SFH21-PPPN-D22-ID-BK-M181
    SULLINS
    CONN RECEPT 44POS 2MM IDT GOLD
SFH21-PPPN-D22-ID-BK-M181 数据手册
Headers .079” [2.00 mm] Contact Centers, Shrouded (Box) Headers, Straight/Right Angle/SMT - SBH Series Mates with SFH21 series (See opposite page) SPECIFICATIONS • Centered Polarizing Notch • Operating Temperature: -40°C to +105°C • Processing Temperature: 230°C Max. for 60 seconds, (260°C Max. 10 seconds) • UL Flammability Rating: 94V-0 • Voltage Rating: 20 milli Ohms Max. • Current Rating: 2 Amps • Dielectric Withstanding: 500 VAC • Insulation Resistance: 5000 Megohms PART NUMBER OPTIONS SBH21 - N B P SERIES SBH21 = Box Header, .079” [2.00 mm] Contact Centers by .079” [2.00 mm] Row Spacing COLOR BK = Black TERMINATION TYPE ST = Straight RA = Right Angle SM = Surface Mount INSULATOR MATERIAL N = Nylon CONTACT MATERIAL B = Brass NUMBER OF CONTACT POSITIONS (Pins per Row) 03 thru 18, 20, 22, 25, 30, 32, 34 CONTACT FINISH - RoHS Compliant P = Gold Flash Overall NUMBER OF ROWS D = Dual Row CONTACT CENTERS N = .079” [2.00 mm] Headers N - D 10 - ST - BK DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Dimensions in [ ] are in millimeters, all others are in inches. .110 [2.80] .173 [4.40] .079 [2.00] STRAIGHT (ST) Example P/N: SBH21-NBPN-D20-ST-BK .079 [2.00] .110 [2.80] .270 [6.85] .220 [5.60] .079 [2.00] RIGHT ANGLE (RA) Example P/N: SBH21-NBPN-D20-RA-BK .274 [6.95] .079 [2.00] .020 [0.50] SQ. .213 [5.40] .299 [7.60] SURFACE MOUNT (SM) Example P/N: SBH21-NBPN-D20-SM-BK 106 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
- 物料型号:SBH21系列,包括直插式(ST)、直角式(RA)和表面贴装式(SM)。 - 器件简介:这些是带护罩的盒式连接器,接触中心间距为.079英寸(2.00毫米),适用于SFH21系列。 - 引脚分配:提供3至34个接触位置的选项,双排布局。 - 参数特性: - 工作温度范围:-40°C至+105°C。 - 加工温度:最高230°C,持续60秒;最高260°C,持续10秒。 - UL阻燃等级:94V-0。 - 电压等级:最大20毫欧姆。 - 电流等级:2安培。 - 介质耐压:500 VAC。 - 绝缘电阻:5000兆欧。 - 功能详解:文档中未提供具体功能详解,但根据参数特性,这些连接器适用于需要高绝缘电阻和介质耐压的应用。 - 应用信息:适用于需要高可靠性和电气性能的应用场合。 - 封装信息:提供了不同类型(ST、RA、SM)的尺寸信息,具体尺寸图可在Sullins官方网站或通过电子邮件获取。
SFH21-PPPN-D22-ID-BK-M181 价格&库存
很抱歉,暂时无法提供与“SFH21-PPPN-D22-ID-BK-M181”相匹配的价格&库存,您可以联系我们找货
