MKT-E-13088F
MRF18 Series
Vertical Mating, Non-Magnetic
8-channel Coaxial Connector
Features
1.Non-Magnetic coaxial connector
2. Small Size & Light Weight
3. Vertical mate, horizontal cable out
4. High lock strength & cable pull resistance
5. Easy cable termination with soldering both center
and outer conductors
6. Flow mounting or manual soldering for PCB
mounting
7. Applicable cable ranges from 1.13 to 1.8 mm
8.RoHS compliant
Vertical Mate Allows
Layout on PCB Center
37
6.4
in mated
4.6 grams
(cable is not included)
Plug: MRF18-8P-178B/U
17
.7
Receptacle: MRF18-8R-PC
Specifications
Characteristic
Impedance
50
Operating
Temperature Range
-40 C to + 125 C (includes
temperature rise caused by current flow)
V.S.W.R.
1.3 Max. from DC to 1 GHz
1.4 Max. from 1 to 2 GHz
Contact Resistance
Center: 35 m Max. Outer: 20 m Max.
Insulation Resistance 500 M Min. (DC100 V)
High Frequency Characteristics
Data at [Port 1]
HRM-306
Test PCB
MRF18-8P-178B/U ASSY
L=100 mm RG-178B/U Cable
V.S.W.R.
Cable Outer Dia.: 1.13 to 1.8 mm
Cable Pull Force: 70 N/line
(Actual measured value with RG-178B/U cable )
Lock Strength: 28 N
(Actual measured value when cables are pulled up)
Insertion Loss
(dB)
[Port 1]
MRF18-8R-PC
HRM-200-088BPJBN
Insertion Loss
-1
1.8
-2
1.6
-3
1.4
V.S.W.R.
-4
1.2
Withstanding Voltage AC 300 V for 1 minute
Durability
30 times
-5
1
1
1.5
Frequency (GHz)
Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities.
© 2014 HIROSE ELECTRIC CO., LTD. All rights reserved.
2
Issued: Mar. 28, 2014
很抱歉,暂时无法提供与“MRF18-8P-178B/U”相匹配的价格&库存,您可以联系我们找货
