A3EA-44D-2R
A3EA-44D-2R
    HRS(广濑)
    CONN SOCKET IDC 44POS 2MM
A3EA-44D-2R 数据手册
2mm Pitch Miniature Connector for HDD A3E Series ■Features 1. Variation in Number of Contacts This connector can be chosen according to applications, using together with other series products as follows: Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1) Cable crimping type (A3B series) (2) Cable ID type (A3E series) (3) FFC connection type (MA18 series, A3C series) (However, the A3E series pin header corresponds to the A3E series socket only.) On the other hand, 44 contacts are available for AT bus connection, and 55 contacts for SCSI connection. 2. Batch Insulation Displacement 1 mm pitch ribbon cable can be insulated and displaced. type without polarizing guide 3. Mechanism to Prevent Mis-insertion type with polarizing guide The connector on the socket side contains a mechanism to prevent mis-insertion in the connector on the header side. ■Product Specifications Rating Current rating: 0.5A Operating Temperature Range:-55 to +85ç (Note 1) Storage Temperature Range:-10 to +60ç (Note 2) Voltage rating: 125V AC Operating Moisture Range:40 to 80% Item Storage Humidity Range:40 to 70% (Note 2) Specification 1. Insulation Resistance Condition 1000M ohms min. 250V DC 2. Withstanding voltage No flashover or insulation breakdown. 300V AC/1 minute 3. Contact Resistance 40m ohms max. 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Insulation resistance: 1000M ohms min. 6. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% (-55ç: 30 minutes →15 to 35ç: 5 minutes max.→ No damage, cracks, or parts looseness. (+85ç: 30 minutes →15 to 35ç: 5 minutes max.) 5 cycles 7. Durability (Mating/un-mating) Contact resistance: 50m ohms max. 8. Resistance to Soldering heat 100 cycles No deformation of components affecting performance. Solder bath: 260ç for 10 seconds Manual soldering: 350ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Part Insulator Contact C26 Material Finish Remarks Black UL94V-0 Pin header Polyamid Socket PBT Pin header Brass Selective gold plated over nickel Socket Beryllium copper underplated ––––––– A3E Series●2mm Pitch Miniature Connector for HDD ■Ordering Information ●Pin Header q Series Name A3E - * P A - 2 DSA q w e r t y : A3E w Number of contacts: 44, 50 e P: Pin header r A: Selective gold plated t Contact pitch : 2mm Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. y Contact type: DSA : Straight dip type ●Socket q Series Name : A3E : With polarizing guide A3EA : Without polarizing guide A3E - * D - 2 R q w e r t w Number of contacts: 44, 50 e D: Receptacle r Contact pitch: 2mm t Connection type: R : ID type C27 A3E Series●2mm Pitch Miniature Connector for HDD Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Pin Header BPCB mounting pattern Unit: mm CL No. A B C D 621-0911-8-71 52.0 42.0 49.2 45.0 A3E-50PA-2DSA(71) 621-0914-6-71 58.0 48.0 55.2 51.0 ●For 44 pos., without contact No. 20 pin header is available. A3E-44PA-2DSA(81) Contact No.2 Contact No.44 Without contact (No.20) Contact No.43 44P Contact No.1 Without contact (No.20) C28 Part Number A3E-44PA-2DSA(71) RoHS YES A3E Series●2mm Pitch Miniature Connector for HDD ■Socket Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Type with polarizing guide to prevent mis-insertion (A3E) Body Protector Without hole(No.20) Combination View No.44 No.43 No.2 No.1 Unit: mm Part Number CL No. A B C D A3E-44D-2R 621-0811-3 49.0 42.0 43.0 44.3 A3E-50D-2R 621-0814-1 55.0 48.0 49.0 50.3 RoHS YES Note : For 44 pos., without contact No. 20 hole soket is available. C29 A3E Series●2mm Pitch Miniature Connector for HDD Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Type without polarizing guide to prevent false-insertion (A3EA) Body Protector Combination View Unit: mm C30 Part Number CL No. A B C D A3EA-44D-2R 621-0861-1 49.0 42.0 43.0 44.3 A3EA-50D-2R 621-0864-0 55.0 48.0 49.0 50.3 RoHS YES A3E Series●2mm Pitch Miniature Connector for HDD ■Recommended Cable for A3E Socket Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (tin plating annealed steel wire) Ribbon Cable Number of Core wire Construction A B 7/0.127 44 43 7/0.127 50 49 Contacts (pc./mm) 44 50 BTable of A3E Series Connection Tools ●Connection Press Part Number: HI-FLEX Connection Press HHP502 CL550-0082-2 ●Pressing Block Part Number: Pressing Block A-01 CL550-0133-1 ●Applicator Universal Guide Plate Part Number: A3E-GPA CL550-0216-7 C31 A3E Series●2mm Pitch Miniature Connector for HDD MA18 Series The MA18 series is a 2mm pitch FFC socket connector developed for miniature HDD and main port connection. 44 contacts are provided for AT bus connection. Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Ordering Information C32 MA18A - 44 D A - 2 DSA q w e q Series Name : MA18A r t y y Contact type (Straight type) w Number of contacts : 44 DSA : Dip length 3mm e Contact alignment : D : Double row DSB : Dip length 2.5mm r Contact plating type DSC : Dip length 2mm A : Selective gold plated t Contact pitch : 2mm ■Variation in Number of Contacts Part Number CL No. Remarks MA18A-44DA-2DSA(71) 588-0247-3-71 –– MA18A-44DA-2DSB(71) 588-0255-1-71 –– MA18A-44DA-2DSC(71) 588-0253-6-71 –– MA18M-44DA-2DSB(71) 588-0291-5-71 High profile mount type RoHS YES A3E Series●2mm Pitch Miniature Connector for HDD Variation in Connection between HDD and Main Board ■Pin Heade Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1) Conventional product (used as conventional HDD interface pin header) ●Straight through hole type (see catalog page C15) 44 contacts : A3C-44P-2DSA (see photo) 50 contacts : A3C-50P-2DSA ●Straight SMT type (see catalog page C22) 44 contacts : A3-44PA-2SV(71) (see photo) 50 contacts : A3-50PA-2SV(71) (With boss type available) ●Right angle through hole type (see catalog page C13) 44 contacts : A3B-44PA-2DS(71) (see photo) 50 contacts : A3B-50PA-2DS(71) (2) Box type product (Socket side prevents mis-insertion) ●Straight through hole type(see catalog page C28) 44 contacts : A3E-44PA-2DSA(71) (see photo) 50 contacts : A3E-50PA-2DSA(71) Note: Correspond to A3E series socket only. C33 A3E Series●2mm Pitch Miniature Connector for HDD ■Socket (1) Products suitable to various cables ●Discrete wire Crimping Type (see catalog page C19) 44 contacts: A3B-44D-2C Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Crimping contacts and crimping tools are detailed on page C20. ●Ribbon Cable (1mm pitch) Batch ID Type (see catalog page C29) 44 contacts: A3E-44D-2R (see photo) 50 contacts: A3E-50D-2R Insulation displacement is detailed on page C31. ●FPC Connection Type 44 contacts: MA18A-44DA-2DSA(71) (photo) ( ( For a typical example, products are provided corresponding to various board thickness. For details, refer to page C32. 50 contacts: A3C-50DA-2DSC(71) For a typical example, products are provided corresponding to various board thickness. For details, refer to page C17. ) ) (2) Right Angle through hole Type (see catalog page C16.) 44 contacts: A3-44DA-2DS(71) (see photo) 50 contacts: A3-50DA-2DS(71) (3) Straight through hole Type 44 contacts: MA18A-44DA-2DSA(71) (see photo) (See catalog page C32.) 50 contacts: A3C-50DA-2DSA(71) (see catalog page C17.) C34 Powered by TCPDF (www.tcpdf.org)
A3EA-44D-2R 价格&库存
很抱歉,暂时无法提供与“A3EA-44D-2R”相匹配的价格&库存,您可以联系我们找货
