.25 (1.7) B Reverse type Model No. No. of circuits Top entry type (with boss) Side entry type 2 B2B-PH-KBLC-H S2B-PH-KLC-H 3 B3B-PH-KBLC-H S3B-PH-KLC-H 4 B4B-PH-KBLC-H S4B-PH-KLC-H 5 B5B-PH-KBLC-H S5B-PH-KLC-H 0.5 6 B6B-PH-KBLC-H S6B-PH-KLC-H 7 B7B-PH-KBLC-H S7B-PH-KLC-H 8 B8B-PH-KBLC-H S8B-PH-KLC-H 9 B9B-PH-KBLC-H S9B-PH-KLC-H 10 B10B-PH-KBLC-H S10B-PH-KLC-H 11 B11B-PH-KBLC-H S11B-PH-KLC-H 12 B12B-PH-KBLC-H S12B-PH-KLC-H 13 B13B-PH-KBLC-H S13B-PH-KLC-H 14 B14B-PH-KBLC-H S14B-PH-KLC-H 15 B15B-PH-KBLC-H S15B-PH-KLC-H 16 B16B-PH-KBLC-H S16B-PH-KLC-H 3.4 (3.4) 6 B Dimensions( mm) A B 6.0 Reverse type: Circuit No.1 1.95 A (3.4) 6 B Normal type Model No. No. of circuits Top entry type (with boss) Side entry type 2 S2B-PH-KL B2B-PH-KBL-H 3 S3B-PH-KL B3B-PH-KBL-H 4 S4B-PH-KL B4B-PH-KBL-H 5 S5B-PH-KL B5B-PH-KBL-H 6 S6B-PH-KL B6B-PH-KBL-H 7 S7B-PH-KL B7B-PH-KBL-H 8 S8B-PH-KL B8B-PH-KBL-H 9 S9B-PH-KL B9B-PH-KBL-H 10 S10B-PH-KL B10B-PH-KBL-H 11 S11B-PH-KL B11B-PH-KBL-H 12 S12B-PH-KL B12B-PH-KBL-H 13 S13B-PH-KL B13B-PH-KBL-H 14 S14B-PH-KL B14B-PH-KBL-H 4.5 15 S15B-PH-KL B15B-PH-KBL-H1.7 16 S16B-PH-KL B16B-PH-KBL-H Reverse type: Circuit No.1 1.95 2 0.5 A Normal type: Circuit No.1 Q'ty/box Top entry type (with a boss) Side entry type 1,000 1,000 2.0 5.9 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 500 250 24.0 27.9 250 250 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 Q'ty/box Top entry type (with a boss) Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 500 250 24.0 27.9 250 250 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 Material and Finish (3.4) Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, gray RoHS2 compliance This product displays (LF)(SN) on a label. Note: 1. Top entry type headers without a bosses are also available.  2. PH connector header [B( )B-PH-K-S, S( )B-PH-K-S] can be also used. ( ) stands for circuits No. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-KBLC-HH...gray S...white Y...yellow R...red N...brown K...black (blank)...gray (normal side entry type only) 4 KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS KR(SMT)表 Single-row header (SMT type) Top entry type No. of circuits 2 B 2.975 A 5 (2) 1.9 2 3 4 5 6 7 6.6 8 9 10 Reverse type: Circuit No.1 Normal type: Circuit No.1 11 1.4 2.2 12 13 14 15 16 Normal type Model No. Top entry type B2B-PH-SM4-TB B3B-PH-SM4-TB B4B-PH-SM4-TB B5B-PH-SM4-TB B6B-PH-SM4-TB B7B-PH-SM4-TB B8B-PH-SM4-TB B9B-PH-SM4-TB B10B-PH-SM4-TB B11B-PH-SM4-TB B12B-PH-SM4-TB B13B-PH-SM4-TB B14B-PH-SM4-TB B15B-PH-SM4-TB B16B-PH-SM4-TB Side entry type S2B-PH-SM4-TB S3B-PH-SM4-TB S4B-PH-SM4-TB S5B-PH-SM4-TB S6B-PH-SM4-TB S7B-PH-SM4-TB S8B-PH-SM4-TB S9B-PH-SM4-TB S10B-PH-SM4-TB S11B-PH-SM4-TB S12B-PH-SM4-TB S13B-PH-SM4-TB S14B-PH-SM4-TB S15B-PH-SM4-TB - Dimensions (mm) B A Top entry type Side entry type Q'ty/ reel 2.0 7.95 7.9 1,000 4.0 9.95 9.9 1,000 6.0 11.95 11.9 1,000 8.0 13.95 13.9 1,000 10.0 15.95 15.9 1,000 12.0 17.95 17.9 1,000 14.0 19.95 19.9 1,000 16.0 21.95 21.9 1,000 18.0 23.95 23.9 1,000 20.0 25.95 25.9 1,000 22.0 27.95 27.9 1,000 24.0 29.95 29.9 1,000 26.0 31.95 31.9 1,000 28.0 33.95 33.9 1,000 30.0 35.95 - 1,000 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 6T, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: Top entry type headers with suction tape are also available. Side entry type 2 6 5.5 2.4 2.95 B A Normal type: Circuit No.1 Reverse type: Circuit No.1 (2.6) 1.6 Reverse type Model No. No. of circuits Top entry type Side entry type 2 B2B-PH-SM4C-TB S2B-PH-SM4C-TB 3 B3B-PH-SM4C-TB S3B-PH-SM4C-TB 4 B4B-PH-SM4C-TB S4B-PH-SM4C-TB 5 B5B-PH-SM4C-TB S5B-PH-SM4C-TB 6 B6B-PH-SM4C-TB S6B-PH-SM4C-TB 7 B7B-PH-SM4C-TB S7B-PH-SM4C-TB 8 B8B-PH-SM4C-TB S8B-PH-SM4C-TB 9 B9B-PH-SM4C-TB S9B-PH-SM4C-TB 10 B10B-PH-SM4C-TB S10B-PH-SM4C-TB 11 B11B-PH-SM4C-TB S11B-PH-SM4C-TB 12 B12B-PH-SM4C-TB S12B-PH-SM4C-TB 13 B13B-PH-SM4C-TB S13B-PH-SM4C-TB 14 B14B-PH-SM4C-TB S14B-PH-SM4C-TB 15 B15B-PH-SM4C-TB S15B-PH-SM4C-TB 16 B16B-PH-SM4C-TB - Dimensions (mm) B A Q'ty/ reel 2.0 7.9 1,000 4.0 9.9 1,000 6.0 11.9 1,000 8.0 13.9 1,000 10.0 15.9 1,000 12.0 17.9 1,000 14.0 19.9 1,000 16.0 21.9 1,000 18.0 23.9 1,000 20.0 25.9 1,000 22.0 27.9 1,000 24.0 29.9 1,000 26.0 31.9 1,000 28.0 33.9 1,000 30.0 35.9 1,000 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 6T, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. 5 KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS KRWコネクタ表1 Dual-row header Top entry type No. of circuits B A Reverse type: Line A/Circuit No.1 16 18 Line A 22 HJST Normal type: Line A/Circuit No.1 20 24 Line B 26 28 Normal type: Line B/Circuit No.1 Reverse type: Line B/Circuit No.1 30 32 Model No. Normal type Reverse type Top entry type Side entry type Top entry type Side entry type B16B-KRWHK S16B-KRWHS B16B-KRWHK-C S16B-KRWHS-C B18B-KRWHK S18B-KRWHS B18B-KRWHK-C S18B-KRWHS-C B20B-KRWHK S20B-KRWHS B20B-KRWHK-C S20B-KRWHS-C B22B-KRWHK S22B-KRWHS B22B-KRWHK-C S22B-KRWHS-C B24B-KRWHK-C B24B-KRWHK B26B-KRWHK S26B-KRWHS B26B-KRWHK-C S26B-KRWHS-C B28B-KRWHK S28B-KRWHS B28B-KRWHK-C S28B-KRWHS-C B30B-KRWHK S30B-KRWHS B30B-KRWHK-C S30B-KRWHS-C B32B-KRWHK S32B-KRWHS B32B-KRWHK-C S32B-KRWHS-C A 4.7 10.7 4.7 22.4 320 280 16.0 24.4 288 252 18.0 26.4 256 224 20.0 28.4 224 196 22.0 30.4 224 196 24.0 32.4 192 168 26.0 34.4 192 168 28.0 36.4 192 168 30.0 38.4 160 140 RoHS2 compliance This product displays (LF)(SN) on a label. Note:1.Top entry type headers with bosses or without clinched tails are also available. 2.The products listed above are supplied packed in tray. B10B-KRWHK-( )M...green H...gray N...brown 3.7 10.05 Reverse type: Line B/Circuit No.1 KRWコネクタポストトップ型 Line B 10.85 H J S T Normal type: Line B/Circuit No.1 2 14.0 Top entry type Side entry type Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, gray ex. B A B As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. B Side entry type Q'ty/box A Material and Finish 7.5 3.4 3.7 2 Dimensions (mm) 3.4 Line A 2.8 2 KRWコネクタ表1 5.8 Normal type: Line A/Circuit No.1 Reverse type: Line A/Circuit No.1 Dual-row header (with locks) Top entry type No. of circuits Line A/Circuit No.1 B A 10 12 14 Line A HJST Line B/Circuit No.1 16 18 20 Line B 22 10.7 24 26 30 32 10.7 3.4 11.5 With a standard boss With a compact boss Q'ty/ box 364 308 280 252 252 224 196 196 168 168 168 140 Material and Finish 3.4 11.5 28 Model No. Dimensions (mm) Top entry type Without bosses With a standard boss With a compact boss A B 8.0 17.0 B10B-KRWHK-F1 B10B-KRWHK-F1-1D B10B-KRWHK-F1-1 10.0 19.0 B12B-KRWHK-F1 B12B-KRWHK-F1-1D B12B-KRWHK-F1-1 12.0 21.0 B14B-KRWHK-F1 B14B-KRWHK-F1-1D B14B-KRWHK-F1-1 14.0 23.0 B16B-KRWHK-F1 B16B-KRWHK-F1-1D B16B-KRWHK-F1-1 16.0 25.0 B18B-KRWHK-F1 B18B-KRWHK-F1-1D B18B-KRWHK-F1-1 18.0 27.0 B20B-KRWHK-F1 B20B-KRWHK-F1-1D B20B-KRWHK-F1-1 29.0 20.0 B22B-KRWHK-F1 B22B-KRWHK-F1-1D B22B-KRWHK-F1-1 22.0 31.0 B24B-KRWHK-F1 B24B-KRWHK-F1-1D B24B-KRWHK-F1-1 24.0 33.0 B26B-KRWHK-F1 B26B-KRWHK-F1-1D B26B-KRWHK-F1-1 26.0 35.0 B28B-KRWHK-F1 B28B-KRWHK-F1-1D B28B-KRWHK-F1-1 28.0 37.0 B30B-KRWHK-F1 B30B-KRWHK-F1-1D B30B-KRWHK-F1-1 30.0 39.0 B32B-KRWHK-F1 B32B-KRWHK-F1-1D B32B-KRWHK-F1-1 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, gray RoHS2 compliance This product displays (LF)(SN) on a label. Note:1. The products listed above are supplied packed in tray. 2. Unlisted in UL/CSA/TÜV. 3. The applicable holder is "KRWH-( )( )-( )-1" only. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B10B-KRWHK-F1-( )- H...gray Y...yellow R...red N...brown M...green K...black 6 KR FAMILY/KR・PHN・KRW・TR・TRWKRWコネクタ表2 CONNECTORS KRW connector holder 0.7 B A Normal type: Line A/Circuit No.1 φ1 Indication for Line A 1 No. of circuits Reverse type: Line A/Circuit No.1 10 12 14 16 18 20 22 24 26 28 30 32 Line A 5 3 5 9.7 A H JST B Line B Normal type: Line B/Circuit No.1 9.7 Dimensions (imm) A B 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 13.4 15.4 17.4 19.4 21.4 23.4 25.4 27.4 29.4 31.4 33.4 35.4 PA 66, UL94V-0, gray 6.65 0.8 No. Reverse type KRWH-10C-H KRWH-12C-H KRWH-14C-H KRWH-16C-H KRWH-18C-H KRWH-20C-H KRWH-22C-H KRWH-24C-H KRWH-26C-H KRWH-28C-H KRWH-30C-H KRWH-32C-H Material and Finish KRWコネクタ表2 RoHS2 compliance 0.8 Indication for Line B Reverse type: Line B/Circuit No.1 Model Normal type KRWH-10-H KRWH-12-H KRWH-14-H KRWH-16-H KRWH-18-H KRWH-20-H KRWH-22-H KRWH-24-H KRWH-26-H KRWH-28-H KRWH-30-H KRWH-32-H KRW connector holder (for header with locks) 0.7 1 B A Normal type: Line A/Circuit No.1 Indication for Line A φ1 Line A 3 3 5 9.7 A H JST B Line B No. of circuits Model No. 10 12 14 16 18 20 22 24 26 28 30 32 KRWH-10-H-1 KRWH-12-H-1 KRWH-14-H-1 KRWH-16-H-1 KRWH-18-H-1 KRWH-20-H-1 KRWH-22-H-1 KRWH-24-H-1 KRWH-26-H-1 KRWH-28-H-1 KRWH-30-H-1 KRWH-32-H-1 Indication for Line B Q'ty/ box 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 13.4 15.4 17.4 19.4 21.4 23.4 25.4 27.4 29.4 31.4 33.4 35.4 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 Material and Finish Normal type: Line B/Circuit No.1 PA 66, UL94V-0, gray 9.7 6.65 0.8 0.8 Dimensions (mm) A B RoHS2 compliance Note:1. Unlisted in UL/CSA/TÜV. 2. The applicable header is "B( )B-KRW( )K-F1-( )" only. TR コネクタ表-1 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. KRWH-10-H-1H...gray Y...yellow R...red N...brown K...black S...natural TR connector (Unit for wire-to-wire connection) Reverse type: Circuit No.1 No. of circuits Normal type: Circuit No.1 2 3 4 7.4 5 6 7 1.3 2.8 8 2 9 A 10 2 10.5 Panel layout H J T C ±0.1 11 12 13 14 15 D B Secure locking ±0.1 3.2±0.1 6.4±0.1 16 TR connectors without secure locking device are also available. 7 Model No. Normal type Reverse type BU02P-TR-PC-H BU02P-TR-P-H BU03P-TR-PC-H BU03P-TR-P-H BU04P-TR-PC-H BU04P-TR-P-H BU05P-TR-PC-H BU05P-TR-P-H BU06P-TR-PC-H BU06P-TR-P-H BU07P-TR-PC-H BU07P-TR-P-H BU08P-TR-PC-H BU08P-TR-P-H BU09P-TR-PC-H BU09P-TR-P-H BU10P-TR-PC-H BU10P-TR-P-H BU11P-TR-PC-H BU11P-TR-P-H BU12P-TR-PC-H BU12P-TR-P-H BU13P-TR-PC-H BU13P-TR-P-H BU14P-TR-PC-H BU14P-TR-P-H BU15P-TR-PC-H BU15P-TR-P-H BU16P-TR-PC-H BU16P-TR-P-H Dimensions (mm) B C D Q'ty/ box 2.0 7.6 7.9 11.6 500 4.0 9.6 9.9 13.6 500 6.0 11.6 11.9 15.6 500 8.0 13.6 13.9 17.6 250 10.0 15.6 15.9 19.6 250 12.0 17.6 18.0 21.6 200 14.0 19.6 20.0 23.6 250 16.0 21.6 22.0 25.6 250 18.0 23.6 24.0 27.6 200 20.0 25.6 26.0 29.6 200 22.0 27.6 28.0 31.6 200 24.0 29.6 30.0 33.6 150 26.0 31.6 32.0 35.6 150 28.0 33.6 34.0 37.6 150 30.0 35.6 36.0 39.6 150 A Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, gray RoHS2 compliance This product displays (LF)(SN) on a label. TR コネクタ表-1 KR FAMILY/KR・PHN・KRW・TR・TRW CONNECTORS TRW connector (Unit for wire-to-wire connection) No. of circuits Normal type: Line B/Circuit No.1 A 2 Reverse type: Line B/Circuit No.1 16 18 Line B Mark 20 22 24 13.2 H JST B 26 28 A 30 Line A Mark Reverse type: Line A/Circuit No.1 32 Normal type: Line A/Circuit No.1 B A Dimensions (mm) B C D Q'ty/ box 14.0 23.5 23.9 27.5 100 16.0 25.5 25.9 29.5 100 18.0 27.5 27.9 31.5 50 20.0 29.5 29.9 33.5 50 22.0 31.5 31.9 35.5 50 24.0 33.5 33.9 37.5 50 26.0 35.5 35.9 39.5 50 28.0 37.5 37.9 41.5 50 30.0 39.5 39.9 43.5 50 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, gray +0.1 11.5  0 +0.1 4.2 0 1.5 0 +0.1 7.6 ±0.05 13.4 No. Reverse type BU16P-TRW-PC-H BU18P-TRW-PC-H BU20P-TRW-PC-H BU22P-TRW-PC-H BU24P-TRW-PC-H BU26P-TRW-PC-H BU28P-TRW-PC-H BU30P-TRW-PC-H BU32P-TRW-PC-H Material and Finish Panel layout +0.1 C 0 D Model Normal type BU16P-TRW-P-H BU18P-TRW-P-H BU20P-TRW-P-H BU22P-TRW-P-H BU24P-TRW-P-H BU26P-TRW-P-H BU28P-TRW-P-H BU30P-TRW-P-H BU32P-TRW-P-H ±0.05 RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. BU16P-TRW-P-HH...gray Y...yellow R...red N...brown S...natural (white) M...green 8
03KR-6H-P 价格&库存
很抱歉,暂时无法提供与“03KR-6H-P”相匹配的价格&库存,您可以联系我们找货
03KR-6H-P
    • 500+0.27760
    库存:1268
    03KR-6H-P
      • 1+1.302091+0.16837
      • 10+1.1622710+0.15029
      • 50+0.8039750+0.10396
      • 100+0.72533100+0.09379
      • 500+0.67289500+0.08701
      • 1000+0.646681000+0.08362
      • 2000+0.637942000+0.08249
      库存:1253
      03KR-6H-P
        • 2000+0.25019
        • 4000+0.23912
        03KR-6H-P
          • 2000+0.27160
          库存:44000
