HIF3A-60D-2.54R
HIF3A-60D-2.54R
    HRS(广濑)
    CONN SOCKET 60POS 2.54MM
HIF3A-60D-2.54R 数据手册
High Performance Ribbon Cable Connector HIF3A Series ■Features 1. Two-Point Contact Structure This connector is designed in the two-point contact structure with high reliability. 2. Compatibility with HIF3 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. This connector is compatible with HIF3B series products compliant with MIL standard and other HIF series headers.(Except HIF3B-60 pos.) 3. Applicable Cable AWG#28 The applicable cable is UL2651 AWG#28 flat cable (7 cores./0.127mm, jacket dia 0.9±0.1mm). ■Applications Computers, terminal equipment, PPC, various kinds of electronic equipment, and office automation machines ■Product Specifications Current rating : 1A Rating Operating Temperature Range : –55 to +85ç (Note 1) Storage Temperature Range : –10 to +60ç (Note 2) Voltage rating : 200V AC Operating Moisture Range : 40 to 80% Item Storage Humidity Range Specification : 40 to 70% (Note 2) Condition 1000M ohms min 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 15m ohms max 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 1. Insulation Resistance 5. Humidity (Steady state) Insulation resistance: 1000M ohms min. 6. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% (-55ç: 30 minutes ➝ 15 to 35ç: 5 minutes max. No damage, cracks, or parts looseness. 125ç: 30 minutes ➝ 15 to 35ç: 5 minutes max.) 5 cycles 7. Durability (Mating/un-mating) Contact resistance: 15m ohms max. 500 cycles Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Part Material Finish Remarks Insulator PBT Black UL94V-0 Contact Beryllium copper Gold plated over nickel underplated –––––– ■Ordering Information HIF3A - * D - 2.54 R q w e q Series Name : HIF3A w Number of Contacts : 16, 20, 26, 30, 34, 40, 50, 60 e Contact alignment : D : Double r t r Contact Pitch t Connection type R : 2.54mm : ID type B13 HIF3A Series●High Performance Ribbon Cable Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Socket Type Body Protector Clamp Note1: The 50 contact and 60 contact connectors contain convex area at two points. Note2: The 60 contact connector indicates 5.6. The applicable pin header is HIF3BAF type. Unit:mm B14 Part Number CL No. Number of Contacts A B C D E HIF3A-10D-2.54R 562-0057-5 10 17.27 10.16 11.43 17.27 17.27 HIF3A-16D-2.54R 562-0058-8 16 24.89 17.78 19.05 24.89 24.89 HIF3A-20D-2.54R 562-0059-0 20 29.97 22.86 24.13 29.97 29.97 HIF3A-26D-2.54R 562-0060-0 26 37.59 30.48 31.75 37.59 37.59 HIF3A-30D-2.54R 562-0055-0 30 42.67 35.56 36.83 42.67 42.67 HIF3A-34D-2.54R 562-0061-2 34 47.75 40.64 41.91 47.75 47.75 HIF3A-40D-2.54R 562-0062-5 40 55.37 48.26 49.53 55.37 55.37 HIF3A-50D-2.54R 562-0063-8 50 68.07 60.96 62.23 68.07 68.07 HIF3A-60D-2.54R 562-0056-2 60 80.77 73.66 74.93 80.77 80.77 RoHS YES
HIF3A-60D-2.54R 价格&库存
很抱歉,暂时无法提供与“HIF3A-60D-2.54R”相匹配的价格&库存,您可以联系我们找货
